Car hit while stationary, does severe tire slant = bent axle?
Discussion in 'Gen 2 Prius Technical Discussion' started by Thane, Dec 7, 2017.
  1. Thane
    Thane Junior Member
    26
    17
    Longview, Wa
    edited to bring all text in view
    my 2004 was involved in a hit and run accident the other night. I came out of the apartment to find it like this. The car seems to have been hit square in the driver side quarter panel. The rear doors still operate as normal and the rear hatch just scrapes the tail lamp just a bit but seems normal otherwise. What worries me is the passenger side rear tire. You can see it looks slanted and it appears the passenger side wheel got wedged up against the curb. The wheel and the hub are parallel. Does the entire rear axle needs replacing? Can the axle be straightened? Could it be possible that the suspension just got tweaked in some way to look like that? I haven't tried driving it yet.
  2. scona
    scona Active Member
    225
    206
    Courtenay, BC, Canada
    2013 Prius v wagon
    If insurance is involved I would leave it there until it is inspected. If not, perhaps drive it ahead a car length or so, moving it away from the curb carefully as you do so. Then see if it still looks the same or if it straightened out. It looks like the right rear is against the curb so the mag wheel might get scraped a bit if it is moved. All you can do is use your best judgement.
  3. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    From the picture it looks like the axle is bent. Axle beam can’t really be straightened.
    Axle beam might be bent from the other side as well as that’s where the other car hit. Rear wheel bearings might also be damaged when this happened, so probably the cheapest fix is to get used axle from a junkyard with bearings still attached to it. Also you might have some damage to the fuel filler neck. That would cause fault code and check engine light. Fixing the body damage (really just cosmetic) is pretty expensive as that’s not an easy area to fix. And you do need a new tail light as well.
    So if you can, using insurance might be a good option…
  4. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Jack it up and see what springs loose, the car got pushed into the curb, it might be stress that is relieved when you jack it up, I wouldn’t move it, I’d jack it first.
  5. fotomoto
    fotomoto Senior Member
    5,626
    3,802
    So. Texas
    That amount of damage on a 2004 is a total loss.
    Good Luck!
  6. Kenny94945
    Kenny94945 Active Member
    833
    412
    Sausalito
    2016 Prius v wagon
    If insurance....let them handle...yes may be a total loss.
    (Start looking for a like vehicle to establish value.)
    If no insurance...do not straighten axle, or cross bar IMO.
    First step is to get the car in the air, Remove all the rear suspension, Professionally measure the frame.
    Then begin repair analysis from there.That's how I would "attack" it.
    Then you have the visual - quarter panel replacement, bumper and color match to deal with.
    Also I believe this repair - just suspension portion - will take more than a weekend if DIYing.
    Lastly, even with used parts and hammers I think you are into this $2000.
    Good luck.
    Kevin_Denver likes this.
  7. Thane
    Thane Junior Member
    26
    17
    Longview, Wa
    Thanks very much for all the advice. I was switching insurance since Gieco almost doubled my rates slowly over 8 years without notifying me despite no accidents or tickets. Unfortunately i took my time getting new insurance since i had no need for the car and i didn't have it when this happened. I could do this myself but i'd have to do it on the street if i did so i think i will just take it in. Thanks again.
  8. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    If it didn't rain recently, looks like a lot of fluid was spilled. The axle might be too bent to repair. Who knows what other damage might be lurking behind that wheel?
    Prodigyplace likes this.
  9. Mendel Leisk
    40,272
    I took a very similar hit, on our 2010, same corner. Rear axle beam had to be replaced (insurance payed for new). You wouldn't know anything had happen now, full insurance job, bottom line in Canadian dollars: $6700.
    Thane likes this.
  10. Mendel Leisk
    40,272
    Appreciate it's a different gen, but maybe this'll give some idea of scope. Wheel was ok btw.
    Thane and SFO like this.
  11. Thane
    Thane Junior Member
    26
    17
    Longview, Wa
    Oh thanks, ill have a look at those. I had a look underneath the car and just to replace the rear axle beam looks super easy. I mean there is only 6 connections to the frame total and they are all small'ish sized bolts and two of those are just the struts connections, just need a strut spring compressor for those. The hardest part looks like all the little brake line fluid connections, not sure how that'll be working with with all electronics. I have bled brakes once before, but with an old 1979 Olds.
  12. valde3
    2,002
    746
    Finland
    No you don’t need a spring compressor to replace the axle beam.
    But if you have to open the brake line you do need a computer with techstream software. You can’t bleed the brake the traditional way as they are not directly connected to brake pedal.
  13. scona
    scona Active Member
    225
    206
    2013 Prius v wagon
    Brake bleeding is a bit more complicated on a Prius, than with your 1979 Olds. Do a search and you will find some good information on that on this forum. Sounds like you have a project on your hands, probably not what the plans were to end 2017. Best Wishes for a new and improved 2018.
