E85
Discussion in 'Gen 2 Prius Main Forum' started by Cheap!, Jul 9, 2006.
  1. Cheap!
    Cheap! New Member
    1,157
    Ok, I though the 06 Prius was E85 compatible. You are now telling me it is not. Now that I have a full tank of E85 what should I do?
  2. Kev1000000
    Kev1000000 New Member
    271
    Livonia, MI
    You do realize the prius was not designed to run on E85, and probably will make the car run very sluggish...
    Anywho, nice rims!
  3. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    And E85 is about 20% less efficient than gasoline, so your MPG will suffer.
    And here are some figures I derived from reading a few sources:
    One acre of corn can produce about 325 gallons of ethanol.
    Because ethanol is not as "hot" as gasoline, that is equivalent to about 215 gallons of gasoline.
    So that means that an acre of corn would fill the tanks of about a dozen cars. Once. Then you have to wait months for more corn.
    It seems totally stupid to me.
  4. Three60guy
    Three60guy -->All around guy<-- (360 = round) get it?
    918
    Racine, Wisconsin
    <div class='quotetop'>QUOTE(Rick Auricchio @ Jul 9 2006, 11:02 PM) [snapback]283633[/snapback]</div>
    While you do make a point I hasten to remind everyone that our lack of a focused energy policy to reduce our addiction to oil is even more stupid. Brazil has engaged ethanol. But Brazil can afford to because it has so fewer vehicles to fuel than we do and so much more untapped land to plant corn in. So for them it makes sense. For us I totally agree, we simply do not have the amount of land to produce the needed ethanol even if it is less efficient. We just need to collectively agree to stop using big honking vehicles for normal transportation and convert over to the Hybrids we currently love, along with the plug-ins and better batteries of tomorrow. While that sounds so self serving, it is a working solution. Now if we could just get more of em built. :) Lets hope the forecasts are correct.
    I hope that Prius doesn't complain too much about that E85 you used, Cheap!
  5. Cheap!
    Cheap! New Member
    1,157
    Please help. Do I need to remove the gas asap, or can I run a few gallons off and start adding unleaded?
    Not a single sputter so far, but I am worried about burning a hole in my bladder or worse burning a gasket in my engine.
  6. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Theonly thing I can think of, Cheap!, is a standard syphon. Walk to the hardware store and get a foot-pump syphon and get out as much as you can.
    Make sure you do this in a well ventilated area since you don't want fumes to build up but make sure the onlookers know that it's your own car.
    I have no idea what you can put the E85 into. Popcorn, perhaps. Or you can sell it to a FlexFuel owner for a few nickels less than the gas station price.
  7. Kev1000000
    271
    Livonia, MI
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Jul 10 2006, 12:33 AM) [snapback]283660[/snapback]</div>
    Is it really that serious? I didnt think it would cause any permanent damage...
  8. TonyPSchaefer
    14,816
    2,499
    66
    To be honest, I'm not sure about the seriousness of the situation.
    I saw a thing on tv about biofuel and flexfuel and they were talking about how the computer has to calculate specific oxidation levels and burn properties of the fuel. That made me feel that there is enough of a difference that it's important.
    Don't tell Cheap! I said this, but what the heck, huh? It's not my car. :D
    I'm sure it's fine to drive a hundred miles or so, then top it off with normal gas and then drive a hundred more and repeat.
  9. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Jul 9 2006, 11:43 PM) [snapback]283665[/snapback]</div>
    Well I just went for a 30 mile drive at a 60 MPH using cruse control. I normal drive like that and I have been getting 5 min. bars ave. just over the 50 MPG mark. However, not the 5 min. bars are running more like 40 MPG. Wth 20% less? Not a single sputter or knock in the engine. It ran as smooth as can be.
    What I am really worried about is if the Prius parts can handle E85 without melting or damage. I sure hope I did not screw up my new car! If anyone has used E85 in your car before or knows somewhere I can find out information about "E85 in the 2006 Prius" I would love to know about it.
    Thank you.
  10. Kev1000000
    271
    Livonia, MI
    Well, E85 has actually less energy than regular E10 does. Gasoline actually stores a lot of energy per gallon. Ethanol does not, however. Aka, you'll use more ethanol to go the same distance as gasoline (lower mpg).
  11. vtie
    vtie New Member
    436
    Gent, Belgium
    One of the risks of E85 is that it may damage some pipes in the fuel system. An E85 modified engine usually has special pipes. But I don't know how fast this effect comes in...
  12. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    You will probably get some CELs soon as the car figures out that things are not working as efficiently as it should.
    As mentioned, the seals, tubing/pipes, etc are not designed for a high ETOH content fuel. I doubt a single tank would do much damage, but, if it were my car, I'd siphon out all I could from the tank then top off with regular unleaded sooner rather than later.
    It should not do any permanant damage to the ICE or anything like that.
  13. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    Don't take chances with your new baby!!!
    Siphon out as much as you can and fill it with regular unleaded, NOW!!! If you are degrading the bladder in your tank or your seals/lines/etc., you will be hit with a very expensive repair bill down the line.
