Is the Prius Prime right for me?
Discussion in 'Prime Main Forum (2017-2022)' started by xdriv3, Feb 18, 2017.
  1. Tideland Prius
    16,508
    Except that it's potentially cheaper to buy with the US federal and state credits.
    The Prius Two starts at $24,685. The Prius Prime Plus starts at $27,100. With just the federal $4,500, it's down to $22,600 equivalent cost. Add in the NY state incentive and it's just about the same as a mid-range Corolla. And it has more features than the base Prius (like standard dual-stage heated front seats, LED indicators and a 7" LCD with Entune Premium Audio w/ nav versus the Prius Two's 6.1" Entune Audio)
    heiwa and Mendel Leisk like this.
    51,567
    all depends on local discounts.
  3. drash
    drash Senior Member
    2,555
    1,297
    Upstate NY
    Supposedly it's a $2,000 rebate, but hasn't been implemented yet. NYSERDA has until this April 15th to implement it.
    Unsupervised!
  4. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    I have a similar commute -- 90 miles.
    In your case, the first 25 miles will be EV and the 75 miles remainder at ~ 55 mpg, or more if you drive under 70 mph. So the 100 miles will use 75/55 = 1.36 gallons. Compare that to the 4 gallons you consume today.
  5. Pdxprimeguy
    Pdxprimeguy Member
    Portland
    I save over $200 a month in gas now days vs my 19 mpg SUV. I don't miss my SUV too much. And I love the adaptive cruise control for my long trips.
    jerrymildred likes this.
  6. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    FWIW, in our case, the difference in mileage against our current car, a Gen-2 Prius, while not insignificant, is not a big factor. We're getting a P.Prime due to a combination of factors, especially: My wife is working on getting her driver's license, so we need a second car ("new first" car actually), our Gen-2 is at over 126Kmiles, I'm now driving ~40 miles round-trip to work which will clobber the Gen-2's remain lifespan in no time, I like driving on electric a lot more than ICEs, and with the additional miles to/from work, the chances of me getting into a wreck go up, so I really want all these new safety features.
    iPhone ? Pro
    jerrymildred and bwilson4web like this.
  7. xdriv3
    xdriv3 Junior Member
    NY
    Looks like it's official. This starts beginning of April!
    iPhone ?
  8. MikeDee
    MikeDee Senior Member
    1,572
    596
    San Francisco Bay Area
    The thing you should ask is if you have (or will have) access to cheap power. If not, get the liftback because it will cost you more to plug in than to gas up because the Prius gets such good gas mileage. Seriously, do some analysis on your power bill and rate options. If you are on a tiered rate schedule, plugging in will probably put you into the next higher tier. For me, that was a brutal $.40/kwh. I then installed solar, but probably would have switched to an EV time of use schedule if I didn't, but that would have upped my power costs during the day but would have been better than the tiered schedule. Anyway, look for one or more threads on this. Also, with the Prime, you give up the 5th seating position, spare tire, rear wiper, and some luggage space over the liftback.
    #28 MikeDee, Mar 5, 2017
  9. mr88cet
    2,313
    1,335
    Austin, TX
    That's a very reasonable suggestion. In my case, even in the second tier, it's still slightly cheaper, but that's before Austin's $50/year charging program around town, after which it's … about half the cost of gas.
    Truthfully though, I want to go EV as much as possible simply because I've rather gotten to dislike ICEs: they're heavy, complicated, noisy, high-maintenance...
    iPhone ? Pro