  14. Thane
    Thane Junior Member
    26
    17
    Longview, Wa
    Thanks valde3, no compressor needed, great. Thanks scona, will do a search.
    Its pretty funny, my investigation into techstream software started me off at a $1,300 proposition and ended up and $20, or even less, from Ebay, new. More research needed.
  15. Mendel Leisk
    40,272
    If your wheel is slanted, probably need replacement bearing on that side, if even just to be on safe side.
    If it's similar to third gen, the axle has two arms going forward, that connect with some serious bolts with bushings. Also, you'll very likely need to replace the wheel bearing on the hit side, and transfer the bearing from the other side. Or just get two new? New of the aforementioned bushings too?
    I'll attach 3rd gen rear axle replacement, just to get a feel for what's involved. I'm definitely a lightweight, would never even consider doing this myself, lol. Especially with all the bodywork needing repair as well, it'd be pros all the way for me.
  16. valde3
    2,002
    746
    Finland
    Here’s the manual for gen 2: http://www.selidori.com/tech/00000-04999/261-0yKYe.pdf
    Probably best to get a used axle beam with bearings as they might have been damaged as well.
    Unfortunately you do need to open the rear brake line while doing this so you need a techstream to bleed the brakes after the work as the brakes in a Prius are not directly connected to brake pedal.
  17. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    Possible that the wheel is just bent, but that car is totaled in any event.
  18. Thane
    Thane Junior Member
    26
    17
    Longview, Wa
    Okay, i replaced the rear axle beam, the point where the hubs mount to the rear axle were definitely bent. Super easy job. Highly recommend doing this yourselves if ever in need. Turned out it only had 4 major connections to the car, two being the struts. The main two connections to the frame had nuts that held themselves taught after being tightened a bit, and so didn't even require me to hold the nut while tightening or loosening the other side. For brake bleeding, i learned that the rears don't require any special procedures (that i know of) and require the system to be in full operational condition when bleeding, so it was just a matter connecting a $7 one-man brake bleed kit and depressing the brakes using my jack handle weighted with the jack itself, then opening the bleeder and closing it when the air stopped running. Very quick. I followed the advice by one of the geniuses on this forum to siphon up the brake fluid in the reservoir first then filling with new fluid of course before bleeding. As always i recommend using 3 or more jacks to make the job safe (and feel safe), i used 4 jacks. Thats what i do anyway, makes me feel safe to push and pull at will.
    The brake drums were a pain in the nice person to get off the new (used) axle beam. For those that don't know, to get off a stuck brake drum, just put a proper metric sized bolt through the holes in the drum faces made for exactly that purpose. I borrowed metric bolts from the base of the hybrid battery pack within the car and then didn't put them back because thats how i roll (no im kidding, i put them back).
    I got estimates to fix the damage between $5,000 and $10,000 due to the internal heavy metal being crushed somewhat to, beyond the quarter panel. I can't afford to fix the damage and only ever afforded the car in the first place with some money my grandma left after she passed away. I just moved to Longview from Seattle and have been trying to get a job for 6 months and am currently a parasite to my Mom's bank account which is major source of depression right now not knowing how and when i will be able to pay her back with a minimum wage job. Chris Randall, from car-part.com was nice enough to respond to my concerns about the rust and damage i was seeing in many other rear axle beam sale pictures and found a one off a 2008 with drum brakes in Nevada we assumed would have very little rust on it. $200.00 plus $25 for shipping was all they charged.
    I also did manage to push the dent in the quarter panel about half way back to normal using a $20 8lb. sledge hammer and some 12in. 2x4s. I used string to hold the wood in place for each strike, using a make shift hook tied on one end anchored to the rear hatch well, string going under the wood, then back up over the well and all the way to the rear driver door catch where i wrapped it around that multiple times and it held with friction. Also some coat hangers to help maintain the position of the 2x4s.To get the rest of the way, i'm going to use some heat (carefully) on the next sunny day. The interior metal damage has effected the safety of the car and so i will have to notify a buyer about it when i sell it, so even if i fit it on the cheap, i will have lost a ton of money i think.
    The hammering has separated the 1/4 panel from the internal parts, but when its all pulled, i'll just use the waterproof expanding foam to seal it then a 50 gallon drum of polish should make it all look like new. Pretty sure. I'm not a scientist.
    #18 Thane, Mar 23, 2018
  19. Mendel Leisk
    40,272
    Are there threaded holes for that purpose? Which side are they, 'round back? Any way you could post a picture?
    Data Daedalus likes this.
  20. fotomoto
    5,626
    3,802
    So. Texas
    Good job on the repairs so far. What about the fuel door and filler neck?
    Let's see some pics!!!
