Rear left tire inside fender
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Imad Munir, Sep 21, 2017.
  1. Imad Munir
    Imad Munir New Member
    norway
    I have a prius 2007 model. the left rear tyre is inside fender but not touching fender or body. I don't know why it happened. I am also attaching the tyre photo.
    51,576
    welcome! not sure what you mean, has the body sagged down? maybe a broken or worn suspension part?
    jerrymildred likes this.
  3. Imad Munir
    norway
    yeah the body has shagged down from one side. I don't think it's the shock problem because otherwise the car would be full down on tyre. I heard something about wheel space don't know what that is.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,146
    Tampa, FL
    Yea. Looks like a broken spring or something.
  5. Mark57
    2,945
    2,739
    OK
    Welcome to the site. I'd definitely want to get under it ASAP to see what's going on before driving it. If you jack it up using a floor jack underneath the rear, be very careful. If it is a broken spring, it might be loose and move around as you jack it up and remove the pressure from it. I assume that side has no bounce to it if you press down on the body? if not, suspect the spring or its mount. Be very careful.
  6. bisco
    51,576
    how many km on her?
