Turbulence in inverter coolant resevoir
Discussion in 'Gen 2 Prius Main Forum' started by franken1313, Jul 25, 2017.
  1. franken1313
    franken1313 Member
    216
    27
    US
    I only see turbulence when the engine is before the READY stage. I press the Egnition On button twice Without pressing the break & there is turbulence in the resevoir tank but I don't see turbulence when in READY
    51,840
    that's odd, because the pump either works, or not. what issues are you having?
  3. franken1313
    franken1313 Member
    216
    27
    US
    I'm losing AC at high rpms / speeding / full throttle
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    You already have a thread going on this.
  5. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    It isn't easy to judge the cause of turbulence in the coolant reservoir when you are speeding without AC. Are you looking carefully enough?
    edthefox5 likes this.
  6. bisco
    51,840
    have you considered professional help?
    Raytheeagle likes this.
  7. edthefox5
    10,096
    4,833
    Clearwater, Florida
    lol....man this site is really whacko..
