2011 prius inverteter Pump wiring issue
Discussion in 'Gen 3 Prius Technical Discussion' started by Terror404, May 19, 2017.
  1. Terror404
    Terror404 Junior Member
    46
    houston, texas
    Hello,
    I had an accident recently and my inverter pump wire plug was damaged, whole bunch of wires were cut in fact.
    I have bough new inverter pump with wire plug and stuff, but now I am having trouble finding which wires and in which sequence go to the pump. Anyone has idea about it? what color wires go from where to where?
    I have doubts that wires should be coming from thick bunch of cables that comes out of the fuse box but I want to be 100% sure before wiring,not to fry the things up.
    p.s. "go to the service" types of advice will not work for me as I have almost restored my car completely and do not what to waste couple of hundred bucks for just stealership telling me where the wires are :)
    [​IMG]images hosting
  2. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    Inverter pump wiring is on the second page...
    Raytheeagle and Terror404 like this.
