Removing center mirror?
Discussion in 'Gen 2 Prius Main Forum' started by egg_salad, Oct 31, 2017.
  1. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    One of the minor annoyances that came with my "new" '08 is a sloppy loose rear-view mirror. It goes out of adjustment if I so much as look at it funny.
    The problem is clearly at the ball-and-socket joint where the mirror housing meets the stem. However, I can't tell if the problem is the ball or the socket, so I'd like to replace the whole shebang. Problem is, I can't make out how the stem attaches to the glass. Any pointers greatly appreciated.
    Oh, if it matters, this is the standard mirror. No HomeLink, no auto-dim.
    Thanks.
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Most windshield mounted mirrors have a "beveled" metal plate glued to the glass........and then the mirror stalk slides over that and is secured by a very small allen-type set screw or two maybe.
    Look carefully around the edges of the part that is up against the glass.
  3. xliderider
    xliderider Senior Member
    8,040
    3,212
    Honolulu, HI
    Yes, hex set screw on the lower edge of the mirror base, against the glass. Loosen the set screw until you can slide the mirror up off the base.
  4. egg_salad
    545
    426
    Las Vegas, NV
    Here is a photograph of the area, taken from the dash looking up. If someone can point out this Allen screw, I will buy them a hot dog.
  5. TerryM
    TerryM Member
    46
    44
    West Central Illinois
    Looks similar to my Chevy Blazer. I found that it has a spring tab that you have to disengage then the mirror slides right off. Heres a video link that shows one on blazer. Should be similar
