TPMS Sender Battery Life?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Air_Boss, Dec 10, 2017.
Tags:
  1. Air_Boss
    Air_Boss Senior Member
    4,190
    1,177
    New Yawk
    Any idea how long a TPMS sender battery is supposed to last?
    2012 Prius v Five TPMS'ing on borrowed time?
    Going to replace tires in the spring and wonder if I should replace TPMS (or the batteries if those are removable).
    Thanks.
  2. Kenny94945
    Kenny94945 Active Member
    850
    424
    Sausalito
    2016 Prius v wagon
    I'll answer with writing 10 years (even more) would not be unusual.
    So, with your 2012 I would not replace the sensors yet.
  3. Mendel Leisk
    41,335
    You would have to replace the whole thing, not just battery, and it's way too soon, battery's should be fine. The tire place will likely propose a rebuild kit, basically new valve and gaskets. If that's not too much it might simplest to just go along with them, hopefully they do it right.
    #3 Mendel Leisk, Dec 10, 2017
    RCO and bisco like this.
  4. bisco
    51,851
    i put new tires on this summer, didn't replace them.
  5. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    My 2006 (first TPMS year) going on 11.5 years now for three of them. One died at 9.5-yr.
    Depends a little on total mileage mine is 165k miles. The TPMS battery is OFF when the car is OFF, so that's why total miles is an indicator.
  6. Air_Boss
    4,190
    1,177
    New Yawk
    Interesting. Centripetal or centrifugal force switching? Guess these can stay on rim @ 33,000 miles. Thanks, all !
  7. mikefocke
    3,988
    1,801
    Sanford, NC
    Just replaced my perfectly good tires on a '12 v Three 43k miles. TPMS service pack @ $7 ea.
  8. Air_Boss
    4,190
    1,177
    New Yawk
    What does the service pack include?
  9. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    The service pack is just hardware for remounting the stem so it doesn't develop a leak after time.
    Batteries are not replaceable without invasive surgery into the sender unit; I don't know of anyone rebuilding them. Probably a liability issue.
    While I keep reading the TPMS sensors don't signal when the car is not moving, it is possible to dismount a working sensor and get it to send a "valid" signal by either placing it into a pressure vessel or squeezing it with a clamp. A mechanism to conserve battery life while the vehicle is not moving makes huge sense, but that isn't necessarily consistent with those tests.
    RCO likes this.
  10. Air_Boss
    4,190
    1,177
    New Yawk
    They are passive transponders to a device that 'pings' them, which is how the device ID can be identified, on rim.
  11. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    A passive device would need power to listen out, wouldn't it? (n)
  12. Air_Boss
    4,190
    1,177
    New Yawk
    No, these are typically passive transponders, initially powered-on by electromagnetic energy transmitted from a 'pinger' (reader), either external or the vehicle TPMS system, which makes it logical that remaining battery life would be a function of vehicle 'Hobbs meter' running time or mileage. By contrast, an active transponder is constantly powered, and battery life would be more a function of time since installation.
    #12 Air_Boss, Dec 13, 2017
    RCO likes this.
  13. wjtracy
    11,366
    3,608
    Northern VA (NoVA)
    I think they work when car is not moving as long as vehicle is ON (if you are talking about Prius OEM)
    RCO likes this.
