So wife took her Prius for "free" service.
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Frederickdawg, Oct 28, 2017.
  1. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    The Mrs finally bowed down to all the emails she got from a local Toyota dealership about her service being overdue nada nada nada...
    She agreed to a wheel alignment, and requested a copy.
    Anyone make anything out of this ?
    They weren't even gonna give her the paper work , she managed to get a copy of the Before but not after. Lesson learned. Got scammed. These so called "free" 2 years servicing in my optinion is nothing more than allowing an opportunity for the dealership franchise to scam as much cash out of the owner as possible , hence why on my own personal vehicle I never utilize their free scam oil changes. I don't like the idea of being mind fu**** by them when going there.
    SM-N950U ?
    #1 Frederickdawg, Oct 28, 2017
  2. Elektroingenieur
    2,515
    3,282
    Three Touring
    The complete alignment specifications and procedures are in Toyota’s Repair Manual, available by subscription to techinfo.toyota.com. For a concise explanation of some of the measurements, see Toyota’s Quick Training Guide: Basic Alignment Geometry.
    The reported measurements are all within specification, except right front caster, which at 5.9° is just outside Toyota’s published limits, 6.85° ± 0.75° (for 195/65R15 tires). The difference between left and right, however, is 0.4°, less than the limit of 0.75°. In any case, Toyota doesn’t publish an adjustment procedure for caster; it’s measured to check for damage to the body or suspension parts, and nothing should be done unless it’s badly out of specification or there is a noticeable handling or alignment problem.
    If the dealer didn’t make any adjustments, that may be why they didn’t provide a second report.
    That’s a fair viewpoint, but ToyotaCare is also meant to encourage people to maintain their vehicles at all—a surprising number don’t—and to get into the habit of returning to dealers for that purpose. Since Toyota reimburses the dealers for the work, the cost is part of the selling price of the car, and I’m inclined to get my money’s worth, while politely but firmly declining any unnecessary extras. I also see nothing wrong with doing the work yourself or having it done by a trusted independent mechanic, if you prefer.
    jerrymildred, RCO and bisco like this.
  3. krmcg
    2,592
    2,392
    Whittier, CA
    These reports are often color-coded to show what is "out" and what is "in".
    RCO likes this.
  4. Frederickdawg
    596
    335
    Exactly,but I asked my wife and she said the rep photo copied it and gave her the black and white one. Comical and totally dubious if you ask me.
    I'm not blaming the dealership, as I had already warned my wife about their predatory tactics.
    So the before shows a discrepancy on the front castor, but there is no proof showing it was sorted as no "after" print out was given. Oh well, what can say. LOL looks like their attempt to "milk" her out of $$$ every time she there for her "free" service eventually paid dividends.
    SM-N950U ?
    RCO, bisco and krmcg like this.
  5. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    My stealer recommends alignments and you pay the full price whether it is OK or not.
    Further, they did a CPO warranty covered bearing replacement on my daughter's Corolla - ran over time. When I finally picked it up, I asked if they did an alignment and they yes. So I asked for the printout, they said oops, forgot to print one, will have to put it back on the machine. Put it back on the machine, said oops, seems to have gotten out of alignment in the last 15 minutes . . . 30 minutes later, good to go (again). Right. :mad:
    RCO and Frederickdawg like this.
  6. Frederickdawg
    596
    335
    Thanks. I thought so. , Like I said earlier, she should have said NO. ;-) women, never listen. LOL
    SM-N950U ?
    #6 Frederickdawg, Oct 28, 2017
  7. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Actually, the reason they made a B/W copy to give your wife is because the right caster "window" on the color printout from the machine is RED because it is out of spec. That's why it is a different background shade on the B/W printout. The others are in spec and their background GREEN.
    Of course, a (color)blind tech might not catch the difference . . .
  8. Prodigyplace
    12,531
    11,749
    Central Virginia
    The text is also white instead of black on the copy. Any colorblind person can see that.
