ice randomly starting and stopping
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lar.smith42, Feb 5, 2017.
  1. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    If you can't lock the car from the outside, it may be that you have left or lost your spare key inside the car
  2. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    You can't lock the car using the drivers door handle if the engine is running or if your spare key is inside the car. I always use the door handle to unlock and lock the car. So when the car locked itself with my wifes keys inside that wasn't normal.
    Rebound likes this.
  3. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    does your key fob have remote start capability? my last car did and the way the key was in my pocket I sat on the button and remote started it a few times and also if hold the unlock it would roll all the windows down! it took me a minute to figure out what was going on.
  4. bisco
    51,895
    i think you're on the right track with the corolla or camry. a car that starts itself is not safe to drive. what if it decides to steer itself?
    lar.smith42 likes this.
  5. lar.smith42
    203
    118
    Double Oak , Texas
    Steering is electric but I don't think its controlled by the computer. But that is a scary thought.
  6. bisco
    51,895
    well, the accelerator is another scary one. remember christine?:eek:
    thatoneraccoon and lar.smith42 like this.
  7. lar.smith42
    203
    118
    Double Oak , Texas
    Now that is scary !!!!!!! This is all probably caused by the fact that I haven't changed any of my fluids yet besides my oil (and thats changed at 10k). I think also the air in my tires is to low 38lbs.
  8. Mendel Leisk
    41,400
    I guess it's pretty much a done deal, that you are shutting the car down. Still, it seems to behaving like it's not shut down.
  9. lar.smith42
    203
    118
    Double Oak , Texas
    Whether or not the ICE is running or not has nothing to do with the headlights going off and on. I don't have the headlights that come on when car is started (unless you leave them on from the night before). If I had left the car running the and not turned the lights off they would have stayed on and not been going on and off.
  10. bisco
    51,895
    are you trying anything, or pretty much giving up? i was thinking a webcam to keep an eye on her at night. or maybe a private dick to make sure she's not cheating on you.;)
  11. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    …I have done that at least twice in the early days! (…hangs head in shame! :oops:) :whistle:;)
  12. bisco
    51,895
    did the headlights go on and off like a horror movie?
  13. lar.smith42
    203
    118
    Double Oak , Texas
    It wont do it often enough to catch it the act. Its 7 1/2 yrs old so I may just trade it in on something newer.
  14. bisco
    51,895
    are you sure you're neighbor wasn't pulling your leg?
  15. bisco
    51,895
    did you ever check the 12v?
  16. lar.smith42
    203
    118
    Double Oak , Texas
    checked at dealer
  17. lar.smith42
    203
    118
    Double Oak , Texas
    Thank you all for trying to help. Took it in to dealer last night to have it checked again and nothing found. So i got pissed and traded it in on a 2017 Corolla SE. What a difference. Better ride and quieter. Not as good MPG but I was looking for comfort and safety .
  18. Mendel Leisk
    41,400
    Ah man.
  19. beaker617
    beaker617 New Member
    lockport ny
    really wish your story had a better ending. my '09 prius is doing weird things since the 12V was replaced. I'll power it off, then it just comes back on. done this about 10 random times. but today, when I went back out to go somewhere, it wouldn't do ANYTHING. I tried holding down the power button - sometimes it would turn green, but no other activity. sometimes it would blink red. sometimes just nothing. so I took my mom's car to run the errand. when I came back, I decided to try it again - only to find that the thing was ON already. and I have reason to believe that it turns on while i'm not around ... whenever it does this weird electrical blip, the clock always goes to 1:00 and there have been times when I've gotten in, started it, and the clock is wrong by varying times.
  20. bisco
    51,895
    check the 12v health and connections.
