charging while it is raining
Discussion in 'Prime Main Forum (2017-2022)' started by kozolchyk, Aug 24, 2017.
  1. kozolchyk
    kozolchyk Junior Member
    28
    39
    Miami Beach Florida
    I want to know if is safe to charge the prime while it is raining?
    priuscatprimeguy likes this.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    Yup, been doing it since 2012, rain, snow, sleet, etc, etc.:D but my hearingaids keep shorting out (I don't know why:confused:)
    #2 priuscatprimeguy, Aug 24, 2017
    Mark57 and HPrimeAdvanced like this.
  3. CharlesH
    2,796
    1,163
    Roseville, CA
    The plug on the car was specifically designed to be safe to use in wet weather.
  4. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    You can sing in the rain while charging as well.
  5. Pdog808
    Pdog808 Active Member
    431
    287
    Los Angeles
    2018 Prius Prime
    And sit in your car and run the A/C off the charger (Remote A/C) !
  6. El Dobro
    El Dobro A Member
    7,079
    3,259
    I charge the car in the rain, all the time.
  7. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Rain, what's that?? Oh no, what is that stuff in the sky, it can't be!! Is this the mysterious stuff called RAIN??!! Yes, it's FINALLY Raining (November 27, 2017; put it in your calendars) in Anaheim, California!!
    Well, you guys would probably call it a sprinkle, or a drizzle, mist, maybe? Would you believe heavy dew? How about foggy condensation. Hey, we'll take whatever we can get, after Satan's Bad Breath of temperatures we have been getting for THANKSGIVING; new record high temperatures in most Socal cities!!
  8. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    One caution, the plug at the car is designed so that the power cables are connected before the sense cables, so power comes on after the plug is seated. If your 110 volt end is also in the rain, it is much less protected. Try to arrange it so you power the circuit after you have inserted the 110 volt plug, if wet.
  9. priuscatprimeguy
    2,730
    2,640
    ZZZZZZTTTTTT!!!!!!!!:eek::eek::eek:!!!!!!!
  10. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    There are a couple of types of weatherproof extension cord connector boxes:
  11. Mendel Leisk
    41,011
