New Prius owner!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Zaklax92, Jun 4, 2017.
  1. Zaklax92
    Zaklax92 New Member
    Malmstrom AFB, MT
    Hi guys!
    Just bought a 2006 magnetic grey Prius last week, with only 110k miles on it! I really got a great deal from a friend at work. I plan to make a few upgrades, like shark fin antenna, window vent visors, H&R or tanabe DF210 springs, KYB gr2 shocks (mine feel like they need to be replaced anyways), front lip, k&n air filter, tanabe strut tower bar and subframe brace.
    The big question is what wheels will fit?
    Avid.1 AV-50 17x8 et35
    Primax 770 17x8 et40
    TSW nurburing 17x8 et35/45
    F1R F23 17x8.5 et35
    I plan on running 215/45r17, and the car is being used for 5hour weekend roadtrips. How wide can I roll around with minimal rubbing?
  2. Zaklax92
    Zaklax92 New Member
    Malmstrom AFB, MT
    Or does anyone have pictures of their gen II with wheels in the listed widths and offsets?
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    I believe an 8" wide wheel isn't gonna fit without major surgery to your fenders, or at least a 50mm backspace. I have 6"x7" wheels w/ 40mm backspace and if I hit a big dip the front tires rub just a little.
    Zaklax92 likes this.
  4. Zaklax92
    Zaklax92 New Member
    Malmstrom AFB, MT
    Thanks! I've seen people with them, but as a car i am going to be driving a lot I really don't want to be modifying the body a ton. Could I get some pictures o work yours fit please?
  5. fotomoto
    fotomoto Senior Member
    5,638
    3,814
    So. Texas
    Welcome and congrats! My '06 only has 49k miles; bought it from a little ol' lady. Anyways, just FYI that going with bigger and non-LRR tires will hurt your fuel economy.
  6. 69shovlhed
    2,170
    751
    Delaware
    motegi traklites are one of the lightest wheels I could find in my price range (used). I bought bridgestone LRR tires; I would not recommend them if you drive hard. traction isn't very good. gonna replace w/ mich or conti.
  7. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    215's should fit if you get the offset right. I tried 225's on 18x8s that I bought off craigslist for a few days and they rubbed pretty badly on the outside of the tire, but there was more room on the inside. The aerodynamics of the vehicle were designed such that there's not much additional room on the outside of the tire for more tread, but more on the inside. 8 inches is probably too wide, I'd stick to 7 or 7.5. I think there's a thread or two on PC with more info about what other's were able to fit.
    Some other notes:
    1. Do your research before using an oiled K&N filter. The oil likes to drip down and clog up the MAF sensor. I personally wouldn't use a K&N filter on a Prius.
    2. For the best cornering suspension upgrade for the money, upgrade the sway bars. Most get an aftermarket 24mm rear bar (TRD or progress) for a Corolla (~$150) and then get a 24mm front bar from a junkyard Corolla/Matrix (or parts store online, can be found for ~$60-70 shipped). There are several threads on this.
  8. Zaklax92
    Zaklax92 New Member
    Malmstrom AFB, MT
    I'm averaging 48 at the moment
    #8 Zaklax92, Jun 4, 2017
  9. Zaklax92
    Zaklax92 New Member
    Malmstrom AFB, MT
    Yea, after reading a few thread I saw 17's lose as much as 7! It seems buying good tires helps a ton. I didn't realize that about k&n filters, thanks. The swaybars are a must, might be my first upgrade
  10. Zaklax92
    Zaklax92 New Member
    Malmstrom AFB, MT
    How would these fit? 17x7, offset 35. Hoping they won't poke to far
  11. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    17x7 with 35ET you should be good as long as you dont lower the car. If you do, you may need to roll yuur fenders. Can easily be done for about $25 per fender.
    Check out the Private Sale forum: Private Sales | PriusChat
    You might find a few of the items your looking for there.
    gta_ and Zaklax92 like this.
  12. Zaklax92
    Zaklax92 New Member
    Malmstrom AFB, MT
    Thanks for your help Justdidit!
    Justdidit likes this.
  13. 69shovlhed
    2,170
    751
    Delaware
    I would try to find 45mm offset or even 50mm with 17" wheels. if the 50mm is a little too much, you can use a 5mm spacer.
  14. Ajourney101
    Ajourney101 Member
    127
    88
    Seattle
    Are you located in Seattle? I am selling my brand new H&R lowering springs
  15. Ajourney101
    Ajourney101 Member
    127
    88
    Seattle
    My prius has 18x7.5 with 1 inch adapters. No rub
  16. Ajourney101
    Ajourney101 Member
    127
    88
    Seattle
    Kevin_Denver and Justdidit like this.
  17. Ajourney101
    Ajourney101 Member
    127
    88
    Seattle
    18x7.5 with 1 inch wide adapters
  18. Ajourney101
    Ajourney101 Member
    127
    88
    Seattle
    No rub, 215/35/18
  19. Zaklax92
    Zaklax92 New Member
    Malmstrom AFB, MT
    I'm about 11 hours away. ill be driving out there the first week of august though! love the pictures!
    Ajourney101 likes this.
  20. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
