A shaking stop
Discussion in 'Gen 3 Prius Main Forum' started by David Green, Sep 30, 2017.
  1. David Green
    David Green New Member
    Morenci, Michigan
    Yesterday my 2011 Prius started shaking when the brakes were applied. Today it started shaking hard a few seconds after the engine was started. The dealership suspected that the auxiliary battery was dead so I drove 40 miles to buy one. It's been replaced but there's no change. I start it up, everything seems fine except for the "Check Hybrid System" display and the amber engine light. Then it starts shaking and soon turns itself off if I don't stop it soon enough. Any ideas?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat (y).
    How many miles on your Prius? Has it ever been in an accident? Did the dealer give you a list of codes that the car has logged? Have you looked under the hood for any loose connections?
    Keep us posted (y).
  3. bisco
    52,747
    sounds like a bad dealer.
    4md and Raytheeagle like this.
  4. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Bad or typical :sick:.
  5. bisco
    52,747
    they always leave me shaking too.:mad:
    Raytheeagle likes this.
  6. David Green
    Morenci, Michigan
    I think mileage is around 72,000. No accidents. No codes. I looked under the hood but didn't see anything. It's pretty packed in there.
    We have it towed to the dealership tomorrow
  7. David Green
    Morenci, Michigan
    The verdict is that a hose was loose and now a new purge valve is needed. I think that’s what was said. I’ll see the paperwork when I pick it up.
  8. bisco
    52,747
    thanks! interesting, not sure what the purge valve is for. this is definitely a new one.
  9. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Hopefully @David Green will post a copy of the diagnosis as there might be a couple of things going on(y).
