EV Range in Cold Weather
Discussion in 'Prime Main Forum (2017-2022)' started by dave3057, Nov 8, 2017.
  1. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    I did a search and didn’t see anything related to this. I’ve noticed the last few weeks my EV range has gone down from almost 35 miles to just over 30 miles. This might be normal for it being cold out. I don’t really ever use the ac/heat unless to get the defrosters for a minute or two.
    iPhone ?
    huskers and priuscatprimeguy like this.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    yup, it's normal:cry:
  3. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    I have noticed the same. It was 23 degrees out this morning. Damn cold.
    Give it 6 months.
    alexcue and priuscatprimeguy like this.
  4. bisco
    51,839
    expect it to keep dropping, but what about the battery pre heater?
  5. Trollbait
    12,501
    I thought the Prime's battery heater was more for keeping it above freezing than keeping it at the optimal temperature for charging and discharging.
    dave3057 and priuscatprimeguy like this.
  6. bisco
    51,839
    do not know, maybe someone with the manual will chime in.
  7. priuscatprimeguy
    2,730
    2,640
  8. bisco
    51,839
    will do, i'll get back to you in a few years.
    priuscatprimeguy likes this.
  9. priuscatprimeguy
    2,730
    2,640
    I'll be waiting:cool:
  10. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
  11. bisco
    51,839
    pg. 126) traction battery heater: when the outside temperature is low, and the charging cable is connected to the vehicle, this function automatically warms the hybrid battery ( traction battery ) until it reaches or exceeds a certain temperature.
    only took me 32 minutes.:cool:
  12. El Dobro
    El Dobro A Member
    7,086
    3,263
    What's heating the battery?
  13. bisco
    51,839
    doesn't say, electric cables?
  14. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    These ranges are just estimated from the Ev mode efficiencies calculated by the car (5.7 * miles/kWh):
  15. priuscatprimeguy
    2,730
    2,640
    the act of charging the traction battery is supplying the heat.
  16. El Dobro
    El Dobro A Member
    7,086
    3,263
    But, what if the battery's already charged? I'm thinking the car heats the interior, then the battery fan takes the heated interior air and blows it over the battery.
  17. bisco
    51,839
    this is the great part of a new vehicle, no one knows anything, and toyota won't disclose any more than is in the manual.
  18. dave3057
    dave3057 Member
    68
    37
    Baltimore, Maryland
    iPad ?
    El Dobro likes this.
  19. priuscatprimeguy
    2,730
    2,640
    Even if it's fully charged. I have taken a measurement with my data logger and noticed when the traction battery heater was activated I saw the same wattage draw. Prime charging status 2-9-2017.JPG
  20. So, on cold mornings such as this (24F), I preheated my car using battery, and also had the warm air blowing in the car, which is another penalty to electric driving range. In practice I can get around 23 miles with a full charge in these conditions.
    bisco and priuscatprimeguy like this.
