Has anyone set off the VSC?
Discussion in 'Gen 2 Prius Main Forum' started by DocVijay, Jun 26, 2006.
  1. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    Just wondering if anyone has set off their VSC while driving? If you have, what were you doing at the time? I see the Traction Control light flashing at least a dozen times a day, but I have never seen (or felt) the VSC system activate. I guess I need to drive much harder than I already am to get it to go off. Just curious.
  2. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    Only time I noticed it, I was taking an on-ramp too fast in the rain, and the light on the dash caught my attention for the moment it lit.
    Nothing else memorable about the incident, so I guess it did its job well...
  3. tmorrowus
    tmorrowus Member
    514
    In three years of driving I only set off VSC once, when I was cornering on a wet road. It felt like the brake was being applied strongly but very briefly on one of the wheels.
    Of course I've set off traction control many times.
  4. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I've only seen it come on when going over large bumps. I've never felt it do anything other than kill the engine. When I got my car back in January we never got enough snow to try it out. I'm hoping to try it out this winter if we get some snow. That is I hope to try it out in a empty parking lot and not out on the road somewhere.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    Couple times when trying to maintain momentum on my gravel road turning into my driveway and a couple times on snow just 'testing'.
    There's a triple beep and some very quick changes in the steering and some power very quickly adjusting the wheels and then it's over in less than a second.
    Never had it activate during "real driving"--ie highway speed or under unexpected conditions.
  6. snowman83
    snowman83 New Member
    29
    Baltimore, Maryland, USA
    The roads around here are sometimes in fairly poor condition, and there are many things like drainage grates in the middle of the road that take away the car's traction. I've had the VSC activate probably about 5 or 6 times, usually hitting one of said obstacles in the rain. It's very disconcerting at first, as it jerks the car by taking away your ability to accelerate, but I guess if it were ever a situation where the car were really slipping, it would be helpful.
  7. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    <div class='quotetop'>QUOTE(theforce @ Jun 26 2006, 01:03 PM) [snapback]276855[/snapback]</div>
    I'm pretty sure you're refering to the Traction Control and not the VSC. I've definately noticed my Traction Control coming on when I go over a big bump from time to time. As Evan said, the VSC is aparently quite noticiable when it comes on, since the car beeps at you.
  8. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    I just had to try it out the first Prius winter (Nov. 2004)...in an empty parking lot...new snow, maybe 3 inches, a few tracks which meant some flattened icy areas. Factory Integrity tires, maybe 5,000 miles. NOT the greatest traction tire in snow/ice!
    I got up to about 25 MPH and swerved fairly hard to the left and the car beeped at me (maybe three quick beeps, like the "no, I can't let u go into forced EV mode"). I felt a power loss and the car slowed and definitely stopped moving (sliding) to the left. Still moving forward. I didn't feel braking per se but then the power loss slowed me and probably was a combo of braking and the power loss. My foot remained on the accelerator and I continued to drive forward.
    I tried this several times both to the right and left and could not get the thing to tailspin or donut or spin. It always beeped at me.
    Only sometimes while doing this would I get beeps AND the Traction Contol light (the 'slippery car icon') to flash on the dash. The TRAC icon always flashed when getting up to speed during my "tests". It doesn't let u spin the tires getting going, that's for sure.
    It seems the natural tendancy in a skid is to let up on the accelerator and then attempt to brake to slow down. Well, this system does that in a blink of an eye, before I could react. Didn't seem like the steering wheel was controlled, meaning the wheel didn't turn on it's own, but I wasn't paying attention if the wheel was harder or easier to turn (as I've read is a part of the VSC?)
    All in all I thought the system responded well to all I was doing to drive out of control. I'm glad the system is there if I hit black ice and can't respond fast enough or somehow do the wrong thing to bring things under control.
    Cheers,
    Curt.
    PS I have snow tires now but didn't test them in the same manner as the originals. Maybe next winter...'cause I can. I did experience less wheel spins with better traction tires.
  9. rufaro
    rufaro WeePoo, Gen II
    2,867
    72
    Lost Angeles
    Next question...Do all '06s have traction control and what does it do? :blink:
  10. 200Volts
    200Volts Member
    434
    45
    Northern CA
    Yes,
    2 lane road, 45 mph and 90 degree turn. What was that plastic can on the shoulder I just passed?
    Oh crud..... VSC kept me from sliding off the road.
    I turned around and looked at the can... transmission fluid-fell off the back of some farmer's truck and was covering half the lane. So two of my tires went through it-and kicked it up on the lower side of the car and wheel wells.
  11. finman
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    yes. standard on all 3rd gen HSD Prii ('04 and up). Not sure on the classic ('00-'03).
    It eliminates excessive wheel spin when on a slick (ice, snow or even wet) or loose (gravel?) surface.
    Basically cuts power that is spinning the wheels and allows the tire to try to catch traction at a slower speed.
    Cheers,
    Curt.
