Defroster problems
Discussion in 'Gen 2 Prius Main Forum' started by FishHawk, Jul 11, 2006.
  1. FishHawk
    FishHawk New Member
    176
    I tried my defroster today and it didn't seem to work that well. The conditions outside the car were very humid with heavy rain. In my RAV4 under the same conditions I was able to defrost the windows without a problem. What am I doing wrong? Put the setting on the front window with the AC on. Perhaps this worsened the condition because of the high humidity. Thanks for your input FishHawk
  2. brandon
    brandon Member
    771
    Manhattan, KS
    The only thing you should have to do to defog your front windshield is touch the windshield airflow switch... [attachmentid=4080]
    At least that's what page 295 of the manual says.
  3. RichBoy
    RichBoy New Member
    189
    yes, brandon is correct. just press that button and it will clear it quite fast, at least mine does.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    There are two buttons the one Brandon posted is for the windshield, the other is for the back window. The AC comes on with the front defroster and as RichBoy said it clears the windshield quite fast.
  5. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    I agree with the responses so far, but I'll just add that what FishHawk did should work. In theory, all that the "defrost" setting does is direct air-conditioned air onto the windshield.
  6. brandon
    brandon Member
    771
    Manhattan, KS
    I have noted in the past that if the inside of the rear window gets really fogged up, sometimes there's nothing that you can do short of taking a towel to it that will clear it up.
    ... well, I guess you could just ask everyone in the car to hold their breath and top emitting body heat, but seriously...
  7. stanleyjohn
    stanleyjohn New Member
    269
    Higganum,Ct
    What seems to work best for me when front fogs up is to put defroster on with HEAT!! The more heat! the faster it works.Not so great though when u dont want to heat up the inside if the car.Opening up the windows abit will also help.
  8. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(brandon @ Jul 11 2006, 02:50 PM) [snapback]284634[/snapback]</div>
    Won't happen if you have it set to Auto/AC.
