Noise in prius engine
Discussion in 'Gen 3 Prius Technical Discussion' started by Wahid D, Nov 15, 2017.
  1. bisco
    50,825
  2. Wahid D
    Wahid D Junior Member
    Lahore
    Sir You are right, I,ll check the belt morrow, the noise not end after getting warmer, and one more thing i note today that is On POWER Mode Or ECO Mode when i suddenly accelerate the sound comes like when we try to drive manual transmission vehicle at 40 speed in 4th or 5th gear, the second thing is my prius gear is smooth when i drive, back or use parking didn't feel any noise aur disturbance, and when i drive just on battery then noise ends.
    amos likes this.
  3. Wahid D
    Lahore
    Thank You :)
  4. Wahid D
    Lahore
    Im Using ZIC 10/40 5 thousand mileage 4 liter
  5. Wahid D
    Lahore
    Sir what kind of Info you need? tell me i,ll provide
  6. Wahid D
    Lahore
    What I,ve to do then?
  7. Wahid D
    Lahore
    :cry:
  8. Jayw13702
    Jayw13702 Active Member
    142
    170
    Plymouth UK
    You need to have the engine tested for head gasket leak.
    Here in the uk we have a “sniffer” test, it tests for oil in the water and water in the oil. That would be my first place to start
    2010 Gen 3
    Tbkilb01 and amos like this.
  9. bisco
    50,825
    is 10/40 the recommended oil? seems thick, but i suppose a warm climate.
  10. Dxta
    Dxta Senior Member
    1,932
    769
    Lagos
    Can you just place the recorder close to the engine immediately you start the car?
    After you've done that, try revving the engine some bit, to see if that noise is proportional to it.
  11. Tbkilb01
    Tbkilb01 Active Member
    216
    187
    Louisiana
    I hear it in the background.
    It's a knocking thump sound.
    At cold start mine does it too.
    sounds close to CVT but hard to tell. Hasn't increased nor decreased last 10k miles.
  12. Arjen
    Arjen Junior Member
    Netherlands
    Hi Wahid D,
    Same noise experienced. It has something to do with bad fuel mixture or misfires at some times. Possibly caused by an old type Intake manifold. There has been a TSB for it, see:
    NEW!!! Service Bulletin for Engine Knocking at Startup T-SB 0012-10 | PriusChat
    Can you tell me the partnumber which is stamped on the Intake manifold?
    Can also be slightly/more worn sparkplugs, causing random misfires, when was the last change milage? or EGR or TB dirty.
    Greetings Arjen.
    Danny3xd likes this.
  13. milkman44
    milkman44 Active Member
    591
    386
    Ky
    I think you're in the right ballpark, I had the same random sound and was experiencing misfire. Sure sounds the same and I think it comes from the clutch plate that they use for a damper between the engine and electric motor. I fixed the misfire and never heard it again. The noise in the video is NOT a connecting rod as his "mechanic" suggested.
    #33 milkman44, Jan 8, 2018
  14. Danny3xd
    Danny3xd Active Member
    238
    149
    CT. U.S.
    "TB", Arjen?
  15. Mendel Leisk
    40,247
    You can remove and clean the intake manifold, that would also determine if it's indeed IM clogging that's the issue. I'm not sure that the revised intake manifold solved anything, it's expensive, wasteful of resources, especially when simple cleaning is a good first step. Watch @NutzAboutBolts video for intake manifold cleaning, it is one video in the set, here:
    One comment on the above: it is possible to remove the throttle body without disconnecting coolant hoses.
    NutzAboutBolts likes this.
