hose size for pcv?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by StarCaller, May 4, 2017.
  1. StarCaller
    StarCaller Senior Member
    1,271
    723
    Cedar Crest, NM, USA
    I'm thinking about getting a catch can & really don't want to figure in the middle of the work that I have a hose with the wrong diameter.
    so nebody knows what's the inside diameter (11/32, 15/32, 19/32 or whatever mm's) of the original pcv hose?
  2. ChapmanF
    17,185
    No, I don't know the diameter. But if you're driving a Gen 3, don't forget that the funky labyrinthine wart on the side of the block, that the PCV valve screws into, is already an oil separator.
    -Chap
  3. StarCaller
    1,271
    723
    this one where the guy points at I assume.
    ne idea how it looks inside & where the trapped oil would go?
  4. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    That's it from under the Prius. It ultimately ends up under the throttle body. When you pull the throttle body or actuate the butterfly valve, you'll see the oil accumulation there.
    Not sure on hose size though:(.
  5. StarCaller
    1,271
    723
    I meant where the accumulated oil in the 'labyrinth' will go.
    SCH-I535 ?
  6. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Love that oil catch container idea (that picture was quite convincing to say the least), still not sure where to will route it, and then there is the need to find the right container.
    The attached PDF is what got me started on my PCV today, though naturally a different path (and much harness wrangling) was had when all was said and done (quite interesting how this PDF jumps from sure no problem to... Wth) o_O
    Both sides looked quite clean and rattled freely, it offered little resistance when blown in one direction. Not sure if it was still usable after 149k miles, but i squirted both sides with throttle body cleaner (nothing came out) and called it new again. Did I do this because of oil lounging in my intake, and with high hopes of breaking 50mpg, YES.. will either of those happen after cleaning an already new looking (though still probably worn out) PCV, doubtful as best.
    The only thing that would've made the whole process easier is if I had the right tools for the job (either a long handled 19mm 12pt wrench or a ratcheting 19mm wrench, please let everyone know if you find a socket/ratchet combo that works). It wasn't that hard to get out once you have all the extras out of the way and turning, then the fingers took over from there (my PCV did have stuff on the threads).
    Now had my engine compartment been spotless like Dr. @Rebound 's there would've been no reason to wash my hands twice, let alone once. Maybe I can save some face and polish up the butterfly and intake the next time I'm in there (just saw @Patrick Wong 's intake image) :whistle:
    #6 SFO, May 5, 2017
  7. ChapmanF
    17,185
    Drains right back into the crankcase. Where else would you want it?
    The way it works is described pretty well in the New Car Features manual.
    -Chap
    Raytheeagle likes this.
  8. Mendel Leisk
    40,460
    I've yet to look at ours, but for an 06 Civic Hybrid, a long-handled 17/19 mm ratcheting wrench (with swivel heads) was the ONLY way I good PCV valve off without intake manifold removal (as instructed in the Shop Manual). Sounds like it might be utile on our Prius too, will see when I get there.
  9. TRUC NGUYEN
    TRUC NGUYEN Junior Member
    2014 Prius Plug-in
  10. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Holy duckets, only $116 :eek: Guess I will be liking that cute little mason jar (looking) setup even more now (y)
  11. TRUC NGUYEN
    2014 Prius Plug-in
    I paid $65 free shipping on Ebay
  12. danlatu
    danlatu Senior Member
    533
    1,361
    maryland
    3/8 inner diameter is correct. Then cut the bigger hose in half from the intake plenum and put a 3/8 coupling on it. Thats what I did to get the catch can/mason jar to work.
    #12 danlatu, May 8, 2017
    StarCaller likes this.
  13. Mendel Leisk
    40,460
    Hose Inside Diameter?
  14. danlatu
    533
    1,361
    maryland
    This one on amazon looks pretty nice. Screen Shot 2017-05-09 at 1.45.50 AM.png
