Glide mode in Prime?
Discussion in 'Prime Fuel Economy & EV Range' started by mercat68, Aug 13, 2017.
Tags:
  1. Mark57
    2,945
    2,739
    OK
    RPM indicator on my Scanguage II.
  2. Prodigyplace
    12,466
    11,717
    Central Virginia
    I am no help then unless somebody donates one. :D
    jerrymildred and Mark57 like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,146
    Tampa, FL
    I have a reader and and app on my phone, so I could check rpm on my PiP. I'll try to remember to try that next time I have to run the ICE. But, to find out about the Prime, someone would have to donate one of those. ;)
    Mark57 likes this.
  4. Prodigyplace
    12,466
    11,717
    Central Virginia
    Bob wanted Gen 4 info. do you have one in your back pocket?
  5. jerrymildred
    11,517
    14,146
    Tampa, FL
    Nope. I also checked both front pockets and my desk drawer. I still need a donation. :D
    But I may make the test with mine just to satisfy my own curiosity.
    Prodigyplace likes this.
  6. bwilson4web
    16,129
    Just to clarify, I use cruise control to accelerate and N to coast because it minimizes human variability. It makes it easy to replicate results.
    Krzysiek_KTA and joachimz like this.
  7. Mark57
    2,945
    2,739
    OK
    To me, that's a lot of work to pulse and glide, especially over a long distance attempt.
    mercat68 and joachimz like this.
  8. jerrymildred
    11,517
    14,146
    Tampa, FL
    Two Prius drivers that I consider experts and greatly respect. I love it when we can disagree agreeably. :) I've tried both, see Bob's reasoning and agree with it, but don't feel like it's worth it to me. I'm glad we're not all the same.
  9. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    I will say this, there are few things people can do that will draw my ire more than this pulse glide thing. When I drive on a road, I maintain a fairly constant speed, people who pulse and glide vary about 10mph over short distances, it drives me batty. And yes I get the concept and why people do it but still it is infuriating when trying to get somewhere and someone is doing road tango. It isn't predictable, I can't follow there pattern without potentially running into their backside and it is self serving at the expense of others.
    Now I am sure a good number of you probably do it in situations where you wouldn't be driving me insane doing it, such as on multi-lane roadways where I can easily go around you, but I had a guy doing this once on a 2 lane bi-directional busy road and I wanted to get out and club him as he did this for like 20 miles and there was no way to get around him as the other direction was busy and there were no cars in front of him for a good 2 miles. He varied between 5 under and 10 over the speed limit.
    bwilson4web, jerrymildred and ct89 like this.
  10. ct89
    ct89 Active Member
    323
    266
    New England
    I 100% agree and appeal to the rest of the prius community to never pulse/glide when there is anyone within many car lengths...
    On an open road when nobody is around...Have at it...
    bwilson4web and jerrymildred like this.
  11. Mark57
    2,945
    2,739
    OK
    OK, I'll bite since I was in the discussion above. If you new folks had gone to the trouble to go back and read the original hypermiling attempt posts (2010 to current) from those of us discussing it, you see we are saying the same thing. Don't pulse and glide in traffic. Don't condemn us for something we have not done or condone doing.
    jerrymildred likes this.
  12. jerrymildred
    11,517
    14,146
    Tampa, FL
    It's a shame you have to actually say that. You'd think it would be assumed that rude driving is ... well, rude. But we've had to say it again and again. Don't drive like a Q-Tip. (If you don't know what a Q-Tip is, come to FL and check out the cars being slowly and erratically driven by small, white fuzzy creatures peering over the dash and under the top of their steering wheel.)
    Mark57 and Prodigyplace like this.
  13. Mark57
    2,945
    2,739
    OK
    I didn't like saying it either. My sister-in-law lives in Ft Lauderdale, so yes, I know the Q-Tip factor well. Be afraid, be very afraid.
  14. Prodigyplace
    12,466
    11,717
    Central Virginia
    I notice that you are wearing a hat in your avatar. Are you a Q-Tip in disguise? :eek: :D
  15. jerrymildred
    11,517
    14,146
    Tampa, FL
    LOL! Not yet, but I'm on my way. Some gray, some formerly blond, and some white ones for variety. One foot in the grave and the other on a banana peel.
    Henrik Helmers and Prodigyplace like this.
  16. Nate_F
    Nate_F Junior Member
    30
    Idaho
    I was under the impression that my 2012 Prius 3 had a programmable mode (OBDII code of some kind) to disable regen when letting off the gas pedal; is this not the case? I thought there was another to disable light acceleration when letting off the brake pedal.
    Would this not also work for the Prime?
    #36 Nate_F, Aug 23, 2017
  17. Prodigyplace
    12,466
    11,717
    Central Virginia
    The Gen 4 is much smarter so any pulse and glide benefit is greatly reduced. It already does some of that.
  18. jerrymildred
    11,517
    14,146
    Tampa, FL
    The only thing I ever heard of that would disable regen is either judicious use of the right foot or putting it in neutral. I can't think of a reason you'd want to have it turned off all the time. Easier to trade it in on a non-hybrid and go back to buying lots of gas.
  19. scm2000
    scm2000 Active Member
    164
    125
    Agree.
    You should not pulse and glide in traffic. But it's possible to use glide to maintain speed depending on the slope of the road. And you could argue it uses less gas that way...
  20. bwilson4web
    16,129
    I throughly agree:
    My testing and one SAE paper suggested the 10-15% gain is not worth the extra work. Fortunately TSS-P solves the problem my using dynamic cruise control.
    Better still, follow large trucks or pickups with trailers. They provide camouflage for following traffic and a fairly steady speed. Set cruise control and enjoy the ride. FYI, my Prius Prime sees no advantage in that driving style in EV mode.
