Power Outage
Discussion in 'Gen 2 Prius Technical Discussion' started by Charles Bradshaw, Aug 3, 2017.
  1. Charles Bradshaw
    Charles Bradshaw Junior Member
    Long Beach, CA
    I parked my 2004 Prius and all was fine. I returned an hour later to no power, no dash lights or power. I changed the 120 and 5 amp fuses at the auxiliary battery. The battery was at 12.8 v unconnected. It tested at 2.4 v connected to the system. The jumper point under the hood was 1.9 v. All the fuses under the dash and hood tested as good. I tried to hook up a code tester but there was no power at the connection. The fusible link in the engine compartment was fine. There were no idiot lights present when I parked. I haven't done any testing on the hybrid battery. Are there any fuses or fusible links in the hybrid module?
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Did I get this right? Voltage at 12V battery posts is 2.4V when it’s connected?
    Of course Prius can’t start when 12V battery is that low. So charge or replace the 12V battery.
    edthefox5 likes this.
  3. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    the 12 volt powers the computers that start the car if its low or dead car no go...
    a volt meter does not test under load so that 12.8 is almost meaningless.. its resting voltage.
    replace it , you cant do anything before the computers power up
  4. bisco
    52,232
    how many miles on her?
  5. Charles Bradshaw
    Long Beach, CA
    It's a new battery, just purchased in may. I have had a dead battery and this did not exhibit any symptoms. I tried jumping it and no go.
  6. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    Are you confident the key is working properly? Not starting with a jump is very strange.
  7. Charles Bradshaw
    Long Beach, CA
    I replaced the fob battery when I changed the 12 volt in May,
  8. Charles Bradshaw
    Long Beach, CA
  9. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    Did you use the jump connection under the hood? If so, make sure the side of the jumper clamp that is actually contacting the metal side of the terminal on the car has 12V on it. Some cables have 12V on only one side of the clamp and if that gets connected to the plastic side of the terminal on the car, you have no juice.
    Marty2go likes this.
  10. valde3
    2,002
    750
    Finland
    If the voltage measured at battery terminals is 2.4V then either battery is empty, faulty, or your measurement is wrong.
    What was the voltage when you tried jump starting it?
  11. Beachbummm
    1,160
    392
    if the battery is only a few months old return it and get a free replacement ...
    be sure you clean the negative cable connector where it attaches to the cars body.. if that doesn't fix it the next common sense thing is
    you have a dead short to ground that could set the car on fire so Id start pulling the interior and carpet out and look for burn marks where the wire harness is touching the body.. not sure why it isn't blowing fuses.. did you check the one near the positive terminal on the 12 volt?
    the orange safety plug on the HV battery is also a fuse, might as well check that..
    my money is still on a bad battery
  12. Charles Bradshaw
    Long Beach, CA
    I have a portable jumper unit and it would only fit in the rear the battery.
  13. Charles Bradshaw
    Long Beach, CA
    The measurements were the same before I jumped it.
  14. valde3
    2,002
    750
    Finland
    Connect your jump pack to jump terminal under the hood! I don’t understand what kind of jump pack would be impossible to connect to jump terminal.
    Measure the voltage when it’s connected. When it’s connected to jump start terminal if there is still no voltage at jump start terminal then you have bad meter, bad jump box, or bad connection on the jumper cables. If there is voltage at jump start terminal but not at 12V battery terminals you have burned fuse/fusible link, or bad connection on 12V battery cables.
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Navy commander is right about the jaw connection on the jumper but the jump point under the hood provides a metal tab
    The jumper can clip too on both sides of the clamp. That clamp one side thing got me once too lol.
    Beach bum is right too......if you had a dead short on the battery lead very exciting things would happen.
    So you have a dead battery. Don't jump it don't charge it replace it.
    Beachbummm likes this.
  16. Beachbummm
    1,160
    392
    OK I throw one last idea then I give up...
    next to the 12 volt battery is a black box, disconnect the white wire connector and leave it out, disconnect the 12 volt battery from the car, remove it and look for swelling or leakage.. if it looks good recharge it, reinstall it, reconnect the white connector be sure it clicks and pray.. a 2004 isn't worth a trip to the dealer.
    still, get a new battery
  17. Charles Bradshaw
    Long Beach, CA
    I haven't had any time to work on the car other than the preliminary that I already performed but this evening I dug out my load tester and it tested as week. Right now I'm doing a reconditioning of the battery. The battery is still on warranty so it's not a big deal to replace. I shall keep you informed of the progress. Thanks for your assistance.
  18. edthefox5
    10,096
    4,834
    Clearwater, Florida
    If it's under warranty why are you reconditioning it? A Prius AGM that's perfectly discharged by a light left on
    Usually is never the same. It's a very small battery. If there's even the slightest possibility it will expose you to another jump start down the road replace it.
    You will really regret it if you don't.
    jerrymildred likes this.
  19. Charles Bradshaw
    Long Beach, CA
    Well, waiting for for the auto parts store to open seemed like a no brained. Ran it all night and did not improve so picked up a new battery this morning. All is well. Thanks for the help. I have never see a battery go that bad that quickly without showing any other symptoms.
    valde3 likes this.
  20. edthefox5
    10,096
    4,834
    Clearwater, Florida
    Yeah that's what that little battery does. It usually does not recover.
    The hatch light gets lots of people they leave the hatch not closed all the way and the light is on and it kills the battery.
    It's on the drivers side in the back hatch it has an on/off switch turn it off,
    People that kill there Prius battery all have one thing in common, they do not arm the alarm especially in the garage. Door ajar will not allow u to arm the alarm alerting you to the fact the door is ajar and the cabin light is on. Caught me numerous times.
