Northern Hemisphere cool down
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Oct 17, 2017.
  1. bwilson4web
    16,129
    The seasonal weather change, Fall, recently brought Dixie temperatures down ~20F (~10C) and sure enough, our tire pressure alarm came on.
    Source:
    Intellicast - Mixed Surface Analysis in United States
    So I topped them off this morning (i.e., cold tire pressure) and found a 30.5 - 34.0 psi range.
    If you have tires, cold weather reduces the pressure and leads to more rolling drag. Since the normal threshold is about 10 psi for a low pressure alarm, I like to run door jam +10 psi. When the alarm comes on, the car is at what Toyota thinks they should be. <wink>
    fuzzy1, RCO and jdcollins5 like this.
    51,575
    54 today, 74 tomorrow. a/c last week, heat this morning.
    RCO likes this.
  3. RRxing
    RRxing Senior Member
    2,539
    1,813
    NEPA
    Rule of Thumb - 1 psi tire pressure (up or down) for every 10 degree F ambient temperature change (up or down)
    RCO likes this.
  4. Mark57
    2,945
    2,739
    OK
    Larger sized tires can be up to 2 PSI per 10°F. I mention this because many here own other vehicles other than Prii.
    RCO likes this.
