12v Power Terminal Cover (fuse box)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lengz, Feb 19, 2017.
  1. Mendel Leisk
    40,502
    Yeah I was thinking it would pull up-and-off of that hinge. Doesn't make a lot of sense, but that's where I was going. I'll try again: really want to hook up a CTEK quick-connect cord.
    And yes: if and when I get the cover off; I'll disconnect battery lead before doing anything else.
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,522
    1,619
    Bay Area
    I should make this a video so it'll be easier to see where to press and remove it from. :)
    Mendel Leisk and Raytheeagle like this.
  3. saltdiscus
    saltdiscus Member
    198
    89
    US
    Yes plz only video can solve this problem.
    NutzAboutBolts likes this.
  4. Mendel Leisk
    40,502
    Yeah baby:
    Still had to coerce and cajole: FINALLY the whole contraption pulled up, on the hinge, about 1/2", and was then easily rotatable on that hinge.
    I will take a good look at the tabs before pushing it back down, to determine which direction releases them, for next time.
  5. NutzAboutBolts
    1,522
    1,619
    Bay Area
    Here's the video like I promise, a simple video lol
    bisco, TheTewks, knix6 and 7 others like this.
  6. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    Nice job! (…it's different on my 2009 Gen II - and the plastic cover is RED! )
  7. NutzAboutBolts
    1,522
    1,619
    Bay Area
    I also have that, but its on the upper side, this terminal is probably what powers the fuse box I guess... since it's a thick wire,
  8. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Good simple video. Maybe @Tideland Prius couod add it to your sticky thread:).
    Any other planned or unplanned videos in the works?
  9. Mendel Leisk
    40,502
    I was thinking the same thing as mentioned in the video, that the central recess with clips is for a (missing) fuse removal tool.
    I managed to get my CTEK quick-connect installed. Had to cut the bulky plastic shoulder off the positive spade connector, other wise the plastic cover was hitting, wouldn't close.
  10. xliderider
    xliderider Senior Member
    8,040
    3,212
    Honolulu, HI
    That's my understanding as well, a low gauge wire connecting the positive battery terminal to the fusebox.
  11. NutzAboutBolts
    1,522
    1,619
    Bay Area
    Not that I know now I of yet... my Prius is too clean and hasn't cause me any problems yet :( Andy the brakes are still good. Maybe I'll do a wiper inserts video and battery video?
    Raytheeagle likes this.
  12. WilDavis
    2,493
    2,154
    49
  13. Mendel Leisk
    40,502
    Man, that's a walk-in-the-park to access! How we "progress"...
    For determining a good ground point, a mulitmeter, preferably with with a continuity setting with beep, is really handy. I found not all bolts were grounded, not sure how or why. I hooked up one lead to my tried-and-true point on the engine itself, then tested various bolts with the other probe.
  14. WilDavis
    2,493
    2,154
    49
    …I grounded mine to the 10mm bolt on right (…part of hood backet - I scraped the paint off and checked with meter before installing!)
  15. NutzAboutBolts
    1,522
    1,619
    Bay Area
    A test light is much faster to test for ground than a multi meter because it lights up if there's power, it's the best tool to check for burnt fuse quickly as well. You can ground the test light to the hood latch by the front bumper.
    #35 NutzAboutBolts, Feb 23, 2017
  16. Tideland Prius
    16,435
    Where was this video when I was installing my foglight?!? :eek:
    I did exactly what you said noobs would do - pry the fuse removal tool thingy, until I figured it out.
    TheTewks and Raytheeagle like this.
  17. NutzAboutBolts
    1,522
    1,619
    Bay Area
    :ROFLMAO::ROFLMAO::ROFLMAO: Sorry about that Tideland! We all have our blond moments when doing things :LOL:
    Tideland Prius and Raytheeagle like this.
  18. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    I see #22 just got added to the sticky thread:).
    Thanks for your support(y).
  19. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    At least some moments stay at the blond level.
    Sometimes mine delve into the "Senior moment" pool:sick:.
  20. saltdiscus
    saltdiscus Member
    198
    89
    US
    Finally I did mine too but I always thought the middle plastic was the problem.thank you .