  9. Frederickdawg
    596
    335
    Regardless of color blindness, the castor was the only aledged issue.
    SM-N950U ?
  10. bisco
    51,840
    total scam in my opinion. it's a marketing ploy by toyota. you'd be surprised how many people think there is value in a couple hundred dollars of 'free' service, when dropping 30 large on a vehicle.
    and a spectacular opportunity for dealers to try and make a few hundred every time some poor uninformed soul comes in for their 'freebie'.
    don't be too hard on your wife, those clowns are well trained on the best ways to pray on the naive and innocent.
    RCO likes this.
  11. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    Alignments are one of those things that you need to get a lifetime warranty for. To receive this, you'll likely head towards a chain store, and not the dealership. My last Toyota had a lifetime warranty for $170 from a chain. I got around 8-10 alignments done for that price.
  12. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,592
    near Brisbane, Australia
    I think you'll find that warranties don't cover wheel alignments or balancing. And, my experience is that SOME dealers will try to convince you that you need one every year - "it's cheaper than new tyres". I've kept my last 3 cars for 3-4½ yrs, never had an alignment - though would have been suggested 10 times in that period of time - at $80 each would have been $800 wasted.
    pilotgrrl and krmcg like this.
  13. krmcg
    2,592
    2,392
    Whittier, CA
    You have the perfect way of telling if you need an alignment - tire wear!
    RCO, scona, Raytheeagle and 1 other person like this.
  14. Mendel Leisk
    41,313
    I was just at our local dealership parts department, and walking out I notice they were strapping some gizmos on the rims of a car, in the big entrance carport. I asked if it was some sort of wireless wheel alignment, and the guy said it was, and added that it's not that accurate, just a cursory check.
    RCO likes this.
  15. ILuvMyPriusToo
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    BEFORE I bought my Prius, the salesman explicitly described a new machine that checked the alignment of cars (free!) as they drove them into the service area.
    AFTER I bought my car, they say they never heard of that . . .
    kithmo, RCO and Prodigyplace like this.
  16. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    This seems rather silly to me.
    Just stand in front of a mirror and practice saying NO a few times before going.
    It really is easy !!
    P.S. The dealership in Ocala has never suggested unnecessary service during the "free" interval......yet.....and I'm on my second one.
    first_superior_prius likes this.
  17. alanclarkeau
    7,045
    7,592
    It's a bit like when you buy a car, and worse if it's new. You sign up for that car, should be the end of the story.
    But no, they want you to meet with the upselling person (always been a beautiful lady they've sent me to, but that might be because I'm a guy). She goes through the pressure sales pitch to sell insurance, paint protection, tint, extra warranties. NO, NO, NO, NO, NO.
    Next time I'm going to say no - I'll just take the car without the sales pitch for extras.
    RCO likes this.
  18. Prodigyplace
    12,531
    11,749
    Central Virginia
    Be sure to ask for a discount for avoiding the upsales person. :D
    RCO likes this.
  19. Isezno
    Isezno Junior Member
    Wagontown, PA
    Four Touring
    I guess I must be lucky then. I've gone to two different dealerships for the free services and never had any attempt to sell me anything other than what I came in for. When I complained to the selling dealership about my chattering wipers (after cleaning them all multiple times and only having 9,000 miles on them), they replaced them all under the 12,000 mile warranty (whatever that is).
    Minus the trips to go back to have them installed (which I'm perfectly capable of doing - minus the rear wiper - I can't get it off and even though I've read the instructions in the manual, can't figure out how to get the stupid thing off), the experience has been great.
  20. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Well, I would blame the dealership. If she paid for a wheel alignment then she's entitled to a print out. When I had an alignment done at Holman Toyota several years ago I looked at the report and thought WTH as the numbers didn't look good. Turns out the V has different specs so the guy had to do it again.
    I'd complain to the Service Manager that it looks like the car is out of spec and that you didn't receive any documentation that it was fixed.
    RCO likes this.
