EV Doesn't kick in with a full charge
Discussion in 'Prime Fuel Economy & EV Range' started by LAP, Nov 7, 2017.
  1. LAP
    LAP Junior Member
    New York
    Four Touring
    We have a 2017 Prime. We've noticed in NY as the weather has gotten colder and despite our car having a full charge, the EV doesn't kick in right away. We sometimes have to drive it for a couple of minutes, shut it off and restart. Does it need to be warm for the EV charge to be used? Any tricks to warming the car before we start driving? Love the car though...
    priuscatprimeguy likes this.
  2. Are you using the windshield defroster? The engine has to be on for that to work.
    Also if you have Advanced, you can preheat the car via the Entune app.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    lol, take a number:p, See "ICE comes on anyway" thread
    Prodigyplace likes this.
  4. ICE comes on anyway | PriusChat
    And you would think that it would appear at the bottom of this page under "Similar Threads" but it doesn't
  5. priuscatprimeguy
    2,730
    2,640
  6. bisco
    51,839
    if you don't shut it down and restart, it never lets you run ev mode?(n)
  7. Tideland Prius
    16,547
    A cold battery will be less willing to discharge.
    Keeping the Prime plugged in will allow the car to use wall power for the "traction battery heater" (see manual using those exact words for more info). You could also pre-condition the cabin prior to setting off so that the interior is warm, requiring less energy to maintain the temperature (rather than starting from scratch).
    Except for safety reasons, avoiding using the windshield defroster. As soon as the windshield is clear, take it off the defroster. Again, if you pre-condition the cabin, hopefully that'll reduce the need or the length required of the defroster.
    Okopipi likes this.
  8. Mark57
    2,945
    2,740
    OK
    So during cold weather, it would be better to leave it plugged in all the time when not driving it, irregardless of the charge schedule. (less than 3 days)
  9. priuscatprimeguy
    2,730
    2,640
    true, but ICE will still kick in when it's below 50 F. Traction battery heater or no traction battery heater.
    Mark57 likes this.
  10. Mark57
    2,945
    2,740
    OK
    I meant while parked in a garage situation.
  11. priuscatprimeguy
    2,730
    2,640
    works for me. (not that I have a garage to put my Prime in):D
    Mark57 likes this.
  12. priuscatprimeguy
    2,730
    2,640
    It could be the morning sun warming up my car but it was covered in frost this morning and a couple of hours later it was frost free. Started out on my usual trip where ICE usually kicks in. It didn't this time.:D
  13. Tideland Prius
    16,547
    That's my understanding. However, you guys are the ones with the Prime (still waiting for it be launched here) so you guys can confirm that for me :D
    Problem solved then? Park such that the front of the car is facing the morning sun :D
  14. Mark57
    2,945
    2,740
    OK
    It would be nice to know what the ambient temperature parameters are that the battery thinks is too hot and too cold.
  15. Tideland Prius
    16,547
    The only the manual states is that if the battery temperature is below freezing, the traction battery heater will bring it back up to freezing. Note that it's battery temperature... so the car will probably have to sit outside for almost a day (assuming you used the car earlier) before the battery temperature drops below freezing. (I think for the Gen 4 had something similar where Toyota suggests that it might take a few days of sitting outside below -30°C before the battery temperature drops below -30°C and the Li-Ion models will require that the battery warm up above -30°C before the car can be driven).
  16. Mark57
    2,945
    2,740
    OK
    Thanks. Mine is always garaged and it never goes below freezing inside the garage so leaving plugged in all day inside the garage won't help my situation. Now, the garage does get pretty hot in the summer so I do need to watch that side.
  17. priuscatprimeguy
    2,730
    2,640
    and when it's cloudy?:rolleyes:
  18. Tideland Prius
    16,547
    Dang it, PCPG, we're trying to help you out here!
  19. priuscatprimeguy
    2,730
    2,640
    Maybe I should move to Nevada:cool:
  20. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Drove to my flight meeting last night after dark. 22F and snowing. Ev the whole way. The car then sat outside getting snowed on and cold soaking for 3 hours. Drove home all Ev.
