Survey: Oil consumption vs build dates
Discussion in 'Gen 3 Prius Main Forum' started by StephenJ, Aug 21, 2017.
  1. bisco
    51,045
    funny, he talks about the 'old cars with tight engine tolerances' wearing out and burning oil at 150km, but that's just the issue we're discussing here with new cars with loose tolerances.
  2. Den
    Den Junior Member
    30
    SF Bay Area
    79k miles
    Oil change interval 15K miles
    No oil consumption
  3. harrysprius
    harrysprius Active Member
    277
    126
    Nashville, TN
    Seriously? Is that 15,000 miles or kilometers?
  4. Den
    Den Junior Member
    30
    SF Bay Area
    15,000 miles, i use amsoil signature series 0W-20 oil.
  5. MelonPrius
    MelonPrius Senior Member
    839
    514
    Las Vegas
    (hijack)
    Harry, our maintenance minder is based on miles. On my Accord, it's based on driving habits, which can extend the change intervals. Your driving route is probably designed for less frequent oil changes, compared to stop and go in more extreme conditions. Oil sent in for analysis have shown that it can often last longer than the manual suggests.
    Here's an interesting article from last year: http://www.chicagotribune.com/classified/automotive/sc-changing-oil-autos-0519-20160516-story.html:
    (hijack over)
  6. harrysprius
    277
    126
    Nashville, TN
    harrysprius said: ↑
    (hijack)
    Mercedes-Benz, for example, uses full synthetic oil, and some owners have reported that the oil life monitor didn't call for an oil change until 15,000 miles, Calkins said.
    (hijack over)
    I still do 5k with synthetic on the "around town car", and was moving to 7500 on the commuter, "all highway car". I don't know about moving to 15k.......
  7. Mendel Leisk
    40,506
    But the main purpose here is just to record, not debate?
    m.wynn, Colm01 and Raytheeagle like this.
  8. bisco
    51,045
    i think o/p has moved on to a 2009, debate away!:p
  9. GardenWeasel
    GardenWeasel Member
    76
    53
    Columbia, SC
    2010 made 2/10, bought new in June 2010
    120,560
    No oil consumption
    Just a darn dash rattle that comes and goes.
    bisco and Raytheeagle like this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Keep to the rules and stay on topic:whistle:.
    Maybe next time (y).
  11. bisco
    51,045
    okay, goalposts have changed again, it's between a 2009, and 2011.:rolleyes:
    m.wynn and Raytheeagle like this.
  12. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    We all love the moving target:cool:.
    m.wynn and bisco like this.
  13. spiff72
    spiff72 Member
    184
    37
    West Michigan
    2010 Prius IV
    Build Date 6/10 (purchased Jan 2011)
    77k miles
    No consumption at this time (knock wood)
  14. orenji
    orenji Senior Member
    5,886
    3,487
    2010 III W/Solar
    Build 10/10
    80k miles
    Using 0W-30 Mobil 1 and recently went to 0W-40 Mobil 1
    No oil burning. 5K mile oil change.
    neaux.m and Raytheeagle like this.
  15. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    2013 model 4
    Build Date: 01/13
    113K miles (owned since 40K)
    No oil consumption issues
    Change oil at 10K intervals with Moble Synthetic 0W20
    Mostly highway miles
    orenji and Mendel Leisk like this.
  16. hayden55
    hayden55 Member
    115
    48
    Oil consumption is a fact of life. Rings don't perfectly seal and you'll get some problems whether it be blow by, oil break down through contamination by gas in the oil, or just oil getting past the rings and being burnt. Id recommend not doing engine breaking as the number one unless you absolutely have to. Past that:
    116k miles
    10k changes. 0w-20, cheap oem filters.
    I put in 5 quarts every change and it ends up at 4 quarts.
    That works out to a quart every 10,000 miles which is extremely healthy.
    I've owned Honda's that burned a quart ever 300 and still ran like a champ as well and rolled a little coal.
    I'm probably gonna bump it up to 12k and send in the oil analysis and see where it gets me at tbn. Keep in mind i run 5 quarts.
    neaux.m, Raytheeagle and Mendel Leisk like this.
  17. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,342
    Wilmington, NC
    9/09
    133,000 miles
    Burns no oil
    No other issues
    I have changed oil at 5k intervals and used Toyota 0W20 oil and filters.
    Raytheeagle and orenji like this.
  18. CR94
    CR94 Senior Member
    2,662
    1,150
    Northwestern S.C.
    Built 3-11 (acquired 9-14 at 41k)
    83k now
    Very low consumption
    TGMO by dealer for first 61.5k
    Rural King & Pennzoil Platinum since
    Careful not to overfill, and dealer was too, apparently.
    #38 CR94, Nov 19, 2017
    Raytheeagle likes this.
  19. 4md
    4md Member
    97
    55
    Sofia, BG
    Joining the survey...
    Gen 3
    02/2011 from the documents (the European models don't have the build date printed on the sticker)
    176k km / 110'000 miles
    No oil consumption, but:
    I bought it used, and changed the oil with 5w-30 for the summer (it's hot here). It didn't consume any oil about 5k km / 3'000 miles after the change, then the level dropped a bit after about 700 mile highway trip with more than 110*F / 43*C ambient temps. After that, until the oil change at 11k km / 6'800 miles, the level did't drop, but the oil become very dark in the last 6-700miles.
    For the cold season (sometimes the winter temps go under -11*F / -24*C) I put 0w-20 and 1200 miles later with 250 miles on the highway, there is no oil consumption at all.
    orenji and Raytheeagle like this.
  20. southjerseycraig
    southjerseycraig Active Member
    438
    107
    Cherry Hill, NJ
    2010 Prius II
    06/09
    92,000 miles
    needs half quart every thousand miles (has apparently done so since about 85,000 miles)
    no other issues.
