Dealership transaxle fluid change nightmare
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by liquidtenmillion, Feb 17, 2017.
  1. liquidtenmillion
    liquidtenmillion Active Member
    261
    194
    Easley, SC
    I am 100% certain that it was transaxle fluid as I touched it and it was rad it was not cooland either. so there is literally absolutely no way to get more than 3.5 quarts in? I know The complete procedure and understand that it flows back at the fill hole but I am wondering if maybe they filled it through some tube to somewhere else in the car .
    What else could they have possibly done? Would either and overfill or in underfill or a plug forgetting has a hybrid system overheat?
    I am on the way to pick up the car right now should I tell them that I actually know quite a bit about the Prius and that I know the Phil process for agent to you and Jen three and then neither could possibly take 6.5 quarts in? When should I do if he swears up and down if that's what they did and that that has been corrected?
    The vehicle is still under the comprehensive warranty and I would be thrilled if they could just replace the transactional and the inverter if I took it to a different dealership that wasn't so concerned about CYA would they be more likely to do something like this?
  2. Mendel Leisk
    40,484
    Print out and take along that pdf I posted, that might help. I too am curious how the heck they got 6.5 quarts in. Maybe just a typo?
    You really want to get some documentation as to what they did this second time around, and just as importantly: that the invoice has printed on it the symptoms you reported.
    There was something bugging me, and I found it. There's a THIRD bolt on the second gen Prius, and maybe something similar on third gen? The 3rd bolt on second gen was up at the top of the transaxle. Assuming there's something similar on 3rd gen, maybe they filled the transaxle through that bolt hole? Got 6.5 quarts in? Grasping at straws:
    Spring maintenance
    If they filled at the regular fill hole, reinstalled the fill bolt and torqued it, there would be no problems. They screwed up, and their evasive behaviour only reinforces this.
  3. bisco
    51,033
    make sure the repair order documents their claimed error. you'll need that to show toyota that they are clueless. i would expect a new tranny, or at least an extended warranty.
  4. liquidtenmillion
    261
    194
    Easley, SC
    It was definitely 6.5 quarts, he said it to me over the phone, in person, and my 2nd invoice from when I picked up the car said it(along with their mistake)
    The first invoice said "Transmission fluid drain and refill, 89.99$" he tried to tell me it was 140 for a flush but I told him that I was not interested in any kind of flash they have and only want a drain and refill and that's when he came back with that price.
    I thought it was strange because it did not break it down by labor and parts and nothing on the sheet mentioned anything about the number of quarts of fluid they used or the type. Usually for example if I get an oil change it will say 4x 0W 20.
    Would these problems potentiay be caused by them putting in the wrong type of ATF? I have a car now and it seems to drive properly and they did clean up all of the transmission fluid in the engine compartment.
    I am concerned about long-term damage I just cannot see how the transaxle could spew out fluid without causing damage unless there is some type of overflow bleed valve or something of the like. So you guys think that my next step is to click the contact us link and contact Toyota corporate? I suppose my plan is to attach the PDF from the last service and then the PDF they just gave me that says that they fixed my problems by leveling the car draining the fluid and ensuring the proper amount of fluid is in the car.
    Should I ask for a warranty extension? Sorry for all the questions I have never dealt with something like this, and I have no idea how to properly deal with corporate Toyota. The only thing I truly want is for my car to be just as reliable as it was two days ago before I had a routine maintenance done.
    Thank you all very much for your help
  5. JC91006
    JC91006 Senior Member
    16,656
    8,506
    The car can only hold a certain amount of ws fluid, can't hold more. I think they are just unsure what amount to invoice and put in 6.5 quarts, not that the car will take that amount. There's even a chance they didn't do anything, just bill you for a service (jiffy lube scam)
    Since you didn't get charged extra for the additional parts, it's probably not worth worrying about it.
  6. bisco
    51,033
    i would contact toyota, explain what happened, send the the doc, and ask for help. none of us has ever had this happen, so we don't really have firm advice for you.
    hopefully, they will contact the dealer, explain the mistake to you, and back you up in some way that limits your potential damage.
  7. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I agree. Toyota corporate has always been very helpful when I've had to call them!
