What is the weight of our stock 15" rims?
Discussion in 'Gen 2 Prius Main Forum' started by usbseawolf2000, Jun 28, 2006.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    I know our stock tires are 17lbs each. What about the weight for the rims?
    I am shopping for 17" rims and 205/45R17 tires. Anyone knows a light set of rims with the tires? I want something like this.
    The tires for 205/45R17 costs twice as much as 185mm or 195mm. I am willing to spend extra maintainence cost for better performance and styling.
    I now average 52 MPG and I would be happy if I get 50 MPG with these new set of wheels. From reading other threads, the penalty is about 1 to 2 MPG.
    If you have done the research already, please let me know. You can save me a lot of time. Thanks.
    Dennis
  2. brandon
    brandon Member
    771
    Manhattan, KS
    Not a clue, but I bet it's pretty insignificant. I'm guessing it would be like carrying a full bookbag in your Prius as opposed to an empty one. You likely won't notice a thing when it comes to MPG.
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(usbseawolf2000 @ Jun 28 2006, 02:07 PM) [snapback]277901[/snapback]</div>
    The original 15" rim is 6.45kg (14.2lbs)
    You maybe see 20% down, about 42 MPG with the 17" tires. <_<
    Ken@Japan
  4. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    <div class='quotetop'>QUOTE(ken1784 @ Jun 28 2006, 01:23 AM) [snapback]277911[/snapback]</div>
    Thanks Ken. You are very knowledgable when comes to spec. ;) Wow, 14.2 lbs rims, impressive!
    20% down? I hope not... not from what others reported. I really hope it is only 5% down. :D
    Dennis
  5. larkinmj
    larkinmj New Member
    1,996
    Does anyone know how much the 16" wheels on the Prius sold in Europe and the touring model in Japan weight would switching to them affect mileage significantly?
  6. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(larkinmj @ Jun 28 2006, 02:42 PM) [snapback]277921[/snapback]</div>
    The original 16" rim is 6.90kg (15.2lbs).
    The mileage will be 10% down by OEM Michelin Pilot Primacy 195/55R16.
    Ken@Japan
  7. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    The factory rims weigh around 15 pounds. I weighed one, so I know for sure rather than what is posted online somewhere. I also know that after I went from the stock wheels and tires, which weighed 32.2 pounds, to a 17" tire/wheel combo (Scion tC wheels) which weighed 42.8 pounds, I only went from 52 mpg to 51.7 mpg.
    Don't listen to the naysayers, most of hem have not done it, and are only guessing. I have done it and know from experience.
    Now I will say this. After switcing, you may end up driving faster because the car handles better. When I said that my mileage only dropped by 0.7 mpg, it was with me driving very conservatively. For me it was almost torture to go so low and steady, always at or just below the speed limits. I normally drive much faster and then my mileage dropped some more. If you look at my normal driving, I dropped from 48 to 43 mpg. But keep in mind that I drive around 80-85 mph for 60 miles. Not the ideal driving for max mileage. If you drive more reasonably, your mileage will NOT suffer that greatly.
    Finally, it is possible to get a 17" setup that weighs less than the stock 15" wheels. I just ordered some wheels/tires which will weigh 1 pound less than the factory setup. I did thi smore for the handling benefits than any mileage benefits. The new wheels won't greatly increase the mileage, maybe I'll gain back that 0.7 mpg. But the car WILL handle much better, and the TRD suspension will perform better with less unsprung weight.
  8. NuShrike
    NuShrike Active Member
    1,378
    <div class='quotetop'>QUOTE(usbseawolf2000 @ Jun 27 2006, 10:07 PM) [snapback]277901[/snapback]</div>
    I'll add Ken's more detailed info to our FAQ now too.
  9. powrfuel
    powrfuel New Member
    82
    docvjay...what rims/tires combo did you get and what did you do about the tire pressure ninitoring stems from the stock tires?
  10. tnthub
    tnthub Member
    519
    Brunswick, Maine
    It isn't just the rim weight... you also need to factor the weight and rolling resistance of the tire. There are a great many variables but another large one is having the total package close enough in size to not have to recalibrate the computer, plus the backs and fronts must be close in diameter to avoid setting off any ABS or traction control codes. I would wager it is possible to obtain 17" wheels and tires that may provide better fuel economy, although the looks may not appeal to you.
  11. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(powrfuel @ Jun 28 2006, 08:42 AM) [snapback]277972[/snapback]</div>
    I originally replaced the factory setup with wheels tires from a Scion tC. They are 17x7.5" rims, 5x100 spacing, 45mm offset, with Bridgestone Potenze RE92 215/45 17 tires. As I posted above, they weigh 11 pounds more than stock for each corner.
