The whine
Discussion in 'Gen 2 Prius Main Forum' started by Anissa Perkerson, Jun 15, 2017.
  1. Anissa Perkerson
    Anissa Perkerson New Member
    Booneville Ms
    Hey guys! I've had my 2007 Prius for about a year now and here recently it has started to whine when I press on the brakes to start and it won't start like usual. It takes a couple (or more) tries to get it to start all while the whining is going on in what sounds like the dash. Does anyone know what could be going on? I'd greatly appreciate it.
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Your 12 Volt starter battery needs to be replaced. Amazon has a pretty good deal on one!
    edthefox5 likes this.
  3. Anissa Perkerson
    Booneville Ms
    I just had it changed last July I believe (I got stuck about 45 minutes away from home that time) but could I take it somewhere and get them to test it for me to know for sure?
  4. Aaron Vitolins
    1,612
    1,144
    Franklin TN
  5. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Try this! Hope it helps
  6. Anissa Perkerson
    Booneville Ms
    Okay so I tried that and when I put the car in accessory mode it read a 12-12.4 and when I completely powered on the car it dipped to 11.2 then raised back to 14.1. Is that normal? Sorry about all of the questions. I don't know too much about cars.
  7. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Hmm sounds like it's going south. Do you have a battery charger? If this car isn't driven much, or only does short trips, the 12volt might not be getting enough time to charge. I would try trickle charging it one night and go from there
    Anissa Perkerson likes this.
  8. dolj
    dolj Senior Member
    8,186
    4,168
    Wellington, New Zealand
    Yes that sequence is normal but it does indicate the battery is on the very low side, so +1 to Aaron's advice. Buy or borrow a battery charger and charge it up overnight. Repeat the above test and then go from there. Report the results back here if you want further advice or opinion.
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,830
    Clearwater, Florida
    Put it in accesory mode again the battery check mode and then turn on the headlights and report that voltage.
    I expect it to be 10.5 a toasted battery.
  10. Anissa Perkerson
    Booneville Ms
    Hey guys! So after after a day of it whining everything went back to normal. I took it to my loca Toyota dealership and they ran a diagnostic test and found nothing wrong. So I woke up today and it's doing it again. Help!? I went to Oreilys to have them check my battery and everything was fine. Any ideas?
  11. Anissa Perkerson
    Booneville Ms
    Hey, after about a night of it sitting with me not messing with it it ran fine the next day. But today however I went to go to work and it decided to do it again. Any ideas? I've had the battery checked.
  12. Anissa Perkerson
    Booneville Ms
    Okay so I don't exactly as the above video said and turned on my headlights and it read 11.6 is that good or bad?
  13. bisco
    51,031
    sounds like it's on the edge, has it ever gone dead since you replaced it? or does the car get driven infrequently?
  14. edthefox5
    10,096
    4,830
    Clearwater, Florida
    Based on what I have experienced 11.6 which is bad quickly goes to very bad.
    Be proactive and dont let a dead 12 volt strand you u in a terrible place.
  15. Anissa Perkerson
    Booneville Ms
    I actually haven't had the battery but about 13 months or so.
  16. Anissa Perkerson
    Booneville Ms
    Also to answer your questions, it's never given me any trouble until about 6ish months ago. And now I'm on the 3rd time this whining has happened. I'm worried about it because I'm not eligible for a trade in for another year or so. I'd hate to spend more money on the car than it's actually worth.
  17. Anissa Perkerson
    Booneville Ms
    I'll probably take it to my local Toyota dealer and leave it with them. No one can figure out the problem so far. Like I said before, I had Oreilys test the battery and they said it was good. But I'm not exactly sure how accurate their tests are.
  18. Anissa Perkerson
    Booneville Ms
    Also the battery popped back up to 12.6 I believe after I left the headlights in for a few seconds.
  19. bisco
    51,031
    it's difficult to diagnose a battery in person, let alone the internet. it may or may not be the problem. find a place that can put a load tester on the battery, and also charge it for you. they should give you a printout of the test results that you can post here.
    if the battery is good, you may have a more serious issue. also, the battery connections should be checked for cleanliness and tightness, especially where the negative cable fastens to the body.
    another thing to check is your brake interlock switch. when you depress the brake pedal to start the car, your brake lights should come on.
    edthefox5 and Anissa Perkerson like this.
  20. Anissa Perkerson
    Booneville Ms
    Well it actually seems like that it may have something to do with low oil. My dad came and checked my oil and it was about 2 quarts low. So he put some more in and today it's running fine.
  21. bisco
    51,031
    yow, that's bad. are you changing it every 5k, and checking it at every phillip?
  22. Anissa Perkerson
    Booneville Ms
    I'll let it run about 200 over sometimes. But I need an oil change in about 600 more miles according to my sticker. But next Friday I'm getting it changed anyways. The maintence required light is annoying lol