  8. liquidtenmillion
    261
    194
    Easley, SC
    They most certainly did change the transaxle fluid because I had a brand new red clean fluid in the engine compartment and the fluid that comes out of a Prius with 30 K on it is definitely black . I don't think you quite read my thread carefully as they told me the reason that my car shut off and gave the red triangle and was billowing smoke out was because they put in 6.5 quarts instead of the standard 3.5 and I triple verify that they seriously say that they got 6.5 quarts in.
    I can't tell if they are lying and this is a CYA situation and they did something even dumber than putting in far too much fluid and are afraid to admit it or if somehow they managed to get 6.5 into the system. Obviously they could not have done that through the Fill hole as it will only allow 3.5 before it just falls out the side.
    I have the car in hand and it seems fine all though maybe less mpg but could be in my head.(again, I had it serviced yesterday, broke down this morning, and then 2 hours after I got it back to them by tow truck they tell me I can pick it up and that all they had to do was drain some fluid.
    When I call corporate Toyota what exactly do I ask for? What kinds of things are they capable of? Are they just going to tell me to piss off because I have the car in hand? Ideally what I would want is the inverter and the transaxle preemptively replaced is that possible, Can corporate Toyota order such a thing? Could I get them to say that if my transmission should ever feel that they will replace it for free due to this incident? What about a warranty extension? The dealer said that it was not necessary because they swear no damage has been done.
    What are the odds that if they did put in 6.5 quarts and I drove normal speeds for 15 miles and stopped as soon as the hybrid overheat came on that everything will be fine?
    Also how could too much transaxle fluid cause a hybrid system overheat?
    I greatly appreciate all of the help guys thank you.
    #28 liquidtenmillion, Feb 17, 2017
  9. liquidtenmillion
    261
    194
    Easley, SC
    Here is what they put on the service sheet for the 2nd visit
    THE CUSTOMER STATES THAT THE VEHICLE WAS DRIVING NORMALLY
    BUT THE WHOLE TRIP THE BATTERY WAS LOSING POWER THE WHOLE
    TRIP AND THEN AFTER TEN MINUTES THE CUSTOMER SMELLED SMOKE
    AND THE HYBRID SYSYTEM OVERHEAT CAME ON AND POPPED THE HOOD
    SMOKE WAS BELLOWING OUT AND THERE IS TRANSMISSION FLUID ALL
    OVER THE ENGINE
    DURING THE DRAIN AND FILL PROCESS WE ACCIDENTALLY OVERFILLED
    THE TRANSMISSION BY APPROXIMATELY 3 QUARTS CAUSING THE
    OVERFILL OF THE TRANSMISSION TO COME OT OF THE SYSTEM TO
    SMOKE ON THE EXHAUST
    WE LEVELED THE TRANSMISSION FLUID LEVEL TO MANUFACTURE
    SPEC AND TEST DROVE VEHICLE AND TESTED ALL COMPONTENTS
    WORKING TO SPEC NOW
    How does fluid "come out of the system" without causing a leak?
  10. Jerry Liebler
    Jerry Liebler Member
    177
    85
    Science Hill Kentucky
    2013 Prius Plug-in
    I'm inclined to say BS to the claim it was overfilled! IT is almost impossible to overfill, it's full when the fluid runs out of the fill port. What "mechanic" is going to put the fill plug in with oil gushing out? An overfilled transmission is, simply, not going to cause the inverter to over heat, or the car to quit. I believe they invented the overfilled story knowing that they have done much more significant damage to your car. IMO it is much more likely that they left the drain plug loose, it fell out and the tranny fluid was blown all over as you drove once the oil was gone the transmission seized, the inverter overheated and the car quit. I've driven a pip that had no transmission fluid, it seized after about 20 miles and quit with the triangle of death. In my case the party that did it admitted it and replaced the transmission and inverter with no questions asked. FWIW it did throw some codes that led to the transmission and it was driveable the next day, after it cooled down. In addition to the other good advice here I'd recommend that you contact an attorney and get ready to sue the dealership.
    thatoneraccoon and Merkey like this.
  11. liquidtenmillion
    261
    194
    Easley, SC
    Thanks for the response!! Two caveats however first I drove the car home after the service about 10 miles, and I checked under the car before I left and saw no leakage and checked under the car while it was parked in my garage before I left this morning and there was still no leakage. It is only while I was driving on the road and had the sudden smoke and overheat and the fluid on the engine compartment I also checked on the ground and still no fluid on the ground anywhere . Second there were no codes throne and I was able to start the vehicle 30 minutes later to move it slightly.
