What is the good/ok voltage reading for the hybrid cells?
Discussion in 'Gen 2 Prius Main Forum' started by franken1313, Oct 5, 2017.
  1. franken1313
    franken1313 Member
    216
    26
    US
    What is the good/ok voltage reading for the hybrid cells? I have an entire hybrid battery for sale. They are reading around the 7.4 area. Is that ok to sell as good/ok condition?
  2. JC91006
    JC91006 Senior Member
    16,754
    8,557
    Where are you? How much?
  3. franken1313
    franken1313 Member
    216
    26
    US
  4. franken1313
    franken1313 Member
    216
    26
    US
    I'm really not sure what they're worth. I'm in texas
  5. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    Not in my book!
    I just went thru charging, discharging, recharging and load testing all 28 modules in our pack, the ONLY module below 7.65 at rest was DOA at 6.84v.
    To really tell if a module is good or not, you need to at least load test it with 1.5-2amps and measure the voltage after it stabilizes (normally <5 seconds). Based on my testing, 7.45v would be about the lowest I would want under that load and yours are lower with no load.
    SFO likes this.
