EGR & Intake Manifold Clean Results
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rebound, Jun 25, 2017.
  1. Dan05979
    Dan05979 Member
    181
    101
    New York City/Upstate NY
    I'm in the same boat. did all that cleaning and now here & there i get a little shaking from the motor, then it smooths out.
    amos likes this.
  2. Mendel Leisk
    40,245
    Yeah I would think it varies, some service departments are reasonable, open minded, others might go "Costco" on you..
    amos likes this.
  3. amos
    amos Active Member
    362
    281
    los angeles
    Im thinking maybe. Just maybe. Some hardened carbon pieces got stuck somewhere there at the IM or egr passages because of imperfect cleaning i did
  4. Tideland Prius
    16,406
    :LOL:
  5. Dan05979
    Dan05979 Member
    181
    101
    You use 87 because that's what I'm using. does this car need premium? Maybe that's the issue? Just thinking.
    In another post i had written that i haven't started the car in over a week. So it sat in cold weather. When I started it up the engine shook for a bit then smoothed out, but no check engine light.
    amos likes this.
  6. amos
    amos Active Member
    362
    281
    los angeles
    Yes i have always used 87 octane
    mjoo and Dan05979 like this.
  7. mjoo
    mjoo Senior Member
    1,147
    1,326
    Michigan
    IMHO, this car needs clean gas with detergents (top tier) or regular injector cleaners. From what I've read - the rings easily get coked up which can lead to more blow-by and oil burning.
    They also need periodic EGR cooler cleaning and Amos may soon need one.
    Pixel XL ?
    m.wynn, amos and Dan05979 like this.
  8. Tbkilb01
    Tbkilb01 Active Member
    216
    187
    Louisiana
    Needs OCC install. Long hoses
    Tucked out of site as opposed to out in the open for all to see... it shouldnt effect emissions. Mines in a corner by crank pulley.. way low. Cant even see it without removing air intake snorkel and resonator...
    amos, Robert Holt and mjoo like this.
  9. amos
    amos Active Member
    362
    281
    los angeles
    @Mendel Leisk.can you help me here.
    Im at the dealer now for the knocks i had. They didnt find anywring but now they are telling me i have code b1585. I have all lights on my dash for abs traction control antiskid cotrol they all lit. Now dealer is telling me i need to replace the ecu for the cost of over 4000$.
    Yes um shocked and yes i never had any problem with any of those issues. I think they messed it up.
    Do you have any relevant material on that code b1585?
    Im waiting for the service manager.
  10. Mendel Leisk
    40,245
    What do they say "b1885" signifies?
    I see one somewhat relevant hit with google, saying "low restance on air bag squib", and doesn't seem to be Prius or Toyota specific:
    B1885 Seatbelt Driver Pretensioner Circuit Resistance Low on Squib
    I searched my 2010 Repair Manual for "b1885", found nothing.
    amos likes this.
  11. amos
    amos Active Member
    362
    281
    los angeles
    #171 amos, Dec 11, 2017
  12. Mendel Leisk
    40,245
    Ok. Out and about, will recheck asap
    Raytheeagle and amos like this.
  13. amos
    amos Active Member
    362
    281
    los angeles
    There is no check engine light but other lights i mentioned wont go when car starts.Im doing some quick reading. And they are trying to intimidate me now. Still waiting for manager
  14. Mendel Leisk
    40,245
    amos likes this.
  15. amos
    amos Active Member
    362
    281
    los angeles
    I'll tell them that.They are doing a total reset to all computers in the car. It will take three hours. No charge. But i feel im toasted they sgowed me code was there before and other dealer before was lucky to reset it but now no more. Redicilous. They told me straight in my face.fix it or take it out of here no centiments.
  16. JC91006
    JC91006 Senior Member
    16,639
    8,495
    It better be no charge, all it takes is for you to disconnect the 12v battery for 1 minute. 3 hours must include their donut breaks
    samsonite22 and amos like this.
  17. amos
    amos Active Member
    362
    281
    los angeles
  18. amos
    amos Active Member
    362
    281
    los angeles
    I think they f'd up that ecu responsible for the break assemblies. But im not naive to believe they will admit it. And i dont know how to prove im right. Worst experience for me with any dealer or any car i had.right now ans not working. And i get a beep for every little hump on the road. Tried it for couple of miles. I have to wait now .
  19. Davit Kachkachuri
    Davit Kachkachuri New Member
    Georgia
    Hello All From Geoargia,Tbilisi
    I have question About EGR. My car has 184 000 Miles run so i buy it on copart after that i repaired car. I didnot know hystory(whot done old owner), but i have 2 gen prius(engine 1.5) and have 50 mpg now i have 43/45 MPG on 2010 year 3 Gen (engine1.8) prius. If i clean this EGR can it give me more MPG? I cleaned both cars battareys Bus bars.
  20. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Cleaned:
    EGR + cooler - was dirty
    EGR pipe - was dirty with round deposits
    manifold intake - was clean, very
    replaced PCV valve - was ok
    inspected throttle body - was clean
    For EGR i did:
    - cleaned using air compressor. some stuff came out
    - cleaned using a EGR cleaner in a compressed can, it worked VERY well, disolved a lot of stuff.
    - cleaned with water hose
    - cleaned with air/water pressured
    - cleaned/dried with air compressor.
    It looked very like-new at the end, I should have taken some photos. I could see no other stuff when looking through it
    Prius Plug-In 200k km
    capolihu, amos, Robert Holt and 4 others like this.
