Replacing transmission oil
Discussion in 'Gen 2 Prius Main Forum' started by franken1313, May 21, 2017.
  1. franken1313
    franken1313 Member
    216
    26
    US
    I'm trying to replace the transmission oil but I cannot undo the drain screw. Is it ok to use a digital torque wrench?
  2. JC91006
    JC91006 Senior Member
    16,659
    8,509
    A torque wrench is normally used to get a desired amount of torque in tightening something. To loosen, you can use whatever you want
    I find it useful to get a long metal cheater bar/pipe to put over whatever you're using to give you more extension and additional torque, that should help you loosen it
  3. franken1313
    franken1313 Member
    216
    26
    US
    So I'll be ok? I'm worried about breaking the screw still inside the transmission
  4. JC91006
    16,659
    8,509
    It's in there pretty tight, so you'll need a bit of muscle if you're not using a long extension breaker bar. It shouldn't break.
  5. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Don't forget.. lefty loosey, righty tighty.
  6. franken1313
    franken1313 Member
    216
    26
    US
  7. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    (this is why I always advise to open the fill hole before the drain hole, if you drain everything out, THEN discover you can't add more, you will hate yourself)
    jerrymildred likes this.
  8. xliderider
    xliderider Senior Member
    8,040
    3,212
    Honolulu, HI
    A breaker bar should be used to break tight fasteners loose, not a torque wrench. Using the torque wrench risks breaking it, or throwing it out of calibration.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    +1 on the breaker bar. A torque wrench isn't made for that duty and costs a lot more to replace. But you might want to use it for putting the plugs back in. 29 ft/pounds, iirc.
    I changed mine yesterday using a 1/2" drive breaker bar. I didn't need a pipe extension, but both plugs gave a couple good snaps before coming loose. And, @JimboPalmer, that's a really important tip about doing the fill plug first. Next week, we'll see how it goes with wifey's 2007 with 118k miles on it.
    Prodigyplace likes this.
  10. xliderider
    8,040
    3,212
    Honolulu, HI
    I don't know if the Gen 2 is similar, but I found using an extension between the socket and the breaker bar helped gain some clearance to be able to gain leverage on the fill/drain plugs.
  11. jerrymildred
    11,517
    14,137
    Tampa, FL
    Me too. Especially the fill plug, I think.
    xliderider likes this.
  12. Patrick Wong
    18,200
    6,492
    I just want to make sure that what you call the "drain screw" is the correct drain plug.
    The 2G transaxle has a circular drain plug for the ATF with a 10 mm hex hole in the center, hence you need to use a 10 mm hex socket key on a 1/2" breaker bar to remove it.
    The transaxle has another drain plug, closer to the engine, with a hex head intended for a 24 mm socket. That drain plug is for the inverter/transaxle coolant.
    As previously suggested, make sure you have located and can loosen the ATF fill plug on the side of the transaxle facing the radiator (which needs a 24 mm socket) before you remove the ATF drain plug.
    The correct tightening torque is 29 ft.-lb. You may have to exert substantial loosening torque to get the drain plug loose, hence the suggestion that you use a breaker bar at minimum, and ideally extend its length with a length of pipe or some other cheater device to improve your leverage.
  13. franken1313
    franken1313 Member
    216
    26
    US
    Will a torque wrench do 29 ft lb to the left so I can untighten the bolt ?
  14. xliderider
    8,040
    3,212
    Honolulu, HI
    Just because one Can do something, doesn't mean that one Should do something.
    Breaker bars are relatively inexpensive, if you don't want to get one, use a regular ratchet with a cheater (pipe) instead of using your torque wrench.
  15. jerrymildred
    11,517
    14,137
    Tampa, FL
    It may take well over 29 foot pounds to loosen the plug. Mine felt like at least 60.
  16. tvpierce
    tvpierce Senior Member
    951
    880
    Maine
    2013 Prius v wagon
    DO NOT USE THE TORQUE WRENCH -- YOU'RE GOING TO BREAK IT!
    As others have said, you need a breaker bar (or ratchet with extension) and 10mm allen socket. Why do you keep wanting to use the torque wrench?
  17. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    I know, torque wrenches are typically longer and it's tempting to use them as a breaker bar. I'll add my voice to the chorus--don't do it.
    If you do, buy a new torque wrench because you've just created an expensive breaker bar.
  18. jerrymildred
    11,517
    14,137
    Tampa, FL
  19. franken1313
    franken1313 Member
    216
    26
    US
  20. xliderider
    8,040
    3,212
    Honolulu, HI
    Clearance is pretty tight, it is doubtful you'll be able to get a power tool in there.
