2010 Prius Engine Replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by fopoku2k2, Feb 20, 2017.
  1. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    great help you guys. I feel like I am almost at the end of the tunnel. OK so I was able to get rid of the old codes with all your help
    unfortunately I have some new ones.
    P0A2D
    P0A40
    P0A41
    find scan image attached
    #21 fopoku2k2, Mar 22, 2017
  2. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
  3. bisco
    51,012
    was it the orange safety plug?
    Raytheeagle likes this.
  4. Mendel Leisk
    40,457
    To help my poor 'ol myopic eyes:
  5. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    yes sir
  6. epoch_time
    epoch_time Active Member
    234
    109
    las vegas
    Those code indicate drive motor A. might not be pluged in properly to the main hybrid ecu.
    Like maybe they forgot a plugin to the transaxle drive motor. Or possibly damaged one of the electrical connections to the transaxle drive motor A.
    If there telling you have bad battery cells. You should ask to see the battery report that shows all battery cell voltages.
    You should ask them to charge the high voltage battery. all dealers should have the required charger.
    Because the battery started the car before you parked it indicated it may still have life if recharged.
    But none of the codes you have submitted to prius chat indicate bad battery cells.
    Jetlifekc and m.wynn like this.
  7. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    Ping your cable for motor A and motor A resistance.........go in opposed direction eliminating one by one then check big hybrid pack
  8. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    so i got my car back from the shop. everything seem to be working so far. thank you guys for all your efforts.
    apparently one of the connectors was faulty. had a bad wire, so mechanic had to replace it.
    sucks I have to continue the mileage from the old engine. wish i cld pick up from the new engines mileage . . . . sucks!!!!!
  9. Mendel Leisk
    40,457
    Sounds like things are on the up-and-up. (y)
  10. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    yeap. thanks to the wonderful people of PriusChat.com
    now i can start pimping my prius like a #boss . . . :):)
    WolfpackBill, DonDNH and Mendel Leisk like this.
  11. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    sorry to bug you guys again, but I am having some strange issues with my stereo. I am not sure if it is linked with the engine swap.
    the display sometimes acts funny with some strange tree like indications on it. this morning the display was actually off but i could still listen to music.
    anybody knows whats going on or do I have to consult an "exorcist "
  12. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    After using my newly engine changed Prius for about 3 weeks. I got these a check hybrid system error this afternoon whilst on the highway. These are the scan codes.
    OBD2 - confirmed:
    P0A7A - Generator Inverter Performance
    OBD2 - confirmed:
    P0A94 - DC/DC Converter Performance
    OBD2 - pending:
    OBD2 - permanent:
    OBD2 - permanent:
    Any idea what the problem is?
  13. Samprocat
    491
    297
    Lincoln, NE
    Check DC/DC connection from hybrid pack
    Coolant pump ??
    Second choice is most likely
    12v battery health
  14. Samprocat
    491
    297
    Lincoln, NE
  15. Samprocat
    491
    297
    Lincoln, NE
    Conditions to generator and check generator winding resistance....make sure all connection are good before doing this.....I'm not sure if you have this expensive tool ....
  16. Samprocat
    491
    297
    Lincoln, NE
    Best approach is to talk to the mechanic that was doing replacment and find out all connectors that was disconnected and recheck all
  17. m.wynn
    m.wynn Senior Member
    684
    1,229
    Queensbury, NY
    Head for a dealer.
    P0A94 - likely IPM failure (intelligent power module - inverter), warrantied for 15 years, unlimited mileage. With your high mileage vehicle it will be interesting to see if they try to squirm some loophole.
  18. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    looks like I need a new inverter. anybody knows the part number for the 2010 inverter.
    also I read somewhere that the 2010 inverter is not very strong/durable. any idea if i could install another year inverter in my 2010?
    Thank you for reading
  19. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