    The new wheels I ordered are Centerline RPM forged wheels, 17x7", 5x100 bolt spacing, 42 mm offset. They weigh 13.5 pounds. I also ordered a set of General Exclaim UHP 215.45 17" tires. They weigh only 18 pounds, which is 4 pounds less than the average tire of that size. THe Brifgestones weigh 22 pounds each. This combo will weigh in at 31.5 pounds, less than the stock 32.2 pounds.
    As I said, this is not likely going to change the mileage a great amount. What it will do is improve handling. Race cars have extremely light wheels because of the increase handling, not the fuel efficiency.
    For the current Scion wheels, I just left the wheels without the sensors. All that happens is the orange indicator light is on when driving. It does not adversely affect the car in any way. Now that I'm getting my final set of wheels (the Scion rims were placeholders, test subjects) I'm installing a set of TPMS sensors to enable the system again. THe ones that came with the stock wheels are still in the stock wheels. I'm selling them to someone.
  12. McShemp
    McShemp New Member
    371
    SA, TX
    Does a tire with great grip equate to a higher rolling resistance?
  13. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(McShemp @ Jun 28 2006, 04:42 PM) [snapback]278203[/snapback]</div>
    Usually, but not always. A tire's grip is a combination of what it's made of and the tire's tread design (or lack thereof).
    A softer compound will almost always have more rolling resistance than a harder one with all else being equal.
    However, usually things are usually not equal. There are a few tires that are available with differnet compounds in the same design. THe Yokohama DOT race tires are one example. They have a standard and a soft compund with the same tire tread and size.
    Design also makes a huge difference. Compare a slick, a summer tire, a rain tire (like the Goodyear Aquatread), and a snow tire. Each is very different.
    A company can make a tire with a softer compound and design the tread so that rolling resistance does not actually increase. Or the other way around. That is why there are so many brands and designs!
    Tires designed to be "economical" such as the ones on the Prius are usually of a harder compound to reduce rolling resistance, but design the tread so as not to loose too much grip. THe ideal high efficiency tire would be rock hard and very narrow, but this would have nearly no grip. The ideal high performance tire would be really wide and really soft to maximize grip.
    It's a game of trade-offs.
    I'm getting a tire with much more grip, and I'm likely trading off some mileage.
    It all depends on what is more important to you.
    I just got my new tires in, and they are indeed light. I weighed them at 18.0 pounds exactly.
  14. cupcake
    cupcake New Member
    sydney
    hi all. dont mean to steal this post.
    but is it true that we shouldnt get after market wheels for the 2006 prius?? something about the tyre monitor thingy...
    thanks in advance
  15. DocVijay
    1,455
    Tampa, FL
    <div class='quotetop'>QUOTE(cupcake @ Jun 29 2006, 03:07 AM) [snapback]278480[/snapback]</div>
    No, not true.
  16. andreaswin
    andreaswin New Member
    72
    NORWAY
    hi
    well i switched from the european 16inch wheels to 17 inches OZ superturisimo GT ,, and Dunlop P9000 205x45x17" tires,, forgot to check the total weight of the old 16",, but the OZ rims are as far as i know,, 5,5 or 5,9kg ,,, the 16" are heavier,, Yes tires are a little wider than original (195mm) .. My experience is the same as DocVijay , i didnt se any significant drop in milage if i drive the in the same way as before.....
    Andreas
  17. NuShrike
    1,378
    <div class='quotetop'>QUOTE(andreaswin @ Jun 29 2006, 07:21 AM) [snapback]278562[/snapback]</div>
    casted:
    from wheelweights.net:
    17x7 20.7lbs [9.38 kg]
    17x7.5 21.6lbs
    17x8 23.3lbs [10.56 kg]
    16x7 19.6 lbs (or tirerack's 17.6lbs) [8.89 / 7.98 kg]
  18. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    I found these 17" that weights 16 lbs. I am thinking about getting a set. The offset is 42mm rather than 45mm stock. Any thoughts on it?
    Dennis
  19. andreaswin
    72
    NORWAY
    thanx!! nice website :) wheelweights.com
    <div class='quotetop'>QUOTE(NuShrike @ Jun 29 2006, 09:50 PM) [snapback]278742[/snapback]</div>
  20. DaveOrgans
    DaveOrgans New Member
    75
    <div class='quotetop'>QUOTE(DocVijay @ Jun 28 2006, 09:52 AM) [snapback]278012[/snapback]</div>
    Questions: 1) Must Toyota (i.e. Prius) TPMS sensors be used with the Prius system, or have TPMS sensors been standardized across manufacturers/models?
    2) Does anyone make a TPMS receiver system that can get more information out of the factory Prius sensors. My last car read each tire's pressure inside the cabin. I found that very informative for adjusting tire pressure for large seasonal temperature changes. I would also like to be able to monitor the pressure of the spare tire on the display. I would like to add such a display to my new Prius when it arrives.
    Dave H.
