A "friend's problem" with her Chrysler's tires
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Aug 31, 2017.
  1. cyberpriusII
    1,155
    1,763
    Mars Hotel
    Seriously, this is a friend. I was over her house this past weekend and I happened to notice abnormal tread wear on the outside of her passenger side front tire -- feathering I believe it is called. Not smooth by any means, but the center of the tire and the inside shoulder had more tread.
    I managed to sneak a penny in the treads and the two outside are marginally covering Abe's head. The rest of the grooves are much deeper.
    The driver's side front tire is a totally different brand, and looks fine.
    The rear tires are a matched pair of a third brand and look good.
    She is a single mom with two kids -- this is a 2001 Chrysler Town & Country Minivan.
    I know she does not have a bunch of bucks.
    It is all conjecture, but how serious might this be. I am thinking she can probably wait a couple of months before springing for two new front tires -- if indeed that would be the solution.....
    Rain usually does not start in earnest here until the end of October. Feel as if I should say something, but I want to be on somewhat solid ground before I squawk.
    kris
  2. Prodigyplace
    12,531
    11,750
    Central Virginia
    I believe abnormal tread wear like that would indicate a wheel alignment or some other front end issue.
    I will let the experts here debate the best course of action.
  3. bisco
    51,840
    how many miles on them, and does she rotate? did u check the pressures?
  4. cyberpriusII
    1,155
    1,763
    Mars Hotel
    Bisco, my exam was done on the qt. I think the tires were all bought at different times -- and were used when they were bought -- probably at a Les Schwab.
    Schwab does seem to do a brisk business in selling used tires.
    Miles, got me, and I am sure she does not know, but all of them have varying miles, I am sure.
    I was just thinking if I could give her a heads up and she could save a couple of hundred dollars in the next two months it might head off overheating her credit card.
    #4 cyberpriusII, Aug 31, 2017
  5. bisco
    51,840
    i guess all you can do is mention it to her, and suggest a reliable alignment shoppe. not sure if it will save her any money though.
    maybe you can help her understand auto maintenance, and the importance of regular service, both financially, and safety for her and her children.
    if finances get in the way, perhaps trading the minivan for something more economical would be a good decision.
  6. bwilson4web
    16,187
    First get the alignment fixed. Then a cheap replacement. Start with the spare and let the worn tire become the new spare. Did I mention first alignment?
    Check the usual suspects for a sale.
    Does Oregon have an annual safety or emissions inspection?
    When a front tire fails, unskilled drivers can hit their brakes and brake-steer into a bad place.
    RCO and Prodigyplace like this.
  7. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    A relative of mine just paid to have his tracking realigned for a similar thing only to be told it was set OK, but his tyres were UNDER INFLATED. I'd recommend checking tyre pressure first. It won't cost much to find out!
    bwilson4web, Raytheeagle and Mark57 like this.
  8. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    It would be interesting to know the dates if the tires are mounted "date side out". I would attempt asking about the van. There's not point taking it to the shop if she knows there is damage that can't be fixed or is too expensive to fix.
    I'm with RCO about checking and increasing the tp (my bet it is low) but that isn't causing the problem.
    Since we suspect the tires were bought used the current condition may have been caused by the previous vehicle.
    RCO likes this.
  9. bisco
    51,840
    at least she's not in south texas.
    RCO likes this.
