Can you turn off the DCC display?
Discussion in 'Prime Main Forum (2017-2022)' started by scm2000, Aug 18, 2017.
  1. scm2000
    scm2000 Active Member
    164
    125
    Im guessing not because ive been through every menu, but maybe i missed it.
    I dont like the info display flipping between whatever info i have up and the cruise control display... especially since that display doesnt seem to give any info... i know my speed setting and i know if a car is in front of me.
  2. Prodigyplace
    12,682
    11,832
    Central Virginia
    On the Gen 4 you can turn off the popup instructions that appear when you turn DRCC on (& off?), but not the other popups without disabling DRCC :(
  3. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    there are 2 different pop-up reasons:
    1. LDA - you are about to get out of your lane or switching lanes without blinking/turn signal
    2. Radar (DRCC) detects a car or you are getting to close to the car in front of you
    If you like LDA &DRCC - you will have to live with these pop-ups
    you can disable LDA
    you can use regular CC instead of DRCC
  4. scm2000
    164
    125
    Toyota watches these forums so you can also say it should be different.
    I have no problem with Lda popups, i want them.
    i have the distance set to max, so very far from the car in front of me... the display seems to cycle on a timer.
    but ill pay attention and see if it stays away with no car in front.
  5. joachimz
    451
    612
    17
    SoCal
    I've been on long trips with no car in front of me for miles and the pop-ups not popping up ... but the radar might detect other things, hence the pop-up.
    I'm not arguing that it is annoying, it bugs me, but ... even if Toyota watches this forum does not mean that they will take any action, best example might be the sun visor that you flip to the side and it is no longer a sun visor, you cannot extend it, pathetic that a plastic extender (cost $0.20???) that even other Toyota cars have has not made it into the Prius for 15+ years, despite feedback on this forum and in surveys ...
    OptimusA and priuscatprimeguy like this.
  6. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Krzysiek_KTA and joachimz like this.
  7. scm2000
    164
    125
    While i do use the visor in front of me. in 40 years of driving i flipped the visor to the side once maybe. i guess sun from the side doesnt bother me.
  8. joachimz
    451
    612
    17
    SoCal
    priuscatprimeguy likes this.
  9. joachimz
    451
    612
    17
    SoCal
    good for you, my morning commute is south, sun on the left, evenings, sun on left ... i use those visors that @priuscatprimeguy is showing for 5+ years 2 hrs every day i commute ...
