  1. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    I have these, and IMO the tubes don't provide enough light during the day to be too noticeable. The brake lights are plenty bright enough though.
  2. pnkp63
    pnkp63 Active Member
    56
    373
  3. pnkp63
    56
    373
    I think Masta D has a secret formula to resolve this issue but you have to run it by him, LED SIFU, just to be sure
    sfv41901 likes this.
  4. TheChip
    TheChip Senior Member
    388
    1,210
    Misissippi
    They seem bright enough to me!
    I also added these eyelids...they don't quite fit right. The headlights have a lip near the hood that causes them to not sit all the way on the headlight :\
    Tracksyde, HelloHybrid, Jk818 and 5 others like this.
  5. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    KT Tape is an elastic sports and fitness tape designed for musle, ligiment and tendon pain relief and support. One side is cotton and the adhesive side is designed to stick through showers, humidity, etc. You can find it in the first aid aisle.
    huggy621 likes this.
  6. huggy621
    huggy621 Junior Member
    24
    Los Angeles County
    Cool thanks , good to know.
    iPhone ?
  7. J Buck
    J Buck New Member
    Gettysburg, PA
    2016 Prius c
  8. Steves895
    Steves895 Member
    48
    68
    Concord, NC
    It just peeled right off for me, just amazing how it does that.
    J Buck likes this.
  9. 2ZR JDM
    2ZR JDM Active Member
    106
    142
    Redondo Beach
  10. HelloHybrid
    482
    1,483
    We discussed changing out the stock LEDs for some ozniums but never got around to it. I'm a little more interested in those CrystalEye's that look like the G's tails nowadays, otherwise I'd consider doing the retrofit a little more.
    Your tubes are definitely brighter than mine, but yours also look different. Not sure if its your camera adding a lot of contrast, but yours are extremely dark in comparison. Mine look a lot closer to @Burna J 's and I can see my reflectors If i stand at the same angle in your pic.
    Dylan Doxey likes this.
  11. JoshM
    JoshM Member
    37
    Mid TN
    These are slick.
  12. pnkp63
    56
    373
    Crystaleye G's are what Masta Sean, TK Rocket and myself are using
  13. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Here's what I did today
    iPhone ?
  14. pnkp63
    56
    373
  15. TheChip
    388
    1,210
    Misissippi
    Prius Plus Sway bar installed on my 2010.
    Huge difference in cornering, there is very little lean around corners even at high speed. The trade off seems to be a bit bumpier on some of the worse roads in my area.
    10/10 highly recommend installing it if you haven't already, it's a huge improvement.
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    A Rear Sway Bar is the best suspension bang for ur $$$
    iPhone ?
    Dylan Doxey, TheChip and HelloHybrid like this.
  17. SubCode
    SubCode Senior Member
    739
    1,341
    if that is yours..where were you...lost at the crest?
  18. 2ZR JDM
    106
    142
    Redondo Beach
    I used my Prius as stage lighting in a short video I made the other night.
    Justdidit, Burna J, apt5020 and 2 others like this.
  19. huggy621
    24
    Los Angeles County
    You must have a sweet ride sir.
    iPhone ?
  20. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Those fogs are bright! u ever get highbeamed? Reminds me when I put HID in my OEM fogs...
