Buying Used 2007 Prius that hasn't been started for 2 years
Discussion in 'Gen 2 Prius Technical Discussion' started by HaiImBrian, Dec 12, 2017.
  1. HaiImBrian
    HaiImBrian Junior Member
    45
    Los Angeles
    I am a proud owner of a Gen 3 but I just got an opportunity to get a gen 2 2007 with only 14k miles on it for an amazing price. This isn't some lucky craigslist find, it's from a friends aunt who is moving out of town.
    The problem is, it hasn't been driven for the last 2 years and the car does not start. I'm assuming that the 12v battery just needs a jump start but I'm quite concerned about the traction battery on the Prius.
    What do you guys think?
  2. JC91006
    JC91006 Senior Member
    16,656
    8,504
    Don't try to start it! It'll kill the traction battery.
    You should have that traction battery charged and balanced BEFORE you attempt to start it.
    If you're in Los Angeles, I can help you with that or you can buy a charger from hybrid automotive.
  3. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Yes good advice JC!
    That's really cool, a 10 year old hybrid cars that's basically brand new! Keep us updated!!
  4. bisco
    51,027
    aunt find! congrats, do it right, and you might have a great little car there. all the best!(y)
    Data Daedalus and WilDavis like this.
  5. HaiImBrian
    45
    Los Angeles
    Thank you for the advice. I just checked the site and there are so many chargers. Which one do you recommend? I am also in Los Angeles! Are you a supplier or do you offer a service/product?
    Will do! I've only had my use gen 3 for 6 months and I've already put over 14k miles on it haha.
    I'm assuming this is referring to JC suggestion? Is recharging the traction battery from scratch the only way to do it?
  6. Prodigyplace
    12,395
    11,676
    Central Virginia
    For recharging the traction battery, we generally recommend the Prolong Charger from Hybrid Automotive. If you get the discharge-ready harness, you can get a discharger in the future to recondition the battery. If you get a Gen 3 harness, the charger & discharger will work with your 2012 too. @jeff652 is the company owner and very helpful here.
    @Raytheeagle may have some additional suggestions.
    Raytheeagle and WilDavis like this.
  7. JC91006
    16,656
    8,504
    I'm in the Los Angeles area, I can help you charge the battery if you don't want to buy the equipment.
    But since the car has been sitting for so long, it may need some work done before the car is ready for the road. For example
    1. change oil
    2. change transaxle fluid
    3. change gas if it's bad
    4. make sure brakes are functioning
    5. tires might need to be changed
    #7 JC91006, Dec 13, 2017
  8. Prodigyplace
    12,395
    11,676
    Central Virginia
    If it were me, I would take @JC91006 up on his offer.
  9. VFerdman
    VFerdman Senior Member
    1,185
    1,212
    Western Massachusetts
    Did I read it right?! 14K miles on an '07? Wow!
    Take care of it properly to get it ready for the road and enjoy!
  10. Mendel Leisk
    40,471
    Brakes might be seriously rusted up, rotors and/or drums. OTOH, Southern California, maybe not. Tires too, might be flatspotted from sitting so long.
    A little dismaying about what protracted idle time might do to hybrid battery. Our 2010 when new, was 15 months past manufacture date. But maybe more stable when new? No problems, over seven years on.
    #10 Mendel Leisk, Dec 13, 2017
    Raytheeagle likes this.
  11. bisco
    51,027
    yes, stick with JC, he'll steer you right.
    Raytheeagle and Prodigyplace like this.
  12. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    Sounds like a great find. Some good recommendations so far, my only question is "has it been garaged for those 2 years?" Good luck, and you've certainly come to the right place for great advice! :)
    Data Daedalus and Chodronish like this.
  13. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    Best before first startup is:
    1. Replace 12V
    2. Recondition HV battery
    3. Change motor oil
    4. Change gas, or at least fill it up with 5 gallons of premium (old gas looses octane rating over time, so premium will help balance this)
    Transaxel and other fluids should be in good enough shape to start the car. Tires will probably be flat-spotted and will likely need replacement. Do some intentional controlled breaking around the neighborhood before getting it into traffic. The rotors and pads will definitely have some corrosion that will take at least a few good brake cycles to get off.
    Data Daedalus likes this.
  14. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    The local dealer here still has 3 brand new 2015s sitting on their lot:cool:.
    That would be an interesting data point for comparison ;).
    When we were shopping for a new car for the wife in July they had a 15 HiHy there and I inquired about it. Being 3 model years old didn’t deter them from starting at MSRP:eek:.
    Let’s just say we kept looking;).
    Aaron Vitolins and JC91006 like this.
  15. JC91006
    16,656
    8,504
    I have a nearly new 2015 for sale. In about 10 years, it should have close to 20k miles. I don't have a chance to drive it
    Asking MSRP
  16. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    How many Prii are in your stable:whistle:?
    Seems like it grows frequently :).
    At least that one isn’t a project(y).
  17. JC91006
    16,656
    8,504
    No more for now, out of room and CA registration just went up.
    8 and counting. I'm ready to sell some....
  18. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    I might look you up when you are ready to part with the 2015;).
    Just clicked 170 k miles on our 2010 and going strong so it’ll be awhile (y).
    Prodigyplace and JC91006 like this.