  12. rufaro
    2,867
    72
    Lost Angeles
    <div class='quotetop'>QUOTE(finman @ Jun 26 2006, 10:31 AM) [snapback]276877[/snapback]</div>
    So traction control will kick in before I suddenly need to try to figure out how those dang antilock brakes work, is the idea? :blink:
  13. TheForce
    3,461
    537
    Wheelersburg, Ohio
    <div class='quotetop'>QUOTE(Betelgeuse @ Jun 26 2006, 01:14 PM) [snapback]276867[/snapback]</div>
    Well I have had both happen. Loss of power one time and beeping the other. I think it happend when I was pulling out on a gravel area and turning at the same time.
  14. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(Rufaro @ Jun 26 2006, 01:28 PM) [snapback]276874[/snapback]</div>
    Traction Control - prevents you from spinning your tires under low grip conditions.
    Vehicle Stability Control (VSC) - prevents you from spinning your car in low grip conditions.
    THe TC works by limiting power on acceleration. It;s a basic system that monitors speed differnetial in the wheels. If one wheel starts to spin much faster than the others, it cuts power in order to get the wheel to slow. It keeps you from spinning your wheels in rain or snow.
    The VSC system is much more complex, with all kinds of sensors that monitor what a car is doing and compares it to what it should be doing. It can cut power and apply brakes in varying degrees to any of the wheels that need it in order to prevent the car from loosing control. It keeps the car going in a line and from going into a spin. This is the technology the IIHS said could save 10,000 lives each year if it became standard on all cars.
    Most people have experienced the TC system. It is a fairly aggressive system, and quickly cuts power when the slightest amount of wheels spin is detected.
    THe VSC is much harder to have activate, as it takes a situation where you would pretty much loose control of the car. I've never experienced it, and was wondering what it was like and what indications it gave. Now I know, three beeps and light the icon.
    Thanks everyone for your input. THe VSC is not something I really WANT to expereince in my daily driving. I push limits, but not to where they are dangerous. I was more curious in that I'd like to tak emy Prius autocrossing, and was wondering what might happen there. That is a "safe" situation where activating the system would be OK (and likely!).
  15. Tideland Prius
    16,431
    I've never had VSC come on under normal driving. It only comes on when I intentionally do something to activate it (e.g. purposefully yanking the steering wheel hard in snowy conditions to induce understeer). I find that if you can learn how it works (and reacts), you can take better advantage of it. If not, you'll try to outsmart the VSC and VSC just reacts to what you do and you'll end up crashing like some fellow here that complained VSC make him crash into a snowbank and claimed he'd be better off without VSC.
    After much discussion, he agreed to learn and feel how VSC works.
  16. wilco
    wilco New Member
    402
    I've set the VSC off a few times on wet pavement.
    There's a cloverleaf overpass near where I work. If you take it fast, when wet, the VSC will sometimes activate as you cross the expansion joints in the concrete.
    There is a railway track crossing near where I used to live that was about a hundred feet from a traffic light. When braking across the tracks on a wet day the VSC would momentarily activate, and when accelerating across the tracks (going the other direction) the TC would activate.
  17. nmrickie
    nmrickie Member
    200
    New Mexico
    I set off the VSC a few months ago in the snow. I was driving (I thought) slowly through an "s" curve, and as I exited the first curve the rear of the car started fishtailing. Instead of the quick fishtailing I had experienced in my Camry, this time the rear-end drifted slowly towards the left, over-corrected itself and then drifted toward the right. The VSC was beeping like crazy the whole time. At one point I was in the other lane, and after correcting itself I almost left the roadway to the right.
    I could definitely feel the VSC kicking in, and it probably made the difference between temporarily losing control and totally losing control. I learned two lessons: 1) get better tires before next winter, and 2) VSC helps, but it's not foolproof. Next time I'll drive a lot slower.
  18. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    I think when VSC starts to beep, it means it's not able to do it's job. When VSC kicks in you won't really get an indicator. Extensive gravel driving gave me some better insight. I've noticed that taking sharp curves with wet roads tends to kick in the VSC. I can feel the car start to understeer, and VSC will take care of it... no beeps. I've gotten VSC to beep at me last week when I tried a hard turn on a wet road and it wasn't able to correct.
  19. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    <div class='quotetop'>QUOTE(DocVijay @ Jun 26 2006, 01:44 PM) [snapback]276889[/snapback]</div>
    I wish you could turn it off. IMO the way it is implemented it is not safe. I hit a bit of gravel as I was pulling off from a stop to cross over the the other side of a heavily traveled four lane road. I reached the death defying speed of about two miles per hour and it cut power leaving me across two lanes of oncoming traffic for a second or two. Not good IMO.
  20. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    <div class='quotetop'>QUOTE(Betelgeuse @ Jun 26 2006, 10:14 AM) [snapback]276867[/snapback]</div>
    <div class='quotetop'>QUOTE(Presto @ Jun 26 2006, 12:11 PM) [snapback]276939[/snapback]</div>
    So which is it? Beep or no beep? The lights flash so quickly I am never sure. Potholes and such irregularities do set off the Traction Control. Even that feels weird, and it's over with before I can even adjust.
