12V battery is dead!
Discussion in 'Gen 4 Prius Main Forum' started by kyw012, Jun 11, 2017.
  1. kyw012
    kyw012 Junior Member
    33
    Is my Prius 2016 12V battery defective? Or other parts?
    I bought it on September, 2016 and it is not even 8000 miles yet.
    Does anyone know how to jump start with portable power bank?
    I can placed the (+) cable clamp on the 12v battery, but the (-) cable clamp is too short to reach the solid, stationary, unpainted metallic point as shown in the manual.
    https://www.toyota.com/t3Portal/document/om-s/OM47A29U/pdf/OM47A29U.pdf
    (Page 711-713)
    Powerbank jumpstarter
    #1 kyw012, Jun 11, 2017
  2. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    Any chance that you may have left one of the interior lights on? Or maybe the little light in the trunk? You have any devices left in the car, and plugged in?
    I have a portable jump starter pack, but have never used it yet on any vehicle. And yes, the cable clamps are too short. I hope I will never need it on my Prius. Do the Auto Club guys know how to properly jump a Prius?
  3. booke02
    booke02 Active Member
    391
    415
    Israel
    My car was delivered in July 2016. I had a flat battery - nothing was left on or plugged in. Took the car into Toyota the next day and they replaced the battery without any questions.
    RCO and CoastRider like this.
  4. CoastRider
    305
    397
    My Prius was made in January '16. I bought it in February '16. I guess my battery didn't have much time to run down.
    If a vehicle has been sitting on the lot for many months, do the dealers recharge the battery before the customer picks it up? When I was a kid and rode my bicycle past car lots, I always saw battery chargers hooked up to many of the cars. But that was 45 years ago. :) They also had a "lot man" who went out there and started every car, every week.
    #4 CoastRider, Jun 11, 2017
    RCO likes this.
  5. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    Toyota wants that last connection to an unpainted bare metal ground to avoid possibly igniting of explosive gasses near the battery. I can say that over the years I have jumped to the negative terminal no less than 500 times and no explosions so far:) . It couldn't hurt to use some cardboard or paper to fan the air near the battery before connecting.
    I also find the jump packs are not as prone to sparking as conventional jumper cables are.
    RCO, kithmo and CoastRider like this.
  6. CoastRider
    305
    397
    I've done the same many times and never had a problem. But have never jumped a Prius.
  7. Mendel Leisk
    40,540
    The reason for connectin the negative cable to a bare metal part of the body is there is a remote possibility there could be hydrogen gas above the battery. There will be spark when hooking up the negative cable, hence the precaution.
    The reality: it's a very remote possibity. Also, ANY substantial bare metal of the body, OR the engine, will do.
    And if push comes to shove, I've connected directly to the negative post many times. Just to not tempt the gods: blow across the top of the battery before connecting, dispel the remotely possible hydrogen.
    Also, just for giggles: where safety goggles.
    The bigger issue: you should read up on 12 volt batteries, do's and don'ts, how to measure their health, how to charge, and so on.
    And with jumpstarting, be VERY careful to not reverse the leads, it can cause expensive damage. Treat jumpstarting as a very stopgap measure, just to get you to service. You need to get your battery assessed, or learn how to do it yourself. There's a possibility it can be recharged, but testing is step one.
    Also, your battery is very likely not "defective". Do you sit in the car listening to the radio, in accessory mode? Leave doors open for extended periods? Plug things in, say a 12 volt vacuum cleaner, phone charger, whatever? Do you have all the "courtesy" lights on? Have you left the car with headlights on occasionally?
    RCO likes this.
  8. kyw012
    33
    I was not on the accessory mode but I have my car dash cam hard wired. My car dash cam was installed in the body shop, so I do not know which battery (12v or the hybrid battery) it wired to.
    All I did was opening all doors to vacuum for probably 30mins.
  9. bisco
    51,087
    i think we've seen dash cams drain batteries before. you may want to talk to the shoppe.
    RCO likes this.
  10. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    It wouldn't be the hybrid battery for the DashCam - can only be the 12v. Go back to them and ask if they connected it to a non-Always-Live circuit or it might be running 24hrs a day. I've noticed modern cars, with such a huge number of draws on 12v power can overload the battery easily, though the couple of Amps for a DashCam shouldn't cause concern unless it's marginal already.
    All doors open operates 3 or 4 bulbs from memory, but could be the straw which broke the battery's back.
    If not, go check with your dealer or have the battery tested independently.
    Do you have heated seats or other high-drain items (though I think you've got summer at the moment)?
    RCO likes this.
  11. kyw012
    33
    No heated seats
    Car dash cam was installed right after I bought my car back in Sept, 2016.
    No battery drain till yesterday.
    The car dash cam will start recording for 30sec- 1min when the car is vibrated.
    Because the car kept vibrating when I was vacuuming. I kinda suspect the car dash cam draining the 12v battery.
    I will drive the car to dealership to check the battery in these days.
  12. alanclarkeau
    7,045
    7,589
    Unless it didn't turn off after you finished vacuuming - could be a faulty DashCam - can you unplug it temporarily. It seems they don't drain a lot of current, though, but anything can become faulty - like SmartPhones which suddenly decide to go flat in short time - then work fine after re-starting.
    Has your driving pattern changed - ie a week with only a few short trips, or lots of nighttime driving with demisters running?
    RCO likes this.
