4th Gen LED headlight durability
Discussion in 'Gen 4 Prius Technical Discussion' started by CooCooCaChoo, Jul 11, 2017.
  1. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    They need to go back and "study" all the cracking windshields...
    'LectroFuel and RCO like this.
  2. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    272
    Harrisburg, PA
    It would be interesting to know if car manufacturer's specify their windshields or if the pick from a list of available options.
    And, why did you put the word study in quotes?
  3. CoastRider
    305
    397
    "I don't know." :LOL:
    But I am enjoying my LED headlights. The brightest headlights I've ever had on a vehicle. A very nice "white" light. I can see the road much better at night. (I just can't see out the SIDE windows! :ROFLMAO:)
    #23 CoastRider, Jul 14, 2017
    HPrimeAdvanced likes this.
  4. bbald123
    386
    272
    Harrisburg, PA
    I completely agree. The first time I used the headlights at night I couldn't believe how much better they were than all others I had used up until then. I don't have the side window problem, though.
  5. CooCooCaChoo
    CooCooCaChoo Senior Member
    953
    533
    Cow-lee-fornia
    2023 Prius
    Dark tinted front side windows--don't get stopped by a cop.
    But yeah, durability questions aside. These are the brightest I've seen, even on just the low beam setting. I wonder if adjusting it a tiny bit upwards would be tolerable to throw more of the light down the road.
  6. Tideland Prius
    16,443
    Be careful of glare though. They are very bright so you don't want to blind oncoming cars if you hit a bump and the car bounces up on the recoil.
    HPrimeAdvanced and RCO like this.
  7. Elektroingenieur
    2,515
    3,277
    Three Touring
    Unfortunately, what they’ll read in Toyota’s Repair Manual, at least in the U.S. edition, is that a faulty headlight assembly must be replaced as a complete unit. The only field repair is to replace the (incandescent) turn signal lamps and to install retainers, sold as service parts, to replace broken mounting tabs. If the LED unit inside is faulty, the whole assembly has to be replaced.
    As I noted in another thread, it’s different in Europe and Japan, but I don’t know if the headlight internal parts Toyota sells in those markets would be compatible with a U.S. vehicle, or if the U.S. headlights are permanently sealed, as another poster in that thread thought they might be.
    Almost. Depending on the trim level, the U.S. list price for a UNIT ASSEMBLY, HEADLAMP is $1119.69 or $1166.21 each, though in practice, discounts of 33% or more from those prices are not hard to find.
    The headlight current is switched with three relays, H-LP SHADE in Relay Block Assembly No. 2, and H-LP LH and H-LP RH in the No. 1 Integration Relay module, both separate from the headlight units. It’s reasonable to assume those relays have design lives of at least 10⁵ cycles.
  8. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,589
    near Brisbane, Australia
    Ours will be RH Drive, which means the internals are different - the pattern of mainly low beam is drastically different, though high beam can be too:
    And with prices - we can often double USA or EU prices here - and discounts at dealerships just don't happen here. Maybe 3rd party but they only stock popular items.
  9. Prodigyplace
    12,398
    11,676
    Central Virginia
    I believe Europe and Japan have self-leveling headlights. Their parts may not work for US lights.
  10. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Didn't somebody ask whether the EU head units would work on US Prii back along? Can't remember the outcome now.
  11. Prodigyplace
    12,398
    11,676
    Central Virginia
    I do not remember that but some people have imported previous generation Prii from Japan only to find out the display, including error text, is Locked to Japanese only :eek:
    Many times they post screenshots trying to translate error text.
  12. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Should have read 'headlamps' - would that have affected your reply?
  13. Prodigyplace
    12,398
    11,676
    Central Virginia
    I would have said look at post 27.
    He said there are parts for the European headlamps but he did not know if they would work on the US headlamps. I merely mentioned the self-leveling difference to point out they may not work.
    Is self-leveling strictly mechanical or is there an electrical component to that?
  14. Elektroingenieur
    2,515
    3,277
    Three Touring
    It’s electromechanical. From the European edition of the New Car Features book:
    The headlight ECU sub-assembly LH receives vehicle height change signals the rear height control sensor sub-assembly LH and calculates the changes in the pitch angle of the vehicle. The headlight ECU sub-assembly LH/RH drives the headlight leveling motor LH/RH in accordance with the change. [ . . . ]
    Depending on the specification of the vehicle, either dynamic control which maintains a constant beam angle, or static control which adjusts the beam angle only when the vehicle is stopped, is used.​
    Interestingly, the headlight units, at least in Europe, have fans in them.
    RCO and Prodigyplace like this.
  15. Prodigyplace
    12,398
    11,676
    Central Virginia
    Since they have fans they must not be sealed units. That would make it easier to replace parts.
