Clock didn't adjust to Daylight Savings Time
Discussion in 'Gen 4 Prius Audio and Electronics' started by Jason F, Mar 15, 2017.
  1. fuzzy1
    10,335
    It isn't one device, it is two independent devices. All trim levels have one of the devices, some of them (OK, most of them) also have the second.
    One global setting for all devices would be nice, but somebody didn't put in the work and expense to do it.
    alexgrigori and RCO like this.
  2. bhtooefr
    bhtooefr Senior Member
    1,396
    1,489
    Newark, OH, USA
    Also, the Prius is set up according to Toyota's standard approach for radios.
    In Japan, no radio is standard, you have to buy it as an accessory installed by your dealer. Toyota does have their own, including navigation, but there's also a huge aftermarket for radios that fit Toyota's 200 mm wide variant of double DIN, in the Japanese market.
    In the US, Toyota has a system optimized for the US market, known as Entune. (I believe this shares a codebase with the Lexus Enform systems - based on a lot of the UI widgets, anyway - which are used on Lexus cars everywhere.) Note that Canada gets the same software, just without the Entune branding or (on the navigation head unit) the Entune App Suite smartphone integration.
    In Europe, Toyota has another system, Touch 2.
    So, the car is designed around not having to have a radio at all (hence the independent clock in the instrument cluster), having an aftermarket radio, having a Japanese-market Toyota radio, having a Toyota Entune radio, or having a Toyota Touch 2 radio. That's why this stuff isn't integrated.
  3. Prodigyplace
    12,395
    11,676
    Central Virginia
    And my Trim Two only has one clock - There is no GPS navigation system.
  4. hyojiggy
    hyojiggy Junior Member
    SoCal
    Four Touring
    Toyota is an idiot for making two clocks not sync and are independent
  5. Prodigyplace
    12,395
    11,676
    Central Virginia
    The GPS system is not a standard option and manufactured by another company. No one company has all the resources to manufacture all the partying a vehicle themselves. It would raise the cost enormously to do that.
    Montgomery likes this.
  6. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    However, they could've used a protocol for, say, the instrument cluster's clock to be set by the navigation system clock.
  7. RobH
    RobH Senior Member
    2,372
    987
    70
    Sunnyvale, California
    So what car has automatic daylight savings time? My Windows XP computer doesn't even handle it properly since the rules changed after the last XP update
  8. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    The rules changed in 2007, meaning that you've missed about seven years of XP updates. See here.
    Montgomery, RCO, wrprice and 2 others like this.
  9. RobH
    RobH Senior Member
    2,372
    987
    70
    Thanks! That system has SP3 installed, which as far as I knew was the last official update. Plus the security updates just announced for June 2017. So are there any other updates beyond SP3?
    I wonder if that machine can boot from other than C? There's a Windows 98 off there on drive E or so...
    The main reason I gave the example is that car manufacturers are hardly into regular software updates. If they attempted to provide automatic DST updates they'd be out of date somewhere in the world rather quickly.
  10. Prodigyplace
    12,395
    11,676
    Central Virginia
    @bhtooefr link marked "See here" directs to the November 2006 time zone update for XP. You need to download & install it yourself, though,
  11. RobH
    RobH Senior Member
    2,372
    987
    70
    Speaketh Microsoft: We're sorry, this download is no longer available.
  12. bhtooefr
    1,396
    1,489
    Newark, OH, USA
    That update should be available through Windows Update, though, and anything with SP3 should already have it, actually.
    If you're booting from another partition with an older OS, though, that could easily explain it. However, that KB article also mentions the registry keys that are changed, and I believe the same registry keys will work on all Win9x or newer OSes. (If not, there's ways to fix it on Win9x, I'm pretty sure.)
  13. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    My 09 Merc C class did it for at least 3 years till I moved on
  14. LeoK
    LeoK Junior Member
    Auckland
    I have a 2017 Gen4 Prius. I change from NZDST to NZST and back by the simple but cunning expedient of pushing H on the data display.
    The first-world problem that keeps me awake to the extent of needing psychiatric counselling (and copious amounts of legal varieties of ethanol) lies in the embedded JBL navigation system the car came with. The time there is stuck on daylight saving and can’t be changed without changing the time zone. The problem is that the car doesn’t work very well in mid ocean.
    Any advice gratefully appreciated.
    Prodigyplace likes this.
  15. Prodigyplace
    12,395
    11,676
    Central Virginia
    Where is the LOL button?
    @Tideland Prius we need an LOL button! :D
    :ROFLMAO::ROFLMAO::ROFLMAO:(y)(y)
    jerrymildred and Tideland Prius like this.
  16. Mendel Leisk
    40,471
    Corolla Hybrid bests it: it has 3 autonomous clocks:
    (starts around 5:35)
