2010 Prius running very roughly
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LRW, Oct 8, 2017.
  1. LRW
    LRW Junior Member
    Oak Park, IL USA
    My 2010 Prius is running very roughly.
    69,500 miles are on it.
    Oil was changed within the last 200 miles.
    I noticed it yesterday during a 10 mile drive. It seemed to come and go but when I started it today it is still rough.
    Battery did not seem to be charging well either (down to 2-3 bars where it hardly ever goes).
    Mileage has been less than usual (around 35 mpg).
    If you have anything that I can try at home I would appreciate your advice. At least if I have some idea of what this is (and what it should cost to repair at the mechanic's) that would be helpful.
    I am handy enough to change air filters and other basic stuff or more complicated things with a good youtube video!
    Thanks in advance!
  2. Mendel Leisk
    40,232
    That seems the smoking gun. First off, you might check the condition of the hybrid battery fan. @NutzAboutBolts has a video on that, pinned at the top of 3rd gen maintenance forum. The fan can get clogged with lint or hair.
    The only comment I'd have on that video is that it's not necessary to remove the rear seat: if you push open a gap between the rear seat and back, directly below the fan inlet grill on seat back, there's a single 12 mm (socket size) bolt in there that you need to remove. It can be done with a ratchet with maybe 9" of extension. You can squeeze a hand in there while removing the bolt, to catch the bolt, you don't want to drop it.
    You also need to pull up the forwardmost portion of the rear hatch floor (with stubborn fasteners, most of which I left off at reinstall), peal back a few velcro carpet bits, a few more bolts and plastic fasteners. It's not that hard, follow the video. Also, you can clean the fan without complete removal. Helps to have compressed air of some sort, even a wet dry vacuum on blow, or a leaf blower, for example.
    All that said, if the problem is not just the fan, would it still be under warranty? The service department will likely not budge until you have a trouble light, some code(s). But get in touch with them, see what's what. Maybe drop $75 or so on a diagnostic session, especially if it it's still warranty, if it turns out to be the hybrid battery.
  3. JC91006
    JC91006 Senior Member
    16,632
    8,492
    Have you checked the oil level?
    Raytheeagle likes this.
  4. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    clean the egr system
    amos and danlatu like this.
  5. Grit
    Grit Senior Member
    6,366
    4,154
    Wilkes Land
    If oil was changed by jiffylube or similar, I'd check the dip stick ASAP to see if it's over filled.
    If this is the first time ever running rough, I'd drain their engine oil just put in and re-change it myself or have another shop do it. They have idiots working at those convenience oil change places. It might be that they put in conventional oil in or overfilled.
  6. Mendel Leisk
    40,232
    Maybe a bit early to be this, but rough idle might point to EGR clogging as well. Theres a good video on this by @NutzAboutBolts , pinned on maintenance sub-forum. Ultimately I found OxyClean was best , for cleaning the EGR cooler.
    Note the mention rough idle:
    NutzAboutBolts likes this.
  7. LRW
    LRW Junior Member
    Oak Park, IL USA
    Thanks all for your suggestions. It looks like I will have to take this to a mechanic. Now I just have to decide whether to find a local mechanic or take it to an inconveniently located dealer in case this is covered by the warranty enhancement.
    If anyone is willing to give my engine a listen, I have a short video at:
    https:// flic.kr/p/ZcK8DS
    (remove spaces after //)
  8. hyb
    hyb New Member
    Wish I new about this Toyota notice , left work recently.. was at drive through eating a burger. 2010 Prius all options, 200K miles , turning on an off at idle while I was eating ( typical of hybrid), outside temp about 60 after I experience rough start ( 1st time ever) and engine light came on..., Finished burger and immediately drove a few miles to my office with car running smooth and went back to work. After work car start was rough, engine light came on.. drove home car ran smooth, predominantly highway, dropped at dealer, they diagnosed the next day ( EGR and Intake manifold, repair was approximately $1100.) Upon pick up, dealer said his last experience indicated that problem could re-appear and if it does in his experience it would be transmission which would be $4000 to replace, Said he heard a noise in transmission and could be converter or clutch??. I asked why not replace just that? he said they do not do transmission work they just replace whole thing . Anyway ,car ran fine at pick up . I then took to another mom and pop repair that specializes in hybrids for second look, he said no issues or codes. Anyway car ran OK until, two weeks later when I am driving, and, turning off street,( stopping at turn.. engine turns off typical of hybrid) then after turn and proceeding up a small ( 60 degree incline) rough start upon engine start up . It smooth's out , however ,similar incidents over the next week. Anyway I do not have time to play twenty questions and start looking for a car ( find one after two weeks , 2014 camry hybrid) . Anyway over that two week period similar instances ( rough starts on some hills) then at some stops while driving. However after rough starts car runs fine. Anyway traded in car ( got $3200). Just thought I would pass this along as I always enjoyed the forum. Never ever had any other issues with this car aside from routine tire replacement and brake pads ( $395 front back dealer installed guaranteed for life) . Also hit a pot hole a year ago and blew out tire. Ultimately had leaky strut . Did not repair but estimates for two fronts ( strut and spring were) : dealer $650, Seaxrs -$750, PBoys $900, 3 local small shops were $875, &900 and 1000 ( respectively) . Anyway always enjoyed this forum and thought I would share my experience. My questions are is there tubing or hose that connect to egr or intake that should also be changed or cleaned during this type of repair as I asked for old parts and did not see any tube or hose in the box. Also can transmission issues cause rough starts??
  9. Mendel Leisk
    40,232
    EGR system is steel/aluminum, from the exhaust manifold connection to the connect at intake manifold.
    So the car is gone now?
  10. orenji
    orenji Senior Member
    5,886
    3,487
    Bad 12 volt battery?
  11. LRW
    LRW Junior Member
    Oak Park, IL USA
    Here is what ended up happening. I took my 2010 Prius to a local independent mechanic. They diagnosed and recommended that I take it to a dealer. I did so and the dealer replaced the EGR valve at no cost to me. The dealer also unsuccessfully tried to sell me other services like an $85 cabin air filter replacement. (which I did on my own in 7 minutes with a filter I bought for 8 bucks.)
    Thanks to everyone for your suggestions!
  12. hyb
    hyb New Member
    yes traded in for a 2014 camry
  13. orenji
    5,886
    3,487
    You first state the Prius had 69,000 miles and then you state it had 200,000 miles on it. Which is it?
  14. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    I think the first place you took your car to that said it could be the transmission, were just trying their luck. The guy said they don't work on transmission? Heheheheh. That was a plot to let you leave in a hurry.
    ANYWAYS, glad you got another car though.
    ANYWAYS, was there any light lit on the instrument cluster? If there was, do you have any scanned results?
    ANYWAYS, I think when the problem resurfaced after some weeks, that shows, the problem wasn't tackled.
    ANYWAYS, other things such as a clogged injectors, dirty fuel pump strainer, spark plugs, etc.
    ANYWAYS, I'd expect you keep spending more time on PC, just like I do, to learn more about these kinda problems.
    Dxta
  15. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    Did that fix the car, or ....?
  16. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    LRW and hyb are of 2 different person ;)
