For my tax return: Can I find my 2016 beginning & ending odometer readings?
Discussion in 'Prius c Fuel Economy' started by davide, Apr 6, 2017.
  1. davide
    davide Junior Member
    86
    suburban Detroit
    I didn't think to keep mileage records (as we know, our Prius Cs barely sip gasoline!) when I drove an elderly customer to his appointments in 2016---for my "business expense". Is there a way I can find in the dashboard "computer" my beginning & ending odometer readings for 2016 (i.e., from January 1 through December 31)?
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  3. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    I'm not aware of any way to do this. You may have to simply estimate using the average miles per trip times the number of trips.
  4. jscoot
    jscoot Junior Member
    25
    PDX
    Little late, but... keep in mind that deducting all of your mileage for the year is a no-go unless you ONLY drove the car for your elderly client's trips, and even then the miles from your home to his place and back would generally not be deductible.
