Fantastic Prime Mileage
Discussion in 'Prime Fuel Economy & EV Range' started by HPrimeAdvanced, Mar 2, 2017.
  1. FA6
    FA6 Member
    45
    150
    I now have just over 1,000 miles on the odo and I reached a max of about 35mile range with EV non hwy driving.
    I have used about 1/8th of the original tank of gas so far.
    I absolutely love the car.
    It is far more sophisticated and "intelligent" than I had ever imagined.
    I get so many compliments and questions.
    Still have not seen another specimen in the wild here is South Texas.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Today May 16, 2017 33.3
    Prius from Dad likes this.
  3. Brad Nunn
    Brad Nunn Junior Member
    Nashville
  4. bisco
    51,846
  5. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Way to go!!
    You cataleptic snail, you!!. I can only manage 36 EV. I guess I must be a track star snail ! (Escargot ).
    Yeah, I heard the joke: I'm going to call my car "S", so I can tell everyone 'look at my S car go!! Har, har, har. It's corn central down here!
    #85 HPrimeAdvanced, May 17, 2017
    Data Daedalus and Brad Nunn like this.
  6. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    So today I went to the gym and charge the Prime, 2 hours, only 13 miles. I definitely did not want to wait around 4 more hours for a full charge. And then it hit me(I'm a little slow) since I had a lot of running around to do, just charge while driving. All of our surface streets are 35 - 45 speed limits. Worked perfect! Arrived home with a 25 mile charge. Since my gasoline is free, it doesn't matter. Still got 45mpg tho.
  7. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    The qualifier at the end made it work: free gasoline, otherwise you ain't savin'!
    Of course if you could access a Level 2 charger, then you're looking at only 2 hours to get your full charge! Time is money!
  8. Andyprius1
    2,327
    859
    Cool CA
    L2 I have at home. But I don't sneeze at L1 potential when its free.
    HPrimeAdvanced likes this.
  9. priuscatprimeguy
    2,730
    2,640
    Today May 18, 2017 33.4 should be short lived because I used A/C today:cry:
  10. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    Banner day for me today! 37.2 miles EV in the AM, 78.1 mpg HV in the PM. Total mpg for the day, after 72 miles, 155.1.:D
  11. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Faaaaarrrrr Out, Dude!!! You're making me look bad, you snail!!
    I think it's hysterical that we grown men are striving to be economical, rather than trying to lay rubber or blow each other's door off!. How times have changed.
  12. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    And I had your Cali weather today to thank for that. 75° AM and 98° PM. ;):whistle: Yes, times have really changed.
    Man that post brought back some great memories! Thanks for that, Pepe Le Prime. (y):D:D
    #92 Prius from Dad, May 18, 2017
  13. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    Man, they're forecasting a heat spell this weekend!! BUMMMMMER! I'm going to be a sweating snail as long as I can to try to stay in the "slugfest" (new connotation!! Har, har) with you guys!
    I think I can, I think I can!!
  14. priuscatprimeguy
    2,730
    2,640
    I used the A/C earlier today and thought my EV mileage would go down. This car never ceases to amaze me:D
    #94 priuscatprimeguy, May 18, 2017
  15. Tideland Prius
    16,549
    Perfect time to test the cabin precondition function!
  16. Chazman62
    Chazman62 Member
    108
    66
    Long Beach, CA
    2020 Prius Prime
    "My EV range is 34 to 35 miles."
    Hmm... how did you calculate that, 6.2 miles/kWh?
    My calculation says 4.97 miles/kWh (=35/(8.8*80%).
  17. Tideland Prius
    16,549
    Because 8.8kWh isn't the actual battery capacity. The true capacity is around 5.6-5.8kWh (with 6.1-6.3kWh shown on your meter due to losses)
    Prodigyplace likes this.
  18. Salamander_King
    Salamander_King Senior Member
    11,016
    8,947
    New England
    You are commenting on very old post by EV-ish, Mar 2, 2017 . As @Tideland Prius commented, the true battery capacity used for a full range of EV is much smaller than 8.8kWh. 5.5kWh is what I use for my calculation to be conservative. I don't want to have false hope on getting better EV range then getting disappointing. BTW, you can check your daily or monthly or lifetime miles/kWh on MID. Daily and Monthly data are in Eco Log, lifetime data is on the Drive Monitor 2, as long as you have not reset the corresponding mpg from the new.
    What is your miles/kWh (total average electricity consumption) on the "Drive Monitor 2" | PriusChat
  19. Chazman62
    Chazman62 Member
    108
    66
    Long Beach, CA
    2020 Prius Prime
    If you look at my equation above, I didn't use the "whole" value of 8.8 kWh to get 4.97 miles/kWh.
    I only used 80% of it which is about 7 kWh.
  20. Salamander_King
    11,016
    8,947
    New England
    That's still too high. You are not charging and discharging entire 8.8kWh of the full capacity of the battery. For longevity purpose, Toyota has programed in such a way to prevent fully charge or fully discharge the battery. So, the full charge from the wall takes only 6.0-6.3kWh by L2, or 6.4-6.8kWh by L1. Of that amount, only 80-90% are actually usable for traction due to conversion loss, making real usable battery charge to be about 5.5kWh.
    6.2 miles/kWh (=35miles/5.645kWh).
    #100 Salamander_King, Jan 22, 2020
    MSantos and Tideland Prius like this.
