Partly working key fob
Discussion in 'Gen 2 Prius Technical Discussion' started by Oakman, Apr 6, 2017.
Tags:
  1. Oakman
    Oakman Junior Member
    Virginia
    I have one key fob that works fine.
    The second one's case broke, so I bought a new case, and I put the little metal thing and other stuff into the case. It worked fine. Doing everything like the first one.
    But now the second one stopped working, partly. I can push its buttons to unlock and lock, but the car doesnt know that I am near it, and it will only start if I put the fob into the slot.
    I replaced the batteries on the fobs to be sure.
    Any ideas on next steps to diagnose it?
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Unfortunately, no one has responded yet, but most likely you accidentally pressed the "key" button under your steering wheel near where your knee would be. The button must be in the out position for the FOB to work completely. The lock/unlock will work regardless of button position.
  3. Oakman
    Virginia
    Thanks for your attempt, but one fob works and the other doesnt, that is, doesnt work anymore. My next thought was to do the chicken dance with it.
  4. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Wow, I totally misread your post. Sry about that.
  5. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Try doing the long chicken dance on it. I had a fob that forgot the proximity/key functions, and reregistering it worked. If that doesn't work, it's time to get another fob. You really want at least two working fobs so that when you lose one you still have one to use in registering another. Getting to zero working fobs sucks big time.
    wjtracy likes this.
