unable to pump gas
Discussion in 'Prime Main Forum (2017-2022)' started by MNdriver, Jul 31, 2017.
  1. MNdriver
    MNdriver Senior Member
    549
    577
    I just refueled for the 2nd time since getting my car.
    The gas pump snapped off after adding just a gallon - like it often would do with my Gen 2 Prius. I know with the older Prius it was due to the bladder design rather than having a rigid fuel tank.
    I had thought Toyota did away with the fuel bladders for the Prius - am I wrong about that, or is there another reason the gas pump might switch off prematurely with the Prime?
    I did my old trick of pulling the nozzle out about an inch in order to continue refueling.
  2. Mendel Leisk
    41,301
    There is a flap that closes, 30 minutes after the the gas fill door is opened. And IIRC it'll also close if the car is moved a foot or two with the gas fill door opened, something like that? And there's been reports of malfunction, or at the least "surprises". Someone who knows more should be along shortly.
  3. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    It could have simply been a worn out pump nozzle. They do need to be replaced from time to time.
  4. MNdriver
    549
    577
    OK, thanks. Hopefully I'll be able to charge soon so the problem, even if recurrent, will be at most an extremely minor and rare nuisance.
  5. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    We had this problem with our Camry Hybrid for the last year we owned it. I kept meaning to get it fixed but never bothered. One trick we found is if we flip the handle upside down it would let us pump the normal amount. This should not be done on a new car though. One thing that can cause this is spiders. If spiders have crawled into and made a nest in the vapor recovery system, it can cause the tank to think it is actually full when it isn't yet. What you are doing by pulling the nozzle out a bit is allowing the gases to release around the nozzle out to the air rather than going into the vehicle's and nozzle's recovery system where it belongs.
  6. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Actually, it is the Prime. The car would rather you run on elec. So it refuses gas. Nice feature.
  7. bisco
    51,838
    what the problem? you should be able to get 5 or 600 miles out of a gallon.:cool:
    MNdriver likes this.
  8. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    If the problem persists at other gas pumps, it may be a problem with the tank air vent. In order for gas to get in, the air has to vent out. This would be a warranty repair item.
  9. Captmiddy
    225
    204
    Massachusetts
    Only a warranty repair in the first 12 months, after that not so much because debris can get into the tubes that form that system and cause it to malfunction. If that happens later, it is a $50 to $500 repair, but what usually happens is they blow air through the system with a compressor to clear the obstruction which is really a $1 repair effort :D. Also if they find that spiders are the cause, that will often remove it from a warranty issue, warranties do not tend to cover pest caused issues.
  10. MNdriver
    549
    577
    Thanks for the tips. I'll ask about it at my 6 month check up. "Unfortunately", if things go well with the electrician on Thursday, I"ll be able to charge at home and may not have another gas station experience to add to the data points. :)
    huskers and john1701a like this.
  11. john1701a
    12,817
    5,303
    58
    If it ever happens again, just move to the next pump. That's immediate confirmation that it's a gas station issue, not your car.
  12. Son of Gloin
    Son of Gloin Active Member
    421
    320
    Lafayette, IN
    I have ALWAYS had to fill our '08 2nd Gen at a VERY slow re-fueling rate... due to the bladder, methinks (which the Prime does not have... am I right?). So is SLOW re-fueling an inconvenience? Yeah! BUT... you might try just gently squeezing the handle - instead of depressing it all the way - when re-fueling. Bladder-or-no, this MIGHT help, at least until you can have your car checked out.
    MikeDee likes this.
  13. PT Guy
    1,085
    711
    MN, this is something I'd want to track down and get fixed sooner rather than later. I'd run on gas and find out what's happening with the fill system. Get that squared away, then enjoy your electron fuel.
    blueterp and Mendel Leisk like this.
  14. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    Make sure the car is "off" when you refuel. If it isn't the valve is closed.
    The sequence is:
    Turn car off.
    Open filler door.
    Fuel within a minute or so.
    Do not interrupt the sequence, or if you have to, repeat from the top.
    Mark57 likes this.
  15. MNdriver
    549
    577
    Yep, that's what I do.
  16. jaqueh
    jaqueh Active Member
    341
    199
    San Francisco
    What kind of a fuel tank does the prime have? Is it a bladder again?
  17. David Beale
    5,963
    1,988
    Edmonton Alberta
    No bladder, but to reduce evap. emissions even further there is a valve in the tank inlet.
    Son of Gloin likes this.
  18. wb9tyj
    wb9tyj 2017 Prius Prime Advanced
    389
    95
    Indiana and Nevada
    I've noticed that once the pump handle clicks off...i'm good for about 1/2 gallon more and that's it...we don't have to stand there and pump slow like i did with my gen 2s and it's burping bladder syndrome...
    blueterp likes this.
  19. Crowmag Naman
    Crowmag Naman Junior Member
    29
    albany new york
    That happen to me and i though something was wrong with the car. Turn out I left the car in park and not off. Apparently the car will not refuel unless turned off.
  20. Mendel Leisk
    41,301
    That's good.
