Some sort of switch that turns on when it recives voltage.
Discussion in 'Gen 3 Prius Technical Discussion' started by MagnusAG99, Jun 8, 2017.
  1. MagnusAG99
    MagnusAG99 Senior Member
    673
    521
    Norway
    Hey, im just wondering, does it exist any kind of switch that can sit in between a positive cable and turn it on when it receives some sort of voltage? like.. i have added some buttons to my car (parking sensor and front camera) but they r connected directly to the battery, which means they r always on, and it would be great if it existed any sort of switch that i can add in the cable that turns on and off the voltage from the battery to the buttons ive added. Like, it could for example be connected to the rear lights, so anytime the rearlights turn on the buttons turn on. For example.. kind a hard to explain, ill leave a pic down here to to what i mean.[​IMG]
  2. ChapmanF
    17,203
    MagnusAG99 likes this.
  3. MagnusAG99
    673
    521
    Norway
    thnak u dude. lol, u have helped me alot with my car now, really appreciate it.
  4. xliderider
    xliderider Senior Member
    8,040
    3,212
    Honolulu, HI
    A regular relay can also be used to switch power to any accessory. The relay coil is wired to a wire or fuse that is only powered when in Ready mode, no voltage sensing circuit necessary.
  5. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    A switch that closes when a voltage is applied is.........a relay.
    jerrymildred and Maarten28 like this.
  6. Eodguy
    Eodguy Junior Member
    Seattle
    Wire in a relay to a 12v supply that turns on with the key. Be sure to use a fuse from the main power input.
  7. MagnusAG99
    673
    521
    Norway
    yea, thanks dude, i have already done some haha, for my front camera and parking sensors and stuff, ill leave the diagram down here so u can see what i did.
