"Auto-Leveling" Headlights
Discussion in 'Prime Main Forum (2017-2022)' started by mr88cet, Apr 23, 2017.
  1. mr88cet
    mr88cet Senior Member
    2,311
    1,335
    Austin, TX
    I just saw a new review that described the P.Prime's headlights as "auto-leveling," meaning that as you go over hills, or just high- and low-spots in the road, they keep the beam of the headlights horizontal.
    Is that in the US version, or is it part of the EU AHS feature? How well does it work?
    Lots of little tidbits of info I hadn't heard before, like this Auto-leveling feature, mentioned in passing in this review:
    iPhone ? Pro
    #1 mr88cet, Apr 23, 2017
  2. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    I wondered about that as well. Hard to check when driving.
  3. Mendel Leisk
    40,482
    Our 3rd gen with LED's has levelling system. Not sure how similar it is, but I surmise ours just deals with loading changes, say a lot of stuff in the hatch.
    It's heady stuff though: are you picturing an Abrams tank, headed over hiil'n dale with its barrel never wavering from horizontal? :)
  4. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    I believe it just initially adjusts based on the weight of the load in back. I don't think it constantly adjusts to adapt to road changes. Hey - I could be wrong! I've been wrong before, and don't plan on stopping now... :p
  5. fuzzy1
    10,335
    That is what I thought too, adjusting for load changes only.
    Because it cannot know the basic overall terrain, in certain conditions a road adjusting system would produce wickedly bad results. When the terrain has a true slope, the headlights simply are not supposed to be horizontal. That would produce a too-short pattern on the uphill, and blind oncoming drivers on the downhill.
    #5 fuzzy1, Apr 23, 2017
  6. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    That is for EU version...
    In NA we get only automatic High Beam
  7. Samprocat
    491
    297
    Lincoln, NE
    My BMW have ability to adjust for weight and it will adjust also to angle of front wheels
  8. Mendel Leisk
    40,482
    I like that Abram Tank analogy though, a lot. :)
  9. Trollbait
    12,318
    The gen2 had auto leveling for loads with the HIDs. I think other markets had a manual dial for it.
    Are you sure this isn't also just for loads? Wouldn't it try to point the lights down while going up a long hill otherwise, or try to light up the sky while going down?
  10. William Redoubt
    William Redoubt Senior Member
    1,215
    1,165
    Coronado Island, California
    The Gen 4 does not have auto adjusting headlights. I installed Firestone airbags to adjust the rear ride height based on load.
  11. Tideland Prius
    16,431
    auto-levelling is standard on US vehicles. It has a load sensor in the rear suspension to determine if you're carrying something heavy (full load of passengers or heavy cargo).
    jrodz09 likes this.
  12. Krzysiek_KTA
    Krzysiek_KTA Active Member
    159
    125
    Houston
    Mine obviously failed and I was trying to find the exact location of that sensor. Checked both rear wheel wells and could not find it.
    Any Guidance whereabouts in rear suspension that sensor is would be appreciated.
    Kris
  13. Tideland Prius
    16,431
    This is the best I can find. It's number 7.
    albus likes this.
  14. Krzysiek_KTA
    159
    125
    Houston
    It tells me it is more hidden than I suspected. I created separate post so someone else had found it and can share how it looks like. Many Thanks
    Kris
  15. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Try the left rear. Look for the wiring either inside trailing arm forward of wheel or on top of upper control arm to the inside of the shock. Maybe shows in one of these pictures. How To: Install coilovers on a Prius Prime | PriusChat
    $200 part! One of the coilover lowering kits I looked at had an extension bracket for this part.
  16. Mark57
    2,945
    2,738
    OK
    It seems like this would be easy to test. In the dark, turn on the head lights aimed at a wall or garage door at a distance so you can easily see the top of the beam horizontal line. Mark it with blue painters tape. Get one or two people to sit or push down on the rear cargo area and see if the head lights adjust downward.
    Tideland Prius likes this.
  17. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    I remember the the spring on the gen2auto leveler, and how it rusts, my prime advanced quickly adjusts the headlights when I top hills, nano second control.
  18. Solar Powered Prime
    Solar Powered Prime Junior Member
    Pittsburgh
    2018 Prius Prime
    I am curious about this also. Recently, we were driving on a rural road and the headlights were pointing so low, we had to turn on the high beams, just to be able to see the road ahead. We took it to the dealer and they said there is no such capability on our Prime. Would love to know more.
  19. fuzzy1
    10,335
