Recentering the Nav
Discussion in 'Prime Audio, Electronics, and Infotainment' started by Civic4982, Jul 8, 2017.
  1. Civic4982
    Civic4982 Member
    46
    40
    Does anyone know how to recenter the Navigation on you once you've touched elsewhere on the screen?
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    I was wondering the same thing, I end up pulling over, shutting off the car then re-starting! ugghh!:mad:
  3. Qmo
    Qmo Member
    61
    52
    Sunnyvale, CA
    alexcue, stevepea and SaraBBrown94 like this.
  4. priuscatprimeguy
    2,730
    2,640
    doesn't that just center it over your home address? what happens if you're not at that address at the moment?:confused:
  5. Qmo
    Qmo Member
    61
    52
    Sunnyvale, CA
    Now I'm confused, what's the button above Menu?
  6. DavidA
    2,344
    1,820
    Chicago western burbs
    Home re-centers the Nav screen around your little flying candy corn car icon.
    CNYhybrid likes this.
  7. Tideland Prius
    16,547
    Press the circled button
    bhtooefr, Pdog808 and stevepea like this.
  8. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    Pressing the home button, which is the upper button on the right side of the large screen, centers the car icon. When in route guidance, pressing the same home button repeats the voice instruction.
  9. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    This "HOME" is the physical button to the right upper corner of the screen. Your "HOME" is the button at the navigation screen.
    priuscatprimeguy likes this.
  10. priuscatprimeguy
    2,730
    2,640
    cool, I'll check that out when I go to work today:cool:
  11. CharlesH
    2,796
    1,163
    Roseville, CA
    The physical "HOME" button means, "jump to the main (home) screen of the user interface". OTOH, the destination "Home" is where you live. Two different contexts for the word "Home".
    Just like "Delete Dest" does not mean to delete the item from your address book or "previous destinations" or wherever. It means to stop navigating to the current destination.
    I suspect that in both cases, things are much clearer in the original Japanese.
    dslomer64 likes this.
  12. Krzysiek_KTA
    Krzysiek_KTA Active Member
    159
    125
    Houston
    regardless of semantics my struggle to re-center the Nav screen was over once i learned from this forum that "home" button push works.
    cheers
    alexcue likes this.
  13. Tideland Prius
    16,547
    Again, there is a recenter button on the screen.
  14. Qmo
    Qmo Member
    61
    52
    Sunnyvale, CA
  15. Civic4982
    Civic4982 Member
    46
    40
    Mine doesn't seem to do that on the 11" screen version.
    Will try again tomorrow but many times I've tried pressing that button but it simply pushes me out even further on centering as if I'm touching that part of the map.
    Will try the "home" button suggested as well. That's one solution I've not yet tried.
    Thanks everyone.
    iPhone ?
  16. Krzysiek_KTA
    159
    125
    Houston
    [QUOTE="Civic4982, post: 2568259, member: 131987" I've tried pressing that button but it simply pushes me out even further on centering as if I'm touching that part of the map.[/QUOTE]
    I've been experiencing the same. Only HOME button works for my Advanced. Thanks to this forum I found it. cheers
  17. Tideland Prius
    16,547
    7". I guess "Home" is the only way on the 11.6"?
    You'd think it's the same software, I guess not :(. Learned something new!
  18. Ragz
    Ragz Active Member
    210
    110
    New York
    Can someone tell me if the colors and ridges on the roads, on the map, tell traffic conditions?
  19. Civic4982
    Civic4982 Member
    46
    40
    Thanks.
    Home button worked but not the on screen button.
    Sorry for the delay in getting back to everyone. Was out sick yesterday.
    Yay for resolution of the issue!
    iPhone ?
    Prius from Dad likes this.
  20. always_shifting
    always_shifting Junior Member
    US
    As you can seen on the 11" screen, the virtual button that appears on the 7" is likewise visible in the top left around some other virtual buttons. However it only shows the distance between the target and the vehicle's current location (in this photo, it's 0.2 miles). It is not a button you can click, if you try to, it simply behaves just like it would if you touched the map anywhere to move around. A little more effort for UI design would have gone a long way for Toyota [​IMG]
    XT1585 ?
