Hybrid battery and ECU failed at same time?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by themadbluebird, Apr 28, 2017.
  1. themadbluebird
    themadbluebird Junior Member
    Grand Rapids, MI
    The hybrid battery in my 2007 Prius with 165,000 miles is showing all the signs of going out (discharging very quickly, red triangle, etc.) I took it in to a Toyota dealer and had the DTC codes read. They informed me that it was giving codes to replace the hybrid battery AND the ECU. They quoted me about $3,000 for a new battery and around $1,000 for a new ECU.
    I am a little suspicious that both the hybrid battery and the ECU would go out at the same time, so I am hesitant to replace both of them. While I am just a layman, it seems more probable to me that one of them is bad and is causing the other to act oddly.
    Anyone else had a similar diagnosis in the past?
    Here are the codes that came out:
    P0607
    P3000
    P0A80
    C0200
    C1235
    C2300
    C2318
    B1271
  2. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Check the 12 V battery.
  3. themadbluebird
    Grand Rapids, MI
    Thanks for the tip. I checked the 12V battery and it was indeed low. It hadn't been changed for at least the 4 years I have owned the car, so not surprising. I replaced it today with a new one. Having the 12V battery disconnected reset the DTC codes, but they came back on shortly after.
    I've now realized that I will have to go back to the dealer for another $120 diagnosis to see if that made any difference, so instead I have ordered a mini VCI and will re-assess when that arrives in a few days.
  4. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Which DTCs came back?
