EnTune App Suite Update ... ?
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Optimus PRIME, Feb 16, 2017.
  1. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Well, I stand corrected, it bit me this morning, I'm at the dealer now, discussing the issue
    #21 priuscatprimeguy, Feb 17, 2017
  2. priuscatprimeguy
    2,730
    2,640
  3. priuscatprimeguy
    2,730
    2,640
    the day didn't start out well for me. Not only did Entune repeat it's update, ICE kicked in when I surpassed 30 MPH:mad::mad: note to Bisco: see another post about ICE kicking in
  4. Lemooron
    Lemooron Junior Member
    73
    25
    Lemoore, CA
    Mine updated once yesterday and once today.
  5. MikeDee
    MikeDee Senior Member
    1,578
    597
    San Francisco Bay Area
    I just checked my car and there are no updates available. I wonder if you guys are getting an old update? Mine updated back in December just after I purchased my car.
  6. Dmitriy Sokol
    Dmitriy Sokol Active Member
    112
    108
    Annapolis, MD
    Mine did it again today. It's not an update, it's a fresh "initial" installation of Entune. For some reason our cars delete the Entune suite on daily basis, requiring a fresh install. Not a big deal, since I rarely use the apps, but disconcerting nonetheless.
  7. priuscatprimeguy
    2,730
    2,640
    So....a cast of numbers....how many times total did the update show up, so far for me it's two.
  8. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Caution !
    After my second update strangeness happened.
    I have no idea if this issue is connected to update, but it happened just afterwards.
    I had an update notification ( after 2 ) that the update was complete.
    So I hit the home button to clear the display, powered off the car and went and got a sandwich.
    Afterwards, I powered up the car and headed home. The car went in Ev mode with 75% charge, as normal.
    I noticed immediately that when I let off the accelerator the dynamic breaking when into effect big time.
    Normally when in EV when you take you foot off the accelerator, you get a little regen, with a thin sliver of indication on the HSI display that some charge was happening.
    Instead what I got was about a 50% regin display on the HSI and you could really feel the de-acceleration.
    No problem, just meant that my foot had to stay on the accelerator, else I come to a stop relativity quick.
    So a little later my foot noticed the extra effort, so I decided to use the cruise control, while driving.
    When I turned on cruise control, the set switch would not work. It was never acknowledged, and I got no cruse control.
    I flipped it off, business as usual.
    Flipped it on, ok, but the set would not take.
    Tried 4 more times, no cruise control.
    Pulled over to the side, powered off the car.
    Powered on, joined traffic, and all was well.
    Back to normal.
    I have no idea if its related to the update, but it happened once for me.
  9. Dmitriy Sokol
    112
    108
    Annapolis, MD
    Could be just a coincidence. That was an Entune update, which doesn't really have anything to do with drive management. Unless Toyota is really doing something weird with our Primes.
  10. Primeinmountains
    Primeinmountains New Member
    Las Vegas
    Has anyone who has had this update issue contacted entune support? I have the update on my prime, but I'm waiting to see if this resolves itself before I run it...
  11. 34Hupp
    34Hupp 1934 Hupmobile - Americas 1st Aerodynamic
    62
    100
    Rochester, NY
    The heavy ReGen and not being able to lock on Cruise is indicative of being in the "B" mode.
    Dmitriy Sokol likes this.
  12. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    Did not notice any engine braking.
  13. Dmitriy Sokol
    112
    108
    Annapolis, MD
    Agreed. Sounds like you may have accidentally slipped into the B-mode.
  14. sonomac
    sonomac Junior Member
    25
    US
    Same here. Will see what tomorrow brings.
  15. Civic4982
    Civic4982 Member
    46
    40
    Mine keeps freezing at 9%
    iPhone ?
  16. I'mJp
    I'mJp Senior Member
    628
    552
    Ma, USA
    I drove today and tried B mode. That's what it was. How it got that way, I don't know.
  17. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    At least it didn't happen anymore for me yesterday the whole day.
    priuscatprimeguy likes this.
  18. priuscatprimeguy
    2,730
    2,640
  19. Dmitriy Sokol
    112
    108
    Annapolis, MD
    Nothing happened for me as well. Perhaps it was an Entune glitch that pushed redundant updates. Hopefully it's fixed, but curious why it affected just Primes and not all Entune enabled Toyotas.
  20. Optimus PRIME
    180
    141
    SF Bay Area
    It was SO HARD to convince you what was happening to me and some of us while you kept talking about bad connections and stuff. Now you TRULY understands don't you?
