Chirps multiple times as I approach or walk away from car
Discussion in 'Gen 3 Prius Technical Discussion' started by timengtimeng, Feb 11, 2017.
  1. timengtimeng
    timengtimeng Junior Member
    california
    2013. Key is in my pocket. Does not happen every time, but started happening a week ago and has happened 5 times now. Definitely there is no other key in car.
    It has happened when I come out of work and get within about thirty feet of car; it chirps and the yellow outside lights flash off and on until I get in car.
    Has also happened twice after I park and turn off car- multiple beeps and flashing lights until I get around fifty feet away from the car.
  2. MikeDee
    MikeDee Senior Member
    1,578
    597
    San Francisco Bay Area
    Don't know for sure, but are you sure you turned the car off? Headlights left on?
  3. AzWxGuy
    AzWxGuy Weather Guy
    1,051
    536
    Tucson, AZ
    2021 Prius
    If there is one thing you can glean from the numerous threads on strange electrical behavior, it is to check that little 12V battery first thing. Four years isn't especially young in lead-acid battery life.
