Oil Burning :(
Discussion in 'Gen 3 Prius Main Forum' started by fustion, Dec 15, 2017.
  1. fustion
    fustion Junior Member
    Antelope
    Hi Guys,
    I recently just got my dad's Prius as my official car! Unfortunately it was time for a oil change and the dealer noticed that its starting to burn oil. I questioned him regarding about it and how it only has 130,000 miles and I see all these other cars working perfectly fine. Anyways, I was wondering if I should put different oil then the one that Toyota puts?
    Thanks
    2010 Prius V (I think?) (Not the van)
    51,851
    many 2010 prius burn oil. check out the threads with many recommendations.
    and don't wait for the dealer to check your oil level, or your engine may blow up.
  3. bisco
    51,851
    congrats on your new to you car btw, all the best!(y)
  4. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Congrats on your new car. I don't know how the dealer would know that it's using too much oil, unless it was really low. Just keep a real close eye on it. The dealer probably put in 0w-20. Another person here puts in 5w-30 synthetic when he has to add oil and I'm going to start doing the same thing. You might want to do that also if you determine yours is starting to use oil.
    Montgomery and Raytheeagle like this.
  5. BZzap!
    BZzap! Senior Member
    1,607
    878
    If it were my car, the first thing I would try is a 0w20 high mileage formula oil. The high mileage formulas contain additional additives that may be beneficial and reduce you oil consumption. It cost no more than regular 0w20 and can’t hurt to try.
  6. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    the real depressing part is the gas motor doesn't have 130,000 miles yet because it isn't running all the time.. it might have 80,000 actual miles... it will only get worse, I have seen some here say they burn a qt every 600 miles.. consider selling it now or start saving for a rebuilt motor .. a used motor is a waste of money as the all burn oil
  7. Mendel Leisk
    41,347
    If it were my car, that'd be the last thing I try, after:
    1. Verifying oil consumption rate, over a decent period of time/miles.
    2. Going to a heavier oil if needed, say 15W30.
    If you're for example consuming say around a quart between oil changes, I'd maybe try a heavier oil, or even just monitor and top up a little more often.
    High mileage oils work by swelling rubber gaskets, and are really a last resort. Once you start with them you stick with them. If you were to return to regular oil, the rubber gaskets would shrink back, likely more than at the outset.
    bshef and tvpierce like this.
  8. bisco
    51,851
    kinda like muscles.:unsure:
    paprius4030 and Mendel Leisk like this.
  9. CR94
    CR94 Senior Member
    2,689
    1,169
    Northwestern S.C.
    Oh!? Mine must need the high-mileage stuff.
  10. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    As Mendel L wrote, first figure out how much oil the engine is consuming. Check it at every fill up and update this thread. Then we'll see the most relevant feedback posted here.
    scona likes this.
  11. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I use 5w-30 all the time;).
    Have been since 120 k miles (just clicked 170 k miles:)).
    Have done many things but going to 5w-30 has helped.
    To the OP, keep a very frequent eye on the dip stick (I check our 2 vehicles every Saturday) and add as needed.
    Keep us posted (y).
    bshef and edthefox5 like this.
  12. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Used motor? Yeah, you're right. Chances of using a used motor would be 50/50.
    If it were mine, would overhaul it, if I've got the time.
  13. Johnny Cakes
    Johnny Cakes Senior Member
    1,045
    780
    Virginia, USA
    Do a search for the Consumer Report study on oil consumption in cars. They found no correlation between oil consumption and engine failure/ serious problems. Their bottom line is that if you don't mind the expense of adding oil when needed, there is really nothing to worry about.
    bentbow likes this.
  14. Mendel Leisk
    41,347
    Still, I'd think there is a correlation, for cars with heavy oil consumption and neglectful owners, the ones that don't even realize you need to check oil level periodically.
    CR94 and frodoz737 like this.
  15. CR94
    CR94 Senior Member
    2,689
    1,169
    Northwestern S.C.
    Wasn't that CR study about cars which burn some oil when new, not ones which suddenly switch to heavy guzzling in middle age? Different causes, different significance ...
  16. Mendel Leisk
    41,347
    Our Honda's always fell into the former category, almost prefer that state, compared with our Prius with its miraculous abstinence: keep waiting for the other shoe to drop lol.
  17. CR94
    CR94 Senior Member
    2,689
    1,169
    Northwestern S.C.
    Yep! Conventional wisdom used to be that engines that were especially abstemious when new would soon wear themselves out and become heavy drinkers. I've never known anything to consume as little as this Prius, so far.
  18. Yippeekyaa
    Yippeekyaa Active Member
    137
    160
    North Carolina
    Time for an egr cleaning and oil catch can.
    mjoo and SFO like this.
  19. orenji
    orenji Senior Member
    5,887
    3,488
    I would recommend you switch to Mobil 1 0W-40 weight oil and see if this reduces the burn of oil. This weight of oil is used in other parts of the world for the Prius and you will not notice any difference in MPG's. And 2nd would be buy a scan gauge II and set it to see your RPM's and stay below 3,000 RPM. Too many owners drive this motor too hard.
    mjoo and scona like this.
  20. CR94
    CR94 Senior Member
    2,689
    1,169
    Northwestern S.C.
    In case that is true, I'm easy on it, but I have not seen solid evidence that that's the cause of so many becoming oil guzzlers.