    TAKE ACTION NOW!!!!
  14. andreaswin
    andreaswin New Member
    72
    NORWAY
    i dont think the engine take any damage (note THINK),, rather fuelpump gaskets and so on??? or that You get a non optimal use of the E85
    http://www.eere.energy.gov/afdc/afv/models.html if You dont find your prius in the documents , then its not E85 compliant...... why not ask toyota about what to be changed on a prius the make it usable for E85
    FFVs (Flexible Fuel Vehicles ) is the standard it has to follow .. many cars are FFVs.. mainly its that chip that controls the injection has a program for running and adjust to E85...
    http://www.greenenergynetwork.com/media/st...s/prius-e85.PDF read this for the prius (pri I) intresting reading,,,, and i suspect it might be the simmilar results for genII
    Cheers
    Andreas
  15. captnslur
    captnslur Junior Member
    78
    Lake Crystal, Minn
    <div class='quotetop'>QUOTE(Cheap! @ Jul 9 2006, 10:44 PM) [snapback]283628[/snapback]</div>
    No, the Prius is not E-85 compatible and reading the car's owners manual is time well spent.
    E-85 compatible vehicles have a notation on the fuel door indicating that. To use E-85 and vehicle must have a specially engineered fuel system which includes, as I understand it, a stainless steel fuel tank, special fuel delivery components which will with stand the corrosive nature of ethanol.
    Here's a web page about some tests run by Bruce Jones at Minnesota State University at Mankato which may shed some light on your delema. Even though the car is not designed for E-85, they did run increasing amounts of ethanol in an '04 and found little change in the operation of the car except that it had more power, but lower fuel economy.
    http://www.eere.energy.gov/states/news_det...fm/news_id=8577
    Check it out and give them a call. I don't think you've hurt anything, but it's not a good idea to use E-85 long term in the Prius.
  16. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Why get upset. You have a good excuse to take a nice drive and just burn the fuel up, since it runs ok.
    The damage will occur based on time in the tank. So just drive and refill. One day shouldn't hurt that much if our cars can handle the 10% ethanol full time now.
    Now if you get warning lights then I'd try to siphon out some and refill now. Then use up the E10 in small amounts with each tank later, keeping the percent near the rated 10%. You'd have to find out what % your gas already has.
  17. Jonnycat26
    Jonnycat26 New Member
    1,748
    New Brunswick, NJ
    <div class='quotetop'>QUOTE(Kev1000000 @ Jul 10 2006, 12:39 AM) [snapback]283663[/snapback]</div>
    It could be... E85 cars have special seals and gaskets, because E85 is more corrosive than regular gasoline.
    On the upside, a few tanks of E85 may destroy the bladder.
    It's almost a risk worth taking. :)
  18. Cheap!
    Cheap! New Member
    1,157
    <div class='quotetop'>QUOTE(captnslur @ Jul 10 2006, 06:52 AM) [snapback]283742[/snapback]</div>
    That is the problem, I read the 2006 Owner's Manual and page 319 states:
    CLEANER BURNING GASOLINE
    Cleaner burning gasoline, including re-
    formulated gasoline that contains oxy-
    genates such as ethanol or MTBE is
    available in many areas.
    Toyota recommends the use of cleaner
    burning gasoline and appropriately blended
    reformulated gasoline. These types of gas-
    oline provide excellent vehicle perfor-
    mance, reduce vehicle emissions, and im-
    prove air quality.
    That and the fact I saw a one sheet handout somewhere stating that the Prius was a flexi-fuel vehicle is what made me think it was ok.
    Also, while I have no knocking or sputtering yet the Check Engine Light did come on this morning. I plan to take my tank down to one gallon tonight so I can refill it with regular 10% ethanol and put this behind me I hope.
  19. sl7vk
    sl7vk Member
    518
    Salt Lake City
    <div class='quotetop'>QUOTE(Cheap! @ Jul 10 2006, 09:43 AM) [snapback]283775[/snapback]</div>
    Yeah, get that garbage out of your car. E85 contains really high levels of water, which make it corrosive as hell. One tank isn't going to kill you, but just the thought of that garbage in my car would make me shutter.
    As for Brazil and there Ethanol... I understand the argument, but when it comes to slashing and burning rain forest in favor of low yielding corn fields, I've got a problem with that.
    Ethanol the savior of GM, is hype.
  20. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Cheap, please keep PC apprised of any possibly related problems you
    see down the road, even if you've had the E85 out of there for some
    time. See, this is one of the thing that EVERYONE would love to know
    and that Toyota is refusing to give out any information on, that
    being: how resistant to ethanol are all the fuel-system components??
    If the cellulosic thing ever becomes viable, it *would* be nice to
    be able to do a minimal conversion to make an EXISTING Prius FFV --
    if all the components can deal with the chemistry, then all it would
    take is a fuel type sensor and a reflash of the engine ECU. [And for
    people to get used to lower MPG and quit bitchin' about it]
    _H*