  12. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    There is absolutely no way they accidentally put three extra quarts of fluid into your transaxle. Hell, even if they found another fill hole that we don't know about, there simply isn't enough room under the Prius hood for 3 quarts to. The transaxle would have to be so much larger to ever accommodate that much fluid. that's double of what it's designed to hold! Completely ridiculous.
    Merkey likes this.
  13. liquidtenmillion
    261
    194
    Easley, SC
    So what do you guys think I should do, what kind of powers does corporate Toyota have? What kind of things have you guys gotten in the past? What should I demand?
    Truly the only things I would feel comfortable with would be either a preemptive inverter and transaxle change by a different dealership or to trade in my car for a new car even though it's Brand new and I owe more on it than it is worth.
    Thank you guys so much for all the help so far it's been a real blessing.
    EDIT: also one more question would just the inverter and transaxle be the problems? Or would Mg1 or mg2 be a problem also, or are they included in the transaxle? Is that even feasible that I would be able to get these parts replaced or to get a new car? I just seem like they're going to train roll me until the warranty runs out because I only have 5000 miles left.
    #33 liquidtenmillion, Feb 17, 2017
  14. bisco
    51,033
    they have all the power. they run the company.
    Raytheeagle likes this.
  15. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    At least gen 2 and 3 have a vent on the transmission.
    I wonder if they have a machine that pumps the fluid through a nozzle. Then they set it to 6.5 quarts by mistake, pump it, fluid gushes out of the vent all over the engine and inverter and they quickly put the fill bolt back on? If the car was on ramps they wouldn't see all the oil sprayed on the engine and inverter.
    I would keep an eye on the bottom of your transmission for leaks. If pressure built up a seal might have blown, an o-ring. Other than that it might not have hurt anything.
    I can see with that much fluid in the tranny - the oil pump having a hard time moving fluid. It is a low pressure pump - 0.4 PSI is typical. I believe it relies on gravity for most of the circulation? If your trans overheats again expect a torn o-ring.
    It would help if you were able to hook it up to a scangauge or techstream and observe the tranny temp while you"re driving. I think the transmission is the only possible damage here.
    Best of luck to you!
    #35 mjoo, Feb 17, 2017
    Merkey likes this.
  16. Mendel Leisk
    40,484
    I think it'd be interesting, to be a fly on the wall, in the service department, when you're not there. They've screwed up royally, and now are covering up. Reminds me of the last time I got a "professional" brake bleed procedure done...
    Whatever the outcome, contact corporate Toyota. And let the dealership know.
    bisco and jerrymildred like this.
  17. JC91006
    16,656
    8,506
    Sounds like they've never done this service and had a tech that came from jiffy lube do it. He flushed the system lol
    Mendel Leisk and Aaron Vitolins like this.
  18. liquidtenmillion
    261
    194
    Easley, SC
    I like this theory but there was no fluid in the engine compartment when I picked the car up, I always check before I leave a "mechanic". The first sign of transmission fluid was the next day when I drove it at normal speed and got the overheat message.
    I have connected a scan gauge and the temps seem normal, inverter at 136F max and mg1/2 at 150F max. During a 30 min drive.
  19. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    I'm extremely sorry to read about your experience, and hope everything gets resolved to your satisfaction. Unfortunately I've concluded that bringing my cars back to their dealerships have usually resulted in disappointment, and occasionally nightmares. I've seen dealerships make mistakes and cover them up.
    If there's any take away from this, it's that dealership service is hit or miss at best. The solution is to find a local mechanic who owns their own private service shop (not a chain service). This will be someone who has fostered and earned the trust of local patrons, and doesn't just care about their job, but cares about their business and reputation.
    I've been fortunate to have a local mechanic who I've patronized for all of my vehicles for nearly thirty years now. They're so good that I've never had to bring any of my cars back to their dealerships for anything, except the occasional recall.
    Please continue to keep us posted on this issue and how well Toyota does to satisfy all of your concerns.
  20. Fred_H
    Fred_H Misoversimplifier
    558
    481
    28
    Germany
    It sounds to me like they drained only the excess transmission fluid, and left the rest of the possibly overheated fluid in the transaxle.
    It might be still OK, but there is only one way to be absolutely sure that the transmission has good oil: Put in fresh oil ASAP!
